Question about Gestetner Copier
Copier Only prints half the page
Just recieved a Gestetner 3222 donated to my church and it will only print half the page. Please help.
Sounds to me that the paper tray is set incorrectly. There is a dial on the back of the machine that needs to be set correctly once the paper tray guides are adjusted accordingly -particularly when running 8 1/2 x 11" (letter) size paper. It can be set to run either lengthwise, or laterally (portrait) make sure the dial is set to the proper setting on ALL trays. If the tray is set for lateral, for example, and the paper is installed lengthwise, the scanner only utilizes 8 1/2" in length rather than the full 11". Frequent jamming is also a common problem when making multiple copies, because the paper is not where the machine "expects" it to be. Also check that the LCD display reads the proper size / orientation after adjustment.
Hope this helps. Please rate solution :)
Posted on May 22, 2009
Dsm 618d
Reinstall your driver
Apr 24, 2012 | Gestetner DSm618d Copier
After installing an off brand cartridge for a Gestetner copy/fax machine, it only printed half pages and the printing was poor. They said the brand name cartridge was no longer available. please...
There are many different companies that sell compatible toner, and the quality varies greatly. You should try getting your money back from the company you bought that toner from, and find a new supplier if you can't get it from Gestetner. Premier is a company that sells compatible toner for many different machines, and they usually get pretty good reviews.
Aug 05, 2010 | Gestetner DSm620d All-In-One Laser Printer
I have a gestetner dsc460 copier. I am going to
okay your machine has the finisher option and punch option? if so when you go to print click file, then print. when your window opens for the printers select the gestetner. then choose properties. then choose printing prfeerences. then choose punch
Dec 31, 2009 | Gestetner DSc460 Copier
Smeared print on paper
I was getting a similar blur/blob down one side of the paper (with no discernable print anywhere,) but after removing and emptying the toner collection bottle my printing returned to normal. I am still working on the size mismatch issue, which seems to be prevalent in the 2300DL population.
Aug 25, 2009 | Office Equipment & Supplies
Well, I'm back to suggest another solution or 2.
After my previous solutions didn't take (we have to start with the most basic solutions, especially when i can't see the results), let's try something else.
At this point it sounds to me like a laser (optical) problem or blockage.
LIft the green handle inside the front cover as if to replace the toner bottle, and underneath you should see the end of a small peice of glass protruding. CAREFULLY slide this out. My suspicion is that there will be a film of toner, or dust built up (particularly on one end of it). Clean it with a soft tissue and slide it back in.
If this glass is not present, but you see the slot, then it has been removed, and I would then suggest that the toner/dust has carried all the way into the laser unit, and the assembly will need to be removed and cleaned -this is not something for the end user to perform.
Regardless of whether or not this solution fixes the problem, you will have arrived at a place where a technician will be required, because it has been narraoweed down to either a Drum (photoconductor) problem, transfer assembly problem, or perhaps a laser positioning problem....but I do hope it helps.
May 22, 2009 | Gestetner Copier
Line across the page
  1. Make a copy by using the platen mode and ADF.
  2. Send a print from your PC or print out the Counter list from User tools/counter button.
  3. Try printing one colour at a time - Black, Cyan, Yellow or Magenta.
If when printing, there is no line across the pages, so you need to clean the optics mirrors and exposure glass.
If the line appears in both 1 and 2 mentioned above, you have the fuser roller or drum damaged.
If the line appears in all colour prints, check the fuser or transfer belt.
If it happens only with one particular colour, check that drum unit.
Good luck and please rate me, thanks.
Feb 02, 2009 | Gestetner DSc328 Copier
Printer stops during print job
Please check if it is giving an error and read any instruction given on the display when this happens and follows accordingly.
Jan 10, 2009 | Gestetner Copier
How do you make the computer NOT print a banner page before every print on a Gestetner 1805?
Look in Control panel/Printers/gestetner/properties, then in the Advanced tab make sure that the "Separator page" feature isn't enabled.
Check if the copier/printer doesn't have that feature enabled in the copier menu.
Also check in the application from where you are printing, that it doesn't have a "Separator page" or "Brief page" print feature.
Apr 30, 2008 | Office Equipment & Supplies
471 people viewed this question
Top Gestetner Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
OfficeServiceAjnc
OfficeServiceAjnc
Are you a Gestetner Office Equipment and Supply Expert? Answer questions, earn points and help others
