Question about Cameras
Sd card problem
Ive got a crayola camcorder and put in a sd cards and saying its locked
    New Friend:
  • 13 Answers
Does your sd card have a little locking slide on it? If so, slide it to the unlock position
Posted on Jan 03, 2014
Doodad
  • 64 Answers
SOURCE: locked memory card
There is a tiny switch located on the side of the memory card, might even say lock on it or beside it. Just flick the switch opposite of the way it is now and it should work fine after that. There might even be a small arrow showing which way to switch it. The reason for the lock button is "just" for this, so you don't accidentally erase some wanted pictures or someone else.
Posted on Jan 06, 2008
t00nz
  • 4738 Answers
SOURCE: Camera says SD Card is locked but card is open;
First I know you've said you've checked the card's slide switch, but just want to restate this first for others with the same problem who may not know of this switch.
Check to make sure that you didn't accidentally place the tiny locking slide switch on the side of your SD card in the "locked" downward position. The correct "unlocked" position should be slid up toward the direction of the connectors.
If you've tried this, and it's still showing locked, it's likely that the locking switch inside the camera's card slot is stuck. If you look inside the slot on the side of the slot where the SD card slide switch would be, you'll see a glint of gold color on the side. This is the camera's lock/unlock switch. The other glint's of gold that you may see at the far end of the slot are the reader's connectors (ignore those).
Somehow, the locking switch is making contact and has become stuck in the locked position. With a plastic toothpick, or other skinny NON-METALLIC item, tap against this switch to see if you can jar open the contact to its normal unlocked position. Also try blowing compressed air at it, as some gunk may have worked its way in there, jamming it closed. Occasionally, reinsert the SD card to see if the issue has been corrected.
If repeated tries fail, it may be time to consider opening the camera to force open this switch (not recommended unless you have some familiarity with electronics). In this case please see the following (xscrewdriver, hope you don't mind me referencing your blog):
http://www.myfixtips.com/blog/digital-camera/how-to-fix-a-%e2%80%98card-locked%e2%80%99-problem-125.htm
Posted on Jul 11, 2009
  • 3 Answers
SOURCE: new sd card says full
Check and make sure the SD card is in all the way, it should make a clicking sound when it's in all the way. I had this same problem with my Vivicam 8025. Hope this helps!
Posted on Dec 26, 2009
Testimonial: "you are right, thank you so much!"
angelo_mlc
  • 1035 Answers
SOURCE: SD card locked
The lock switch on the SD card looks like a bit of plastic without any electronics. A bit like the write-protect tab on a 3.5" FDD.
So there must be a sensor in the reader / camera which detects the position of the switch. Maybe there is dirt in the sensor. The best way to check would be to try another SD card, but you could try blowing out any possible dirt and see if that fixes the problem. Can the camera write to the SD card?
Try moving the switch to lock and unlock status.
Posted on Apr 07, 2010
SOURCE: SD HD card won't format
This camera only works with standard SD cards with a max of 2 GB
Posted on Nov 14, 2010
I put my sd card in and it says please plug out card what does that mean and now the red light stays on
How to Format MicroSD card of SJ4000 sport camera ...
? 2:22
https://www.youtube.com/watch?v=xVZUrKz2wSk
Oct 11, 2014 - Uploaded by furulevi
How to Format MicroSD card of SJ4000 sport camera. furulevi .... 64 128 GB MICRO SD CARD IN SJCAM ...
What does "please plug out card"mean? - Fixya
www.fixya.com/support/t17649043-please_plug_out_card_mean
Apr 12, 2013 - When camera is turned on it says "please plug out card" What does that mean? ... put in a micro SD card and turned it on and it saying please plug out card what does that ... What does it mean if my camera says "card locked"?
Jazz JDC77 saying please plug card out means - Fixya
www.fixya.com/.../t23705480-jazz_jdc77_saying_please_plug_card_out
Mar 2, 2014 - jazz JDC77 saying please plug card out means Just bought this ... SOURCE: I have a new Jazz DV151 camcorder and the memory card says full ... I bought an sd micro chip for my jazz dv151 camcorder, but everytime i put ..
Dec 21, 2015 | Cameras
My sony xpera x8 keeps saying sd card removed insert new one, ive put new one in formated and restore to factory setting but the handset still says removed sd card
try connecting your phone to a pc and see if the icon of the sd card is there or connecting your sd card to a pc and formating it
Nov 22, 2012 | Sony Ericsson XPERIA X8 Cell Phone
How do i fix a sd card for my camera,it says sd card protected when you put in camera
SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Nov 13, 2012 | Sanyo Xacti Digital Camcorder
My VPC-E760 keeps saying card is locked but the sd card is not locked
For the card locked, make sure that you are using a 2GB or smaller card. The E760 can not use 4GB or larger SDHC cards. 2GB cards can still be purchased on Amazon if your local store no longer carries them. If you are using 2GB, then here are some more tips for card locked.
For the "lens error", see this article for tips and steps that might help you repair it.
Apr 11, 2012 | Sanyo VPC-E760 Digital Camera
Insertion of sd card into crayola camera model 25070n
Use a screwdriver to remove the battery cover on the bottom of the camera. You'll see a slot running lengthwise, between the batteries. The card goes in contacts first, the notched corner toward the single battery.
Dec 28, 2011 | Crayola 2.1 MP Digital Camera Scrapbooking...
I put in a sd memory card from my laptob but, it says no card when I tried to record.
you need to make sure that the SD card is compatible with the camcorder. Some camcorders can only read SD cards, and not SDHC cards.
Hope this helps!
Tom
Jul 22, 2011 | Jazz DV151 Camcorder
My jazz dv152 keep on saying card locked what do i do
I had the same problem. Check the SD card. There is a small slide button on the side of the SD card to lock or unlock it. On the Toshiba 2GB SD card the lock is yellow.
Jun 26, 2011 | Jazz DV152 Camcorder
Manual for GZ-MG21U says any SanDisk would work with this camcorder but we got a SanDisk that says SDHC Card but when I insert it and click menu button nothing comes up.
Make sure that the card is not locked. There is a little switch that slides on the card to write protect information on it from accidental deletion. If the card is not locked, it may need to be formatted. I'm not sure if your particular camcorder has that ability or not. If not use a card reader on a computer to format it. It may be possible that your camcorder will not accept an SDHC card. It may only take a SD memory card. The HC stands for high capacity and it may not be compatible, so you may need an SD memory card not the SDHC one. I hope this helps and good luck!
Dec 03, 2009 | JVC Everio GZ-MG21 Camcorder
Help!
The little lock lever on the side of the card is too long and telling the camera its inwrite protect mode try another brand of card ozdigiman
Feb 04, 2007 | Aiptek PocketT DV3300 Camcorder
Cameras Logo
21 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
