Question about Linksys WUSB6300 USB 3.0 Wireless AC1200 Dual-Band Adapter
Can not get the driver for my network adapter to grab
I have tried many times to instal the driver for this thing. I am running windows 7 64 bit and even while selecting the correct driver from the disk I get an error message that it will not instal corectly. Does anyone have an idea as to what to do?
  • 794 Answers
Http://support.linksys.com/en-us/support/adapters/WUSB600N/download
Posted on Jan 03, 2014
Need Windows 7 driver
http://www.startech.com/Networking-IO/Adapter-Cards/PCI-Express-10-100-Dual-Profile-Ethernet-Card~PEX100S
download the drivers, use the one that is for windows vista, instead of running the driver installer that comes with the it go to the folder that called WINVISTA then go to a folder called 32 if using 32-bits or 64 if using 64 bits OS, inside that folder you will find 3 files extract then to a place you can remember. then go to control panel, device manager, look for the device that has a yellow icon click on it, click on update drivers, click on browser my computer for driver software, click browse, search for the place where you have extracted the drivers from before select the folder containing the drivers, click next and wait until windows installs the drivers.
usually a 85% of the windows vista drivers will work in windows 7.
Sep 13, 2011 | StarTech.com (PEX100S) Network Adapter
I am having installing my dynex wireles g usb adapter because it says the install driver is not compatible with windows 7 64 bit. Is there a way to install the driver?
I'd suggest installing the device drivers in the Compatibility Wizard. Remove that hardware device in Device Manager, right-click on the driver executable/installer file and select the Compatibility tab; click the checkbox before Run this program in Compatibility mode for option and select Windows Vista in the list-down box; then try installing the device driver. In addition, you can use the Windows XP driver for testing.
If the problem still persists, please understand that Windows 7 is a new operating system (only the beta version) and whole driverstore has been reprogrammed; some old driver is not compatible with new OS. I suggest that you should wait for another period of time till the retail version is released and push the vendor company to upgrade their device driver. Thanks for your time and understanding!
Good Luck!
Feb 28, 2011 | Dynex Wireless-G USB 2.0 Network Adapter
I am trying to install F5D7051 Wireless G Plus USB Adapter on windows 7 but i have several problems .i tried to install the drivers from the cd that came with the package but i couldnt run the program.i...
You don't actually need a driver to set it up. Just plug it into your network, then browse to its URL (likely 192.168.1.1, but could be 192.168.0.1, or 192.168.2.1). Then just follow the prompts to configure it. Hope that helps.
Feb 20, 2011 | Belkin Wireless G Plus MIMO (F5D9230-4)...
F5d5050 Belkin USB 10/100 Ethernet Adaptor - Does it work with Windows 7 64 bit OS? I have spent hours trying to install a Swann and a Digitech product but none seem to work with the above OS. Any...
You cannot install this adapter in a Win 7 computer because the drivers are not compatible with Win 7.
So far Belkin haven't updated the drivers for win 7 OS. The latest drivers for this adapter is compatible only with
" Windows 98SE, Windows Me, Windows 2000, Windows XP 32-bit, Windows Vista 32-bit "
Click here to see the belkin compatible drivers in the website.
With Regards,
Prema.
Jan 06, 2011 | Belkin Ethernet Adapter F5D5050 Network...
Hello well i just got a linksys wusb11 2.6 adapter and i tried installing it on my laptop with windows 7 and i downloaded the driver from linksys and it installed but it still doesnt work
I just had this problem with the same adapter when trying to set up my mom's new computer. What happens is the older adapters don't have drivers compatible with a 64bit operating system (generally found in computers with 4 or more gigs of ram).
In order to check what kind of Opperating system you have go to control panel-->system and security-->system and there will be your specifications go down the list until your find "system type" and that will say either 32 bit operating system or 64 bit operating system.
If you have a 64bit system the best thing to do is to go buy a new adapter and make sure you can get 64 bit drivers for it.
Or what I did was. I got a long network conected it to the router which is faster then wireless.
Oct 22, 2010 | Linksys WUSB11 802.11b Wireless Adapter
Cant get my belkin network adapter to work on windows 7 because it says there are no drivers installed for this device
This Will work in most Cases
Download the Drivers for Vista 64 Bit from
www.belkin.com/support
Step 1 : Right Click on the EXE File and Click properties
Step 2 : Click on the Compatibility tab
Step 3 : Select run this program in compatibility mode for Windows Vista SP1
Step 4 : Click Apply
Now try installing the Drivers
Dec 26, 2009 | Belkin High-Speed Mode Wireless G Notebook...
Need working Windows 7 driver for Linksys WUSB54G V.1.0 Adapter
This driver should work with Vista, and based on the FAQ it should work with 64-bit although it wasn't designed for the 64-bit OS.
http://downloads.linksysbycisco.com/downloads/WUSB54G_dr,0.exe
If the link doesn't work, let me know. I'll direct you to the download page to retrieve the driver.
Mar 23, 2009 | Linksys WUSB54GC 802.11g/b Wireless...
Linksys WUSB6300 USB 3.0 Wireless AC1200 Dual-Band Adapter Logo
496 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
