Question about Panasonic PV-C2020 20 in. Combo
Wall mount holes for the Sylvania LC370SC8S
I just bought two 37"Sylvania LC370SC8S tv's and seperate wall mount brackets but when we open the boxes there were no instructions on what holes should be used to mount the bracket to the TV. We call Sylvania customer support and they said that they will not give any advise on mounting their TV's to a wall mount as they do not want to be held liable if it were to fall off of the wall. This is crazy! When you buy a picture frame (any size) they provide a way to mount & hand it on the wall or set it on a shelf. You don't see their companies getting suid because it fell off the wall. I understand that a picture frame cost less than a plasma but you get my point right?
Any advise would be helpful
SOURCE: Mounting the bracket to the tv?
Hey, I had the same problem and finally found this solution (the four mounting holes are covered by plastic caps as I thought ... just wanted to be sure). Hop this helps:
http://www.avsforum.com/avs-vb/showthread.php?t=1040337
Posted on Dec 27, 2008
SOURCE: Sylvania 37-Inch LCD/DVD combo HDTV remote code for Scientific Atlanta 8003
You can find the sylvania 37" LCD/DVD COMBO at Sam's club for 597.00 it is a special item for sams club. If you go to sams club on line you cna locate what sams club has this tv in stock but hurry they are going fast and there model number is LD370SC8. I am not sure where you are located but please start your search now and if you do not have a sams culb card you can get the lowest priced membership possible and due to the low cost the price of a membership is worth it.
I hope I have helped?
Noreen
Posted on Feb 15, 2009
pgh_pa_guy
  • 2992 Answers
SOURCE: What is the screw hole size in back of tv
The screw holes are metric. The set is supplied with M5x25 screws to attach the pedestal, so the wall mount screws will be in that same range.
Posted on Mar 01, 2009
  • 11 Answers
SOURCE: how do i mount the brackets on the back of the tv
There is a good guide for tv wall mounting/brackets, see it here:
http://www.mountright.com/articles/
Posted on Sep 14, 2009
caroldon
  • 17130 Answers
SOURCE: which holes in the rear
These are marked and are open to be bolted to the brackets. please check the link below:
TV Wall brackets: http://www.regencyproducts.co.uk/
Posted on Jul 07, 2011
How can I put. On my led tv on the wall
You need to purchase a wall bracket for your TV. There are several types on the market. Make sure the mountind holes on the TV line up with the wall bracket mounting holes and it can support the weight of your TV.
Google search for a wall mounting bracket for your model TV.
Nov 21, 2011 | Televison & Video
Which holes in the rear of the tv are the wall mounting bracket holes?
Jul 07, 2011 | Panasonic Televison & Video
Can i wall mount my 32" LC320SS8 sylvania tv by the 4 screw holes in the back of tv
Yes, with a mounting kit. A plate screws to the TV using those holes, then attaches to another plate that's attached to the wall.
Jul 06, 2011 | Sylvania LC320SS8 32 in. LCD Television
Best wall mount for sylvania 6842thg plasma
To make it simple: Mounts go by the size of the TV.
You have the choice to get a standard mount that can only swing or a mount that can swing and tilt or even extend. Plasma TVs are a bit heavier, than LCDs therefore, you need a solid mount. There are wall mounts and ceiling mounts. Mounts can be purchased from Home Depot, Lowe's and best buy, they can also be bought on line. If you buy it from a local store and does not fit, you can take it back the next day, an option you wont have if you buy online.
Good luck
N Sabre
Nov 08, 2009 | Sylvania 6842PE 42 in. HD-Ready Plasma...
Tryiny to put my Akai LCT3201AD TV on the wall
For a set this size, there should be at least 4 mounting holes for a wall bracket. Please note that wall mounting is an option so the holes may be covered by plastic caps to hide the holes. These holes should be in a box shape around 1 foot wide or so.
Dan
Apr 10, 2009 | Akai LCT3201AD 32 in. LCD Television
What screw holes are used for wall mounting a Sylvania 37 in LCD
the tv only weighs 55 lbs yes those are the holes 4 of them your bracket may have other screws if the bracket is thick
Mar 15, 2009 | Sylvania LD370SS8 37 in. LCD Television
Looking for wall mount for MLTD2622 26" tv
I had similiar issue with 32 inch...bracket required an adapter which I found through Best Buy. Check out Sanus.com They should give you discription of what you need and tell you where to get it. Adapter was very cheap ($19.00 or so). It is essentially two metal bars that bolt to regular wall mount, the bars will line up with bolt holes on TV.
Dec 13, 2008 | Memorex MLTD2622 26 in. LCD TV
Cannot figure out how to remove stand so I can mount TV on wall
did you figure this out? I only ask because I need the stand for my TV. Could you sell me yours?
Thanks
Anthony
amsaxo@yahoo.com
Dec 02, 2008 | Sylvania 6620LDG 20 in. EDTV-Ready LCD...
Hannspree Television/Wall Bracket
If there are six threaded holes in the rear of your TV and the bracket supplied has only four holes I would bet that the weight requires a heavier bracket.
Apr 03, 2017 | Hannspree Televison & Video
How do i attach a Wall Mount to the TV?
Hi, Ok, great.Look at the back panel and you can see four holes spaced 4" between the top and bottom, and 16" from side to side. these are for universal mount. http://www.bestbuyplasma.com/Plasma/tvmounts_land.asp I think this clears your problem regards sreejith "Please use caution if wall mounting this product. Follow all directions from the manufacturer of the wall mount and be sure to securely fasten the product to the mount. While the TV can be wall mounted, improper wall installation may void the warranty."
Jul 16, 2007 | Akai LCT3285TA 32 in. LCD Television
Panasonic PV-C2020 20 in. Combo Logo
125 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
