Tempstar nugk125DK06 won't light. Changed from gas to lp and now won't light. Is there a way to bleed the valve?
  • dustin358 Jan 05, 2014
    Hi Rachel Mitchell, I want to help you with your problem, but I need more information from you. Can you please add details in the comment box? did you change the spring in the valve that came with conversion kit, what about the orifices as well? you may just have air in the lines it can take a while to get all the air through the small outlets.
  • 30 Answers
Keep letting it cycle through eventually the gas will make it through the small outlets. You will likely need to reset power. It took me about 10 start cycles to bleed one two days ago
Posted on Jan 05, 2014
Is a 650 delta gas valve for natural gas be used with lp
no.
propane burns much hotter than natural gas, and has higher pressure
gas valve and burner and orifice must be changed to switch between natural gas and propane
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html
Most manufacturers do not support converting gas on heater.
Gene
Sep 13, 2014 | Rheem 40 Gallon FVR NATGAS Low WATER...
Pilot light keeps going out
The thermocouple could have failed again but the gas valve could be failing as well.
Dec 30, 2013 | Blodgett Oven 1048 SINGLE LP Pizza Oven...
Bosch Confort S 13 BP tankless water heater won't ignite, It clicks but no gas going thru valve
The S 13 BP is a simple unit that does not have a pilot light. It uses electronic ignition on demand, which is what you hear clicking. If there is no gas going through and you've verified there is gas to the inlet, then it has to be the gas control valve.
Feb 01, 2013 | Bosch & Tankless LP Hot Water Heater
Won't light no gas
Is the gas supply valve open? the handle will be perpendicular the the pipe if it is on. Is your supply natural gas or LP gas. If LP make sure the tank is supplied. Any LP supplier will be able to check it out. By law they will have to check for leaks before filling the tank.
Oct 06, 2012 | Dayton (4LX430 Gas Heater
Rv fridge won't get cold when on lp gas
check for a blue flame at the burner located at the base of the boiler assembly there is a viewing port, my guess is there is no flame, check with ohm meter for continuity across the gas control valve contacts the should be about 30 ohms across it if so reconnect the wires leading to the valve, set meter to volts , view the meter and have an assistant to switch the fridge on there should be a voltage appearing at the contacts this is only momentarily if the flame dos not light if there is no voltage your control board needs to be replaced if there is a voltage than the gas valve is faulty or gas supply is not present
May 19, 2012 | Car Audio & Video
Just bought a new Jenn-Air grill and cant get the temp past 250. Any ideas what i am doing wrong?
First, check that all the gas lines and flame bars are clear of any 'things' or bugs. I had a similar problem with a Webber grill and found out my problem was with the gas bottle. The new Overflow Protection Valve required on LP bottles can closed off or severly slow the flow of gas when the bottle is full and the valve is opened quickly. It will let enough gas flow to light the grill but won't let the fire get high enough to heat the grill up. Turn all the valves off on the grill and gas bottle. Open the gas bottle valve slowly then turn on the grill burner and try lighting it. If the flame is still very low try again or you have to let it burn at the low level until the OPV float drops down and the valve doesn't impede the gas flow. The best way to avoid this in the future is to not fill the gas bottle to the top when you have it refilled. Just ask the LP attendent to not fill it all the way.
Jun 06, 2011 | Garden
This si the second time I have had a problem when I changed tanks. It started working the first time but not this time. The tank valve is open and the pressure guage is in the green, until you tirn on...
Many newer grills have a safety feature built in where the valve will not
allow gas to flow if the burner valve is in ON position when the valve on
the tank is opened.
Try this - Shut of all valves, disconnect and then re-connect hose to tank,
turn on valve above LP tank, THEN turn on burner valve, light w/ spark or
match...
This feature can be really frustrating if you don't know it is in
operation...
Sep 06, 2010 | Brinkmann Charmglow Stainless Steel LP...
Pentair minimax 100 pool heater millivolt type wont light
You need to check your tanks and make sure that you have enough gas. The heater will need 30% or more in the tanks. If they changed the gas valve I assume that you had a natural gas valve and they replaced with a LP. If your tanks are small then you will only get a couple of days out of them. On this I would need more info. Size of tank size of pool (surface aera) wind conditions, exact model of heater.
First ck to be sure that you have enough gas and be sure to bleed the line before you start once the tanks are full. Let me know how you do. Kieran
Feb 25, 2010 | Pentair MiniMax 100 Aboveground 100,000...
Laars Lite 2 Coversion to LP Gas
Hi you will need a gas fitter to do this and set it up
Jun 02, 2009 | Lite On Laars Lite 2 Heaters: 250,000BTU...
Heating & Cooling Logo
105 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
