Question about Whirlpool LER4634PQ Electric Dryer
My heating element will come on but not stay on...do I need a new element or thermostat?
  • 35 Answers
This is a general Ideal,and may or may not be your problem.Its quite often a clog in the exhaust will make an element cycle off to quickly.Not enough air moves through the dryer,and it overheats.Its a safety feature that keeps your clothes from catching fire.You can check the exhaust for air flow,but sometimes a partial blockage is enough to trip the heater off.so you have to really pull the hose off,and look up into the unit,and the hose.I had to tear a unit almost completely apart one time to find the clog.good luck,I hope that's the problem.
Posted on May 22, 2009
Dryer won't shift to cool down cycle. Stays hot to the end of the drying cycle.
You need a new high temp heat thermostat. Its located on the housing of the heating element.
May 06, 2016 | Dryers
Belling cookcenter oven over heats and light stays on
It sounds like the people who changed the elements did not connect them to the correct wires. The thermostat seems to have no effect on the elements, and the light switch seems to have no effect on the light, explain this to them and that you think they fitted the elements directly onto the power input to the device, instead of the correct connections.
Dec 14, 2013 | Ovens
Washing machine does not heat up water
It is Your element or thermostat that is gone. You can get a reading of your element with a multimeter, you are looking for a reading of between 20 and 30 ohms. If you are unsure how to do this, i suggest getting a new element.(the thermostat is part of the element also) There are many useful videos on the internet to show you how to do it. *Please be sure to unplug your appliance before working on it.Good luck to you.
Jan 24, 2013 | Washing Machines
Heating element replaced. Worked one load and back or dryer seemed very hot. Turned off and later ran on low. Next load no heat.
Hi.
There is either a problem with the thermostats that turn off the heating element, or the heating element is plugged (elements has contact to ground and stays always on).
Heating element and thermostats are tested reading Ohms with a multimeter set at Rx1. If the circuit is open (Ohms stay infinite), then the part is defective.
If the machine overheated, then the element may be gone again. Test reading Ohms.
Also replace the thermostats (there should be two or three of them), unless the element had a contact, the most common cause for overheating is a shorted thermostat.
Aug 04, 2010 | EuroTech EDC158 Electric Dryer
Dryer does not get hot, only cold air
Parts that can cause no heat are thermal fuse, heating element, thermostat and electronic control.
The thermal fuse can be tested using a multimeter. The multimeter set on Ohms, at Rx1 must be used on element contacts, to read impedance. If the fuse is good, it will read zero or low impedance.
he heating element is tested in the same way, only the element contacts must be disconnected before reading impdance.
To test thermostat better removing parts from the appliance, after disconnecting power. To test element you will need to at least disconnect its wiring.
If the element is good it must return some impedance that is not infinity. If the element returns open (infinity), then element is bad.
Same for the thermostat, only difference the thermostat must return low or no impedance (zero) at room. If impedance stays infinite (open), then the thermostat is faulty.
If the machine has separate thermostat and high limit (they are same thing on dryers), both thermostats must be tested.
If there is some cooling, but cooling is poor, check also lint filter, air duct and fan.
All testing and repair must be done by a trained person.
To get a technician or to find parts contact the number listed on the user manual.
Dec 17, 2009 | Maytag Dryers
My Bunn Pour-Omatic coffee maker (White) Heat up
Most likely suspect is the thermostat, however you might want to check the limit switch also(located on boiler between elements).
Jun 18, 2009 | Bunn Pour-Omatic Coffeemaker, 10 Cup White
Burner heating element stays on high-cannot
there is a thermostat element beside every burner
i think it need to be changed.
thank you
Jun 08, 2009 | Jenn-Air JES9860 Electric Kitchen Range
Continually running/heating
Coffeemakers have two heating elements: a brew element and a keep-warm element. When the water reservoir has run empty, a thermostat switches power from the brew element to the keep-warm element.
The keep-warm element will cause the thermostat to stay in this condition until more water is added [or power is cut off] which will cool it down to switch back.
However, if the keep-warm element has quit working, the thermostat may be reactivating the brew element. With no water in the reservoir, the brew element will heat up till the thermostat trips again, then cool down, etc. This cycle will repeat until power is switched off.
Mar 31, 2008 | Keurig B50 Coffee Maker
Kenmore electric stove heating element how to replace
A replacement is usually around $40. There are usually 2 screws holding the element in the back of the stove. Turn off the power and remove the element. There are usually only 2 wires. It really doesn't matter which goes where. Install the new element and see if it will shut off when oven reachers temp. If it continues to heat, there is another piece that needs to be replaced. If there is a contactor or relay replace it, If not the thermostat needs to be replaced. Sometimes when the element burns out it shorts to the ground and fuses the contacts forcing the element to stay on. Sometimes you actually have to turn off the power to the stove.
Nov 26, 2007 | Equipex PZ-330 Electric Single Oven
Whirlpool LER4634PQ Electric Dryer Logo
70 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
