My wd passport permission changed
My wd passport suddenly changed it's permission to read only. i have been able to read & write on my passport until my computer suddenly shutdown. Now it is saying that I can only read. How can I fix this?
  • 28 Answers
What OS are you running?
Posted on Jan 03, 2014
Testimonial: "os lion i believe"
SOURCE: dropped a WD passport drive, now it won't load. HELP!
Unfortunately, these drives are not made to be dropped.
It sounds like it was damaged by the drop which could have rendered the read/write heads inoperable or mis-aligned.
Contact Western Digital for a warranty replacement.
Posted on Apr 29, 2008
kim_cu
  • 70 Answers
SOURCE: wd passport
I would suggest an externally AC powered USB hub. Try the D-Link DUB-H4 High Speed USB 2.0 4-Port Hub. Read the reviews for any other hub you might choose.
Posted on Nov 30, 2008
SOURCE: My PC is not recognizing my WD Passport 120GB USB external drive.
I had the same issue. Its not a power issue because it shows up in device manager. Heres what I did.
Right-click on my computer and click Manage>Disk Management
Your drive should show up there. Right-click on it. If explore is not grayed out, assign a drive letter to it and you should then be bale to see it in my computer.
In my case explore was grayed out. I had to click on the option to format the drive. After re-formatting the passport explore was available. I then assigned a drive letter to it and I have access again.
I guess somehow using it on multiple computers srcewed up the file-system on it. I was using it between windows and linux.
This fixed my problem.
Posted on Jan 02, 2009
SOURCE: Getting an old Dell Dimension to recognize a WD Passport
In the end, I assigned a different drive letter to the device and it worked.
There's a lot of info out there on how to assign a letter. Here's one link:
http://lifehacker.com/software/windows/change-windows-drive-letters-167525.php
Posted on Feb 18, 2009
nclark557
  • 15 Answers
SOURCE: WD is suddenly unreadable by my computer!
go into my computer it should be there
Posted on Jul 28, 2009
I am begging someone to help me PLEASE.I have WD Passport Ultra, I ACCIDENTALLY removed access to 'everyone' in Security.Then Passport turned to NTFS and is now 'Local File F:.Help how do I repair?
First off don't freak your data is still there. If you were to plug that drive into a Linux computer you simply copy all the data. Anyhow in windows it sounds like you just need to take back ownership of the drive. so right click on the drive in Windows then Properties click on the Security Tab and hit that Advanced button. Then click on the Owner tab and click on edit. Then click on Other users or groups and add your user back. and put a check in the Replace owner on subcontainers and objects. I think that will do the trick.
Aug 16, 2015 | Western Digital WD My Passport Ultra...
Permission reset
Login with Administrator account on Windows (Root account on Linux) connect the WD passport, access the files / change the permissions.
Nov 14, 2013 | Western Digital Computers & Internet
Wd will not trasnfer files read only
Read only is a file attribute. There is read and modify, and full control. You would have to change the attribute if you have the right permissions (administrator). To change the permissions you would have to right click on the file, go to the security tab on top and change what is allowed.
Aug 27, 2013 | Western Digital Passport Computers &...
ERRO 8072
This is usually a permission error.
Go to the drive on desktop
right click and get info.
If you set permission and same thing set in safe mode
restart. hold shift key @chime and not before.
you set your permissions there.
Apr 15, 2013 | Western Digital 320GB My Passport Studio...
WD Passport write protection removal
click start click to open on my computer you should see your usb drive E: right click select properties there will be an array of options
select the sharing tab option then advanced sharing make sure you have a tick in the share this folder box
then click permissions make sure you have all 3 boxes ticked full control changes and read in windows 7
click start control panel user accounts click on the administrators account if you have made one or you will have to create one in windows XP
click start right click on my computer select open
Right click the icon of your usb drive (It should be E:/ or something)
Click Properties in the menu that comes up
Click the Sharing tab
Click permissions
And finally, click Allow next to Full Control.
hope it helps
Apr 14, 2012 | Western Digital My Passport Essential...
Trying to backup to my WD passport, get a message "don't have permission to save to this location, contact administrator to get permission". there are already saved items on the same drive. why I...
Are you dragging and dropping files from the WD passport to a folder on your computer? If so which folder? It may be that you are trying to copy the files into a Windows system directory.
Try dragging and dropping the files to a folder on your Desktop or under My Documents.
Please leave feedback for this solution, thanks.
Mar 08, 2011 | Computers & Internet
My wd passport is set to read only under sharing and permissions how do i fix that?
Is this a Windows, Mac, or Linux / Unix system?
Sometimes you need to uninstall the drivers and reinstall, reboot and all is OK (i've seen this in Win7).
Try to check WD's forum's for some info specific to your passport drive.
Nov 30, 2010 | Western Digital Passport WDXML800UE...
Hi. I have WD Passport Esential 500 Gb. When I plug the device, i can see it in My Computer like drive G:. There I see my folders and subfolders, also the files, but when i try to open some of them i have...
To resolve this issue, follow these steps:
  1. Make sure you have the necessary NTFS file system permissions:
    1. In Windows NT Explorer, right-click the file, and then click Properties.
    2. On the Security tab, click Permissions.
    3. In the Type Of Access box, click Change.
  2. If your permissions are correct but you still cannot gain access to the file, use Systems Internals' Handle utility to troubleshoot the issue with this file. The Handles utility lists information about open handles and files. To obtain this utility, download it from the following Systems Internals Web site: http://technet.microsoft.com/en-us/sysinternals/bb896655.aspx
Nov 09, 2010 | Western Digital Passport WDXML800UE...
WD Passport not recognized
I added my WD Passport 80 GB it was seen in My Computer one day then i tried it again and it doesn't appear it on (humming and the blue lights on to) but still no WD Passport (F:\Removable disk) please help
Jun 18, 2009 | Western Digital Passport WDXML800UE...
My PC is not recognizing my WD Passport 120GB USB external drive. I used just few days ago and connected the usb cable to my computer and the WD Passport drive and not recognized on my 2 laptop and 2 other...
I have the 80GB WD passport and it suddenly stopped working one day.  The unit lights up but nothing else.  Finally I cracked the case open and found, as I suspected, that the drive is simply a SATA laptop drive with a SATA-to-USB conversion card built in.  I suspected that the card was **** so I disconnected it and used a USB hard drive adapter (http://www.tigerdirect.com/applications/category/category_slc.asp?CatId=3770&name=USB_Hard_Drive_Adapter) and I can read/write to the drive just fine.  Best part is that the adapter I use has its own power supply so I'm not pulling juice through the USB cable for a SATA drive.
Even though mine "works" again I don't recommend these drives to anyone.  They're just not sturdy enough or well designed.
Sep 09, 2008 | Western Digital Passport WDXML800UE...
Computers & Internet Logo
155 people viewed this question
David Payne
David Payne
