On line problem
SOURCE: canon mp390 flashing alarm put in cartridge
Can you send me a copy of the set-up sheet for the Multipass 390 by e-mail? a[email protected]
SOURCE: canon mp830 service error 5c310 alarm light keeps
http://damnprinter.com/226/canon-service-call-errors.html
http://www.fixyourownprinter.com/forums/inkjet/26091
You need to clean your waste ink i think.
For troubleshooting purposes, please perform the following:
1. Open the printer and remove all ink tanks.
2. Insert a single ink tank in the printer then close the cover.
3. Confirm whether the printer recognizes the installed tank
properly. If it does, it will indicate it does not detect the other ink tanks, as
they are not currently installed in the printer.
4. Repeat steps 1-3 with another ink tank.
5. If the printer at any time indicates two of the same ink tanks are
installed, the cause will be the last tank installed. For example, if
you inserted an ink tank earlier, and you later inserted another ink
tank, and it said two of the same inks were installed, the cause of
the issue is the last ink tank.
