Question about 5704x 570.x 2-Way Security and Remote Start System with
Constant sounds coming from my truck alarm
Just bought truck got home and now truck alarm is making sound constantly, not loud like alarm but constant
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 177 Answers
Pull fuses until it goes away. Also pull relays you could hae a bad relay
Posted on Apr 30, 2014
What can cause a whining noise coming from 2003 mazda 6 engine?
That is commonly caused by a power steering pump issue, it is either low on fluid due to a leak in a hose or the pump is defective.
Oct 06, 2016 | Mazda Cars & Trucks
2008 land rover lr3 making loud meal scraping sound
from where is the sound coming from, and is it constant or intermittent?
Apr 09, 2013 | 2008 Land Rover LR3
Bought a 1992 acura vigor and found horn fuse missing. when I replaced the fuse alarm goes off and constantly sounds. how do I stop it? I've read that there's a relay somewhere under the hood
horn relay located on the right side kick panel,you will see a row of relays,if horn relay is okay, more likely your horn control pad has a short inside causing horn button contacts to stick causing horn to keep blowing.
Oct 01, 2012 | 1992 Acura Vigor
Constant beep even while driving and when i turn it off it still beeps unless i disconect the interior lighting fuse and plug it back in fuse # 8 i believe. if i leave the fuse out it makes a wierd sound...
1995 GrCher Orvis - I have now just started with the same problem. An incessent loud high pitched alarm sound. Identical fuse, ignition on/off, and ticking issues. Can start jeep, warning sounds as normal followed by incessent tone, I can remove fuse to get quiet, but then when I close the door I get the identical alarm sound, but with a slight pause. Tone. Tone, Tone, etc. I can't figure. Tore through all components of dash: to learn that the alarm seems to emminate from the transmission floor area, and is not in the instrument panel (f up #1) nor is it behind the dashboard (f up #2). I'm stuck now... Anybody got something for me? Is it a transmission warning?
May 28, 2010 | 1995 Jeep Grand Cherokee
1994 Oldsmobile Bravada - Driving - Loud Noices
Sounds like worn Constant Velocity Joints (CV Joint)
to me.
Feb 27, 2010 | 1994 Oldsmobile Bravada
Danby microwave does not heat food and makes loud constant noise
IF the noise is a sound coming from the oven area, its the megatron tube. Typically, replacing the megatron tube is more expensive than replacing wiht a new unit and a new warranty.
Nov 06, 2009 | Danby DMW112 Microwave Oven
Sliding door alarm sounds constantly
there must be a switch some where , around the door to shut it off when door shut
May 10, 2009 | Chevrolet Uplander LS Cars & Trucks
BUZZING SOUND WHEN RUNNING
It sounds as if there is something in the bottom part of the dishwasher arm (it sprays the water around the bottom of the dishwasher). I would suggest that you take out the baskets and then remove and clean all of the parts that water comes out of as well as the bottom drain. If this works or does not, I would also suggest that you run an empty load using 1/4 cup vinegar. Hope this helps!
Mar 16, 2009 | KitchenAid 24 in. KUDI01FLSS Stainless...
5704x 570.x 2-Way Security and Remote Start System with Logo
63 people viewed this question
Top Clifford Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Clifford Vehicle Part and Accessory Expert? Answer questions, earn points and help others
