Causes of thrombocytopenia - Televison & Video
Hello' i have been told in the hospital that i have low platelet in my body, so now the have done a bone marrow test to see whats the course ,am also anenic
I would advise you to stay in touch with the hematologist about these concerns! Go for the bone marrow tests to see what the root cause is. Thrombocytopenia with anemia is a situation that needs to be looked at more closely to get the right treatment.
Feb 16, 2017 | The Health & Beauty
TV lost power - Protect LED D912 blinking
If E994 has continuity , then C701 is ok. defective C701 gives problem with colors and picture.
If there is no led flashing, and does not turn on at all then is the power unit, test the capacitors on the power board.
Sep 27, 2008 | Hitachi 50SBX70B 50" Rear Projection...
Wat are low plateletts
When your skin is injured or broken, platelets clump together and form clots to stop the bleeding. When you don't have enough platelets in your blood, your body cannot form clots. A low platelet count may also be called thrombocytopenia. This condition can range from mild to severe, depending on its underlying cause.8 Feb 2016
Low Platelet Count (Thrombocytopenia) - Healthline
https://www.google.co.uk/webhp?sourceid=chrome-instant&rlz=1C1CHBD_en-GBGB719GB719&ion=1&espv=2&ie=UTF-8#q=what%20are%20low%20platelets
Dec 09, 2016 | Cars & Trucks
Low blood platelets
When your skin is injured or broken, platelets clump together and form clots to stop the bleeding. When you dont have enough platelets in your blood, your blood cannot form clots. A low platelets count may also be called thrombocytopenia.
Nov 04, 2016 | Health & Beauty
What are side effects for apoquel
http://petdermatologyclinic.com/apoquel-information/
Side Effects:
Other drugs in the same **** class as Apoquel include drugs for humans for rheumatoid arthritis, psoriasis, and cancer. In humans, the side effects of drugs in the JAK inhibitor class of drugs include: neutropenia, anemia, thrombocytopenia, increased liver values, increased cholesterol, UTI, weight gain, HPV zoster.
Apoquel side effects listed for dogs in the product insert include: vomiting, diarrhea, lethargy, anorexia, SQ or dermal masses (unspecified), decreased leukocytes, decreased globulins, and increased cholesterol and lipase. Low numbers of dogs in the studies developed demodicosis, neoplasia, pneumonia, ****** diarrhea, skin and ear infections, UTIs, and histiocytomas. Interestingly, a few dogs developed polydipsia, increased appetite, and aggression, similar to what may be seen with steroids.
Oct 31, 2016 | Health & Beauty
What is low platelets
Thrombocytopenia is a condition in which you have a low blood platelet count.Platelets (thrombocytes) are colorless blood cells that help blood clot. Platelets stop bleeding by clumping and forming plugs in blood vessel injuries.
Jul 05, 2016 | Cars & Trucks
What are the side effects of Degranol?
Hi Derek,
SIDE-EFFECTS AND SPECIAL PRECAUTIONS:
Medical supervision during treatment is essential.
The level of serum folic acid should be observed during anticonvulsant therapy since Degranol may enhance the metabolism of folic acid.
Abnormalities of liver function and jaundice have been associated with long-term treatment.
Blood counts and liver function tests should be performed before commencing treatment.
Blood counts should then be repeated at weekly intervals during the first month of treatment and subsequently at monthly intervals; liver function tests should also be undertaken periodically, if allergic skin reactions occur, if the leucocyte and/or platelet count diminish, if tests reveal a deterioration in liver function, or if any serious adverse symptoms develop, Degranol should be withdrawn.
Reaction-time may be increased by Degranol. The patient's safety as a road-user or operator of machines may be impaired in consequence.
Unwanted effects - i.e. loss of appetite, dryness of the mouth, retching, diarrhoea or constipation, headache, drowsiness, dizziness, somnolence, ataxia, disorders of visual accommodation, diplopia, or, in elderly patients, states of confusion and agitation - may occur, particularly at the start of treatment. These effects may require temporary reduction in the dosage.
Hyponatraemia due to the antidiuretic effect of Degranol and possibly accompanied by vomiting, headache, and mental confusion has been observed.
Allergic skin reactions, as well as occurrences of exfoliative dermatitis, paraesthesia, systemic lupus erythematosus, Steven's-Johnson syndrome, photosensitivity, altered skin pigmentation, leucopenia, thrombocytopenia, agranulocytosis, aplastic anaemia, thrombo-embolism, left ventricular failure, disturbances of cardiac impulse conduction, hepatocellular and cholestatic hepatitis, acute oliguria with hypertension and proteinuria have been reported.
A wide variety of other central nervous system, gastro-intestinal, cardiovascular and dermatological effects have also been reported.
In patients with cardiovascular diseases, or with hepatic or renal disorders, glaucoma and in elderly subjects, Degranol should be administered with caution.
Tolerance may develop to some of the untoward effects of carbamazepine and they can be minimized by gradual increase in dosage and adjustment of maintenance dosage.
If treatment with Degranol is withdrawn abruptly, the change-over to another anti-epileptic should be effected under cover of diazepam or a barbiturate.
May 01, 2014 | Health & Beauty
Hi Derek,
Treadmills problem ER7
this error has 2 alternatives: proceed according God bless you
E7- 1) Alternative Elevation Motor
1)Cause: Elevation Motor not moving Solution:Check Elevation Motor connection
2)Cause: Elevation Elevation Motor screw binding Solution: Clean screw and lubricate
3)Cause: Elevation Motor Motor out of Range Solution: Check motor out of elevation
4)Cause: E-Motor Potentiometer: Solution: Replace Elevation Motor
2)Alternative:
Display Doesn't Light Up: a)Cause: On/Off switch Solution: Test unit is turned on b)Cause: Insufficient Power Source Solution: Plug dedicated120V, 20Amp Outlet
c) Cause: Line Cord Damaged Solution: Replace Line Cord
d)Cause: Fuse Solution: Check Fuse on MCB
Nov 13, 2013 | Exercise & Fitness
E 7 error
1) this means 2 alternatives.
2)Alternative:
God bless you
Nov 07, 2012 | Exercise & Fitness
Televison & Video Logo
64 people viewed this question
Top Televison & Video Experts
