Question about Horizon T202 Treadmill
My horizon t650 treadmillis dead. power checks ok
Hi I have a horizon t4000 premier treadmill, everything seems to work fine when I plug it in, it all the console displays fine, but p1 (programme 1) just keeps flashing and no response from any of the
Hi Anthony, sounds like there is a bad connection from upper to lower, a pinched or bad cable, or bad solder on a connection point.
With the "flickering" of the console lights mentioned, this tells me that the power supply connections to the console were suspect at one time, and doing nothing and having it "work ok now" is not a good sign of something being fixed. Also, with the flickering, this would mean the upper board would be intermittently powering up / down, causing massive trouble with the onboard CPU which is trying to operate the system. I would advise against using the unit the way it is, and have the control board checked. You can contact jatinah electronics for further help if needed. Good Luck!
Jan 11, 2015 | Horizon T4000 Premier Folding Treadmill
My Horizon T101 treadmill has power coming in from the power outlet but when I plug in the key it does not start. Please help. Is there a battery on the key?
no there isn't, in fact the key is a magnet plate mechanism but you should try attacking the problem by first checking the fuse which is located at the head end of the machine. If that doesn't work then remove the motor cover and get a qualified electrician/technician to check the circuit board for any possible faults.
hope this helps
Apr 07, 2011 | Horizon Fitness Horizon T101 9 Program...
Setup didnot find hard disk
Either you are trying to install XP on a SATA disk - in that case you will need the driver
http://drivers.softpedia.com/get/Other-DRIVERS-TOOLS/Others/Acer-Aspire-T650-SATA-Driver.shtml
or (if you try to install Vista or 7) the hard disk is dead, replace it.
Apr 25, 2010 | Acer Aspire T650 (AST650UC3601) PC Desktop
Serious Prob
Try switching out the power supply.
Apr 18, 2010 | Acer Aspire T650 PC Desktop
Horizon Elliptical CSE4.6 all of the sudden won't turn on.
I don't have the solution, but also have the same problem. Have you solved this?
Aug 29, 2009 | Horizon Exercise & Fitness
Lost remote
Searching online I found a web site that you may order a replacement remote, however this web site no longer carries the T650-DR remote but they do carry a substitute.
http://remotes.com/remotes/servlet/rs?a=gmi&uuid=A12145901412461&smodel=T650DR&brand_pn=TRUTECH_T650DR
if the link does not work, go to http://remotes.com and in the top left search for T650-DR to find the replacement. Hope this helps, post back.
Jun 27, 2008 | TruTech T650-DR DVD Recorder
I need the 3-digit setup Code for Trutech T650-DR DVD
Note: In order for you to watch your TV your TruTech T650-DR must be on. Not shure what you mean by code? but setup go,s like this.
Out DISHNET to in on your Trutech T650-DR
Out TruTech T650-DR to in TV Note: the name of the input on your TV video 1 or video 2.
Just like your DISHNET you need to be on Ch 3 or 4 what ever is open.
turn on your DISHNET and your Trutech T650-DR Do you see a Trutech logo on your TV?
If yes, Keep pressing the source Button on your Trutech T650-DR remote Tell you have a TV Ch. then press the return button.
use your DISHNET remote to watch your tv.
thats it hope I could help.
Jan 31, 2008 | TruTech T650-DR DVD Recorder
Horizon T202 Treadmill Logo
56 people viewed this question
Top Horizon Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Matt Olenzek
Matt Olenzek
Trevor Turner
Are you a Horizon Exercise and Fitnes Expert? Answer questions, earn points and help others
