Question about HP dc7700 PC Desktop
Monitor wont turn on. - HP dc7700 PC Desktop
Monitor wont power off
The blue light probably simply means that the computer is not turned on, but the monitor is. Just turn off the monitor, and the blue light should go away.
Mar 16, 2014 | Computers & Internet
My monitor hp w1858 wont turn on
Your monitor may have developed a power supply problem since being refurbished
Jul 04, 2013 | HP Refurbished 18.5" Widescreen Monitor...
AL 1706 troubleshouting monitor wont turn on green
If your monitor shows a yellow light and it won't turn green, the problem most likely lies with the computer. If your computer is not sending a signal to the monitor, then you have a computer problem. One way to test this is to turn the monitor off and the computer off, too.
Turn the monitor on and if it is working, it should display a message telling you that there is no signal. If you see that message, you can assume the monitor is working. If you do see it, now turn on the computer and see if the message changes.
If you turn the monitor on and you get no message, you can assume the problem lies with the monitor itself.
If you have access to another monitor, hook that one up to test the computer output.
You can now either get the monitor fixed or the computer fixed, depending on which one is bad.
May 31, 2011 | Acer Computers & Internet
Monitor wont come out of sleep mode
One possiblility will be the failing power supply due to bad caps (leaking/bulging tops). You can take a look inside first before making the decison to buy a new one or not.
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
May 16, 2010 | HP Q1859 18 inch Monitor
Dell computer monitor wont come on when I turn
When you turn on most dell monitors they come on with a yellow light, then turn green when the monitor and video source synch. If your light is not turning from yellow to green, your monitor is either dead or not getting a signal from the video source it's plugged into. Verify in your BIOS settings that you have selected to output video through an installed card and not from the motherboard source. If the BIOS settings are correct, your monitor has died. If the light is turning green after you turn the computer on, press the menu button on the monitor and adjust the brightness/contrast until you have a picture. If you don't see anything when the menu button is pressed, then again your monitor is likely dead.
Jan 04, 2010 | Computers & Internet
Acer AL1916 monitor wont turn on
normally along the number keys are cymbals, you must look for one that is a wireless sign, then i think you must press a key with this key to enable it, normally its a fn key
Nov 29, 2009 | Acer AL1916W 19" LCD Monitor
Monitor times out and wont come back on.
Try this settings:
  • Click on Start | Control Panel | Power Options.
  • In the Power Option properties window, click on the Power Schemes Tab
  • Set the Turn off Monitor/ Turn off Hard Disks option when on Power (and also Battery for laptop users) to Never.
  • Now click on the Save as... button and assign a name to this power scheme... Let us call it 'Presentation' and then click on OK.
  • That's it congrats!
  • Aug 03, 2009 | Acer AL1914 19" LCD Monitor
    My screen wont turn on
    Hiya, have you tried plugging in an external monitor to the Blue VGA port of the laptop ?
    If so, do you get any display then ?
    Hint : you need to plug in the external display 1st, then turn on the laptop. If the External monitor doesn't come on, then you may need to press the Function key on the laptop & the F4 key (Or whichever shows a monitor logo) to get the laptop to switch to external monitor.
    If you CAN get display on the external monitor then the problem could either be that the Invertor for your laptop screen has blown, or, the backlight for your Laptop Screen has broken, or the Laptop screen itself has gone faulty. In rare cases, the cable from the Laptop Motherboard to the screen may be faulty or have come away form the connector on either end.
    Hope this helps.
    Mar 19, 2009 | HP Compaq Presario F750US
    The monitor light does not turn on!
    Connect another external working monitor to the computer, if the other works then get lamps and inverter replaced.
    May 25, 2008 | ViewSonic VA520 15" Flat Panel LCD Monitor
    Viewsonic VA2012w Wont go into standby with computer.
    turns out it may be a heating problem. cut a few extra vent holes in it and seems to be fine.
    Sep 08, 2007 | ViewSonic VA2012WB Monitor
    HP dc7700 PC Desktop Logo
    78 people viewed this question
    Top HP Computers & Internet Experts
    Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
