Question about Electronics - Others
95 Mustang GT no cold start
After car starts it runs good after its warm.However after it sits over 3 hrs its right back to no cold start?
  • 15 Answers
SOURCE: engine misses at startup until engine warms
sounds like a bad injector take it to the dealer ship and have it checked out
Posted on Dec 27, 2008
  • 10 Answers
SOURCE: 95 Mustang gt backfiring and RPM's bouncing
sounds like you have jumped a tooth on the timing if not timing out
Posted on Feb 05, 2009
  • 6 Answers
SOURCE: 1990 Chevy Scottsdale 1500 wont idle when first starting cold
ICM idle control module, loc throttle body, it may be dirty, remove clean or replace, its easy..
Posted on Jul 29, 2009
  • 6 Answers
SOURCE: saab 95 2002 3.0l v6 turbo. when warm, starts to
Have you had your mass air meter checked or replaced? This is the unit attached to the air intake hose behind your air filter. It senses the air temperature, speed, density, etc... and adjusts the fuel/air ratio to keep the vehicle running at "peak" performance. Also, check your TPS (throttle positioning sensor) it can also cause the problem you speak of. The TPS adjusts your engine speed/idle etc. and also compensates for hot/cold changes etc. This is roughly a $35.00 part and in most cases usually an easy fix.
Posted on Dec 12, 2009
  • 617 Answers
SOURCE: 04 crf450.hard start when cold(25deg).kick for 10min.once it
1. First thing is when was the last time you had your valves adjusted
2. On cold start up twist about 15 times on your throttle, as you do that the accelerator pump in carb will shot gas in cylinder, I have a 2003 yx426 & 2005 yz450 have to do to both of them when cold out to get started
Posted on Feb 07, 2010
4.6l. After warm-up, why does it run rough with missing?
Could be spark or fuel.
Weak or worn spark plugs, weak coil, dirty injector, and so on.
Jan 05, 2016 | 2001 Ford Mustang GT
Starts right up but once it warms up it dies have messed with the air gas screws that's fine don't know what the problem is
My car runs good when it's cold but stalls once it warms up ...
www.badasscars.com/index.cfm/page/ptype...id.../prd289.htm
My car runs good when it's cold but stalls once it warms up? ... In this situation, you can usually re-start the engine once it has hada chance to cool back ... it'll fill-up and exits fuel right up and out the vent tube which dumps it down the middle of ...
Car starts and after warmed up.. it dies!! HELP! - Honda-Tech
honda-tech.com/...del.../car-starts-after-warmed-up-dies-help-2797652/
Jun 28, 2010 - Car starts and after warmed up.. it dies! ... but if i let it sits for awhile till the engine is cool down it starts right up but after its warmed up.. it dies.
Troubleshooting an Engine that Stalls at Idle When Warm ...
www.gearheaddiva.com/.../troubleshooting-an-engine-that-stalls-at-idle-...
Dec 21, 2015 | Cars & Trucks
2001 mustang gt running rich no check engiine light. backfiring and popping cranks and idles good until engine warms up
Begin with Scanning & Checking parameters....Best to begin with a 'stone cold' engine.
Feb 28, 2014 | 2001 Ford Mustang GT
2002 mustang gt cold starting the runs rough and stays that way until it is warm.
Use a bottle of yellow HEET dry gas to remove any moisture problem in the fuel.
Clean / replace air filter.
Top off ATF to MAX level.
Jan 18, 2014 | 2002 Ford Mustang
I have a 1996 Mustang gt with the 4.6. It starts up but then dies right after only on cold days. but starts fine on warm days. When it won't start the theft flashes. when it does start it dosen't...
sounds like your battery is getting to cold id try insulating the battery . if not possable just take out and keep warm, like mabey room temp..
Oct 07, 2013 | 1996 Ford Mustang
I have a 95 mustang gt 5.0. The car was working fine until all of the sudden started to hesitate and died. I let it cool of for a while and started back up again. It feels like the fuel pump when back up...
You might have picked up some water in the gas some where. Put a can of Dri-gas or some other brand of fuel system cleaner/stabelizer. it should fix your problem.
Aug 15, 2010 | 1995 Ford Mustang
'96 VW Golf GL with 2.0 motor. Cold start knock
It sounds like the hydraulic lifters are bleeding down after sitting for a while... there are ball checks which are supposed to prevent this... Try using a good engine flush (a product that frees sticky lifters) and replace the oil with a good synthetic... Hope this helps...;-)
Apr 27, 2009 | 1997 Volkswagen Golf
Car fails to restart after intial drive
Sounds like TFI module I think 95 was the last year for it. Car runs great but when it gets hot dies out. TFI module.
Apr 22, 2009 | 1995 Ford Mustang
Feb 02, 2009 | 1995 Ford Mustang
Electronics - Others Logo
43 people viewed this question
Top Electronics - Others Experts
Are you an Electronics - Other Expert? Answer questions, earn points and help others
