Question about Microwave Ovens
Surpresso s60 error 2
All digital temp/time settings. 2 does nothing while 1 - 0 give an error. There is no letter or number error displayed, just "error." Won't power on.
More than likely the control panel PCB is defective, it is most likely cheaper to just purchase a new oven.
Sep 20, 2016 | Microwave Ovens
Why does it display error 2 after five seconds?
What is the model? On this link for their brand error 2 means temperature higher than expected inside the oven or the temperature sensor is not working right.
Smeg SA987CX Installation And Operating Instructions Manual To Stop The...
Nov 26, 2015 | Microwave Ovens
E 2 ERROR IN SAMSUNG MICROWAVE
E2 is the error code indicating a jammed key
see the diagram and replace.
Feb 07, 2013 | Samsung Microwave Ovens
I have lost my user manual for my Siemens surpresso s 40 . Where can I downloud one ?
You can download it from here.
http://www.siemens-brand.info/siemens-surpresso-s40-manual.html
Jul 20, 2011 | Microwave Ovens
Shows error 2
If you are using a Kenmore (or similar), "Error 2" is most likely a warning that your microwave hasn't been plugged in long enough to begin cooking with it. Press "Clear" and wait a few minutes (five to ten), then try again, and it should work.
Jun 17, 2011 | Microwave Ovens
Getting an error F-9
Reason for F-9 error code:
1. Door motor failure/jammed. Latch motor switch failure.
2. Control software failure.
3. Wiring problem
Solution:
1. Press CLEAR key
2. If CLEAR key does not eliminate the problem, turn power off for 30 seconds, then turn power on.
If this still does not correct the problem the wiring of the Lock Motor, Lock switches A, Door switch circuits and main control panel will need to be check and would require a professional service technician.
Hope this helps.
Shane
Feb 01, 2011 | Microwave Ovens
Will not start making coffee push start after 30 second message on screen err2 model kcm5340bo gerald larsen 1-630-323-3112
This is to do with an error in the warming plate function. You may be able to cure this error by completely unplugging the coffee maker from the mains lead and then plugging it back in and trying to brew. If this does not help I would suggest trying to contact the manufacturer to see if it is still under warranty.
Hope this helps and thank you for usinf FixYa
Aug 30, 2010 | Microwave Ovens
Bosch micro wave error code h95
How to deal with error h95 code?
Mar 28, 2009 | Bosch Microwave Ovens
ERROR CODE E 63 COMES ON AFTER 2 MINUTES ON SAMSUNG MICROWAVE
Some models are equipped with a sensor that can automatically adjust the oven's heating time based on the amount of steam in the oven.  If your microwave is displaying E1, E4, or E5, there may be an issue with the gas sensor. For an E1 error, press the Cancel button and check on the food.
If the message is either ERROR or E-6, it indicates a mechanical fault.
For all error indications, try unplugging the microwave from the outlet for at least ten minutes and then plug it back in. If the error persists, the microwave may require service. Please use our ASC Locater to find your nearest Authorzied Service Center
Oct 21, 2007 | Samsung SMH7174BC Microwave Oven
I'm not finding that error code.
Does it come on 2 minutes after you plug it in?
If so, it may be a failing keypad or door switch / mount.
Of two minutes after you have been cooking?
That may indicate a bad humidity or other sensor.
Please give more detials so we can help further.
Oct 21, 2007 | Microwave Ovens
Microwave Ovens Logo
24 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
