Question about Singer 7442 Mechanical Sewing Machine
Nothing happens when I push the foot pedal
Machine was working fine. I stopped for a few mins then when I resumed there was power to machine but when I push the pedal nothing happens. I have checked the bobbin and top thread, needle and feet. All seem ok.
  • 86 Answers
I have a singer machine and when this happened to me, it was my foot peddle. I have the strangest foot peddle, it has a tube that is hollow and it works on air pressure. I had to buy a new peddle. turns out my cat had chewed the cord and made several holes in it.
Posted on Mar 03, 2015
    Champion:
    Habit-Forming:
  • 201 Answers
Please check the Stitch regulator & Presser foot lifter.
Posted on Jan 04, 2014
SOURCE: Hand Wheel Won't Turn
The "Bobbin stopper" is in the incorrect position. It moves from side to side in a switch like motion. In one direction, it locks up the machine. That is, you can turn the wheele backwards, but not forward.. The bobbin stopper can be found in the book that cam with the machine. In our book, it is item #9.
Posted on May 01, 2009
SOURCE: singer simple sewing machine will not sew
need needle threading instructions singer 3116 simple. pictures would help. thank you
Posted on Mar 15, 2009
  • 371 Answers
SOURCE: Machine will not pick up bobbin thread. The bobbin
Sounds like timing of hook/needle. The needle should go down, a mechanism in the bobbin area moves to sweep the top thread around to pick up the bottom thread. Suggest taking it to a service technician, preferrably one authorized to repair your brand of machine. Check website for your brand and it might list authorized dealers close to you. Good luck.
Posted on Sep 24, 2009
  • 109 Answers
SOURCE: Singer 2259 - The machine has stopped moving, the
Check to see if you have your bobbin winder on. That's usually the problem. Just push it to the left and you should be ok.
Posted on Sep 11, 2010
Obertelli
  • 3006 Answers
SOURCE: The thread is bunching up
Your problem stems from the faulty foot lever mechanism. It's coupled to the upper thread tension control which only provides tension when the presser foot is in the locked down position.
If the presser foot won't positively engage in the down position, there's no upper thread tension and the thread bunches up below. Everything else stems from there. If the needle has hit the bobbin case too frequently then the bobbin timing may also be slightly out and the needle itself will be damaged and won't pass straight through the fabric; it only takes a tiny deflection from the vertical as it passes through the workpiece for the needle to flex and hit the bobbin case.
In summary, your machine is in desperate need of repair and adjustment. You haven't stated which exact Singer model you have, but they are usually easy to get servicing manuals for or you can take the machine to a sewing machine servicing specialist. Most singer spare parts (even for 100 year old machines) are usually still available fairly cheaply from a variety of sources, just enter "Singer spares" into your search engine to find suppliers.
To prevent re-occurrence, clean the mechanism regularly and lubricate it as directed by the manufacturer using sewing machine oil. Depending on how often you use the machine, do (or have done) a more thorough service periodically to check the timing and also that all mechanism screws remain tightly fastened.
I hope that my reply has shed some light on your problem and enables you to decide what to do next. Please take a moment to rate my answer.
Posted on Sep 30, 2010
Has the fuse blown on my machine? It doesn't turn on anymore. I changed the bulb and accidentally put in a 25W instead of a max 15W and it turned on for a few mins until i started sewing and it cut.
Hello Jess
Your manual is listed below, but I don't see a fuse or a reset button at a quick glance.
However, open up the area where the bulb is and look for a reset button. Also look on the foot pedal. Plug something else into the wall outlet to verify that a breaker hasn't tripped.
Did the machine work with no bulb alight? Wondering if the bulb must be working and present for the machine to function for safety reasons?
You know there is an On/Off switch above the power cord on the back of the machine, PAGE 6, Figure 1 in the manual?
http://www.singerco.com/uploads/download/38b237687d4dcaa62be10a78bb352508437b5509.pdf
Jul 02, 2016 | Singer 2250 Tradition
Foot control on my Juki 2010 sewing machine is not working, as if there's no power reaching it at all. There is power to my machine as indicated by light coming on when main power switch turned on.
Pam, Could be a bad/broken wire, may be repairable, you should take your pedal in to be tested, if diagnosed to be bad you may have to order a new replacement pedal. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to Repair the Foot Control on Your Sewing Machine
http://www.sewingmachinesplus.com/foot-control-419451-003.php?gdftrk=gdfV210602_a_7c3285_a_7c15319_a_7cPID513
Sewing Parts Online Search
Juki Sewing Machines
Jun 09, 2016 | Juki Sewing Machines
Machine ran on when pedal when released, pedal now no longer works and machine wont sewing more than one layer of fabric without getting jammed
How are you making it run now since the pedal doesn't work?
You probably should take it to a repairman/shop. When this happens, sometimes the pedal is shorting out and it kills the pedal and you will need to buy a new pedal. When it ran by itself, it might have either gotten a piece of material or thread caught in the shuttle or it might have knocked the machine "out of time" and you will need to have it put back in time so that it will run properly again. I don't know what the prices are in your area but I would imagine that it will all run about $125. Sometimes you can get a used pedal off ebay (check to make sure that the configuration of the plug is the same). Good Luck.
Mar 12, 2015 | Janome DC3050 Computerized Sewing Machine...
Foot pedal not working
Well, you are definitely getting power from the electric plug in.
Let's do some diagnostic work. Do you hear anything when you press the foot pedal? Any hum? Did you happen to leave it in bobbin winding mode?
your machine doesn't have a "sew" button for use without the pedal. So please rotate the hand wheel toward you as you press the pedal. Did the motor take over and sew?
If you know someone with a meter... have them test the pedal. (they will place probes on/in the part that plugs in which tests for shorts, etc.) If that tests ok... then we know it's something more than the pedal and it will need servicing by a Singer Tech.
Aug 27, 2012 | SINGER 7470 Sewing Machine
My juki serger mo-634de suddenly stopped working. Lights on, wheels and parts move freely, even stitching seems to work if I turn it manually, but nothing happens when I push the pedal. No sound. ...
Hi, I have the exact same machine. it sounds like the wire from the foot pedal to the machine is broken. You would still get power from the wall to the machine to light the light, but no 'gas pedal'. You could maybe get an electrian to test the connection under the foot pedal and if the wire is damaged? or maybe the part that plugs in the machine is cracked or damaged?
Good luck! Annette
Jan 08, 2012 | Sewing Machines
My machine continues to run after i take my foot off the pedal.
Undo the foot control and take out the little square bit called a suppressor which you don't need these days anyway and it should be fine.
Jan 19, 2010 | Singer CE-200 Quantum Futura Computerized...
Bernina 830, worked fine until today... think it
there is a board inside the foot pedal that goes out sometimes you can check this by flipping the foot pedal upside down and at the top right there is a small hole where you can adjust the speed with a flat head screwdriver but be gentle it breaks easy, if its out you can take it to a bernina dealer and they might have a reapired one or they can send yours off for repair since that part is repair only
Jun 26, 2009 | Sewing Machines
Foot control has no power
I've just fixed this problem by replacingthe main capacitor in the foot pedal. I have a Bernina 830. I needed a soldering iron, and I had to buy the right capacitor, but it fixed this exact problem. Btw, a few months ago this problem initially appeared (on my machine) as an issue where the speed was either zero, or full speed). After a white it wouldn't work at all.
Aug 31, 2008 | Kenmore Drop-In Bobbin 16231 Mechanical...
Singer 7442 Mechanical Sewing Machine Logo
340 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
