Question about Radio Communications
No SWR - Radio Communications
  • Mojorisin65 May 11, 2010
    Do you mean that it is showing no standing wave at all or what ?
    Low standing wave is a good thing.
  • 181 Answers
You have to have some swr. around 1.1,check patch lead. are you get out. check power out usually 4 watts on a standed rig.
Posted on Jun 01, 2009
Have a new cobra 29lx. Everthing works fine except for the SWR meter. Can't use the meter to adjust SWR. No matter what I do the meter stays the same. Sent to factory but they said nothing was wro
The SWR cannot be changed by rotating this knob. The SWR function allows you to determine the SWR or "match" of the antenna system and transmitter on a specific channel. The entire process must be performed whenever you want to know what the SWR is on a different channel. The SWR/CAL button toggles the meter between the CALIBRATE and SWR modes.
Set the radio to CH1. Press the SWR/CAL button. The radio CAL(ibrate) mode is now selected. Press and hold the mic PTT (or push to talk) button. Rotate the SWR knob as needed to adjust the meter indicator until it is on the SET mark on the dial. The meter is now calibrated for this channel.
While still holding down the mic PTT, press and release the S/RF SWR CAL button to the SWR setting to read the SWR on the meter.
This entire process should be done for Ch 20 and Ch 40. You must go through the CAL procedure for EACH channel before attempting to read the SWR.
Changing the SWR requires that the antenna be lengthened or shortened until such time that the SWR can be reduced no further. Typical SWR across the band may be:
CH1 - 1.5:1, CH20 - 1.1:1, CH40 1.5:1
or
CH1 - 2.2:1, CH20 - 1.7:1, CH40 2.3:1
The "dip" in SWR on CH20 is typical, as the antenna is the perfect length on only one channel - it will be come slightly too long or slightly too short as you tune up or down from CH20. The further away from CH20 you go, the poorer the SWR will be. You can "slide" the dip to any channel you prefer - say CH8. If you tune for lowest SWR on CH8, You might see CH1 with a 1.2:1 SWR, CH8 at 1.1:1 SWR and CH40 at 2.5:1. All are acceptable - sort of. Many manufacturers say up to 2.5:1 or even 3.0:1 matches are ok, There's no reason a quality antenna can't be tuned for optimum SWR in the middle of the band (CH20) to have less than a 2.0:1 SWR on CH1 or CH40, unless there is a ground issues or bad cable / antenna / connection somewhere.
You can view the manual here. I hope this helps & good luck!
Nov 30, 2012 | Cobra 29 Lx Full-featured Cb Radio
Self adjusting SWR does not work on 959 Galaxy
the swr on the radio is not what you are thinking it is. You have to set the SWR to anything below a 2.0 and the meter will let you know when and if your swr gets to high.
Sep 23, 2012 | Galaxy Radios DX-959 CB Mob Auto Swr...
My ANT light comes on when ever i push the mic button but my SWR isnt that high
The meter will be more accurate and an external meter will be even better. If they show good disregard the ant light it is adjustable. It may have been set to sensitive from factory. These erroneous SWR reading can be the side effects of a PEAK & TUNE if the coils have been spread but that should also show on meter.
SWR meter calibrations
  • Switch (S/RF SWR CAL) to the CAL position.
  • Push and hold mic button
  • While holding mic button adjust the SWR CAL knob so the meter needle swings to the CAL mark on the meter
  • While still holding down the mic button, set the (S/RF SWR CAL) switch to the SWR position, to read the SWR reading. Note: When switched to SWR position the meter needle should ideally be as far to the left as possible. Anything over 3 is not acceptable.
Jul 28, 2011 | Cobra 29 LTD CB Radio
Swr meter not moving
follow these steps to adjust the
standing wave ratio(SWR).
1. Turn on the CB.
2. Set S/RF/SWR/CAL to CAL.
3. Key the Mic and rotate SWR CAL so the meter points
to CAL.
4. Unkey Mic.
5. Set S/RF/SWR/CAL to SWR.
6. Key Mic again and note the actual measurement on
the SWR scale. Refer to the following table to interpret
the reading.
1:1 - 1.5 Great
1.5 - 2:1 OK
2:1 - 3:1 Not So Good
Higher than 3.1:1 Terrible
Jan 14, 2011 | Cobra 29 LTD CB Radio
I don't understand how to adjust the SWR or how the built in meter works for my DX949.
Here is a basic instruction on how to adjust the SWR. When you adjust the SWR, you are not changing anything on the radio. You are actually tuning the antenna for best SWR. The lower the better. SWR stands for "Standing Wave Ratio" Or in layman's terms, SWR is energy that is reflected back into the radio. The higher your SWR reading, the more RF energy that is not leaving the antenna, and getting reflected back into the radio. This can cause damage to the transmit section of the radio. The length of the antenna is what will change this. The length of the antenna must match the length of the radio wave. The following instruction will explain how to take an SWR reading, and how to use that reading to ascertain weather the antenna is too long or too short.
Here is a quick explanation of the meter. There are 3 settings for the meter. SWR, MOD, and PWR. When you are not keying the radio the meter will show you your receive signal. How strong some ones signal is. When you have the switch on MOD and key, when you talk it shows you modulation. How much audio you are putting through the radio. When its on power, and you key the radio, it shows you your dead key wattage.
Tuning your antenna:
It is important to tune your CB radio antenna to the proper length. The length must exactly match the wavelength of the frequency you transmit on. Or be really really close.
All Cb antenna's have a way to adjust the length of the antenna. If it's a mag mount, the metal whip can be slid in and out of a metal collar. Usually a set screw. If its a fiberglass whip, the way to tune it is on top. It either has a small metal rod with a set screw to adjust the length, or it threads in and out to adjust length.
Either type you have it will need to be adjusted for proper length. Here is how to tune the antenna to lowest SWR.
Some radios have a built in SWR meter. Some do not. If yours doesn't have an SWR meter, then you have to use an external SWR meter. Radio shack carries one, and you can find them cheap on ebay.
If you have a built in SWR meter or external, the procedure is the same:
1. Turn the radio to CH 20.(This is the center of the band.)
2. Switch the meter switch to SWR
3. Key the radio. (Important. Do not talk while keying the radio.)
Where the meter falls after that point is you SWR reading. If its above 3, that is real bad. 2 is not gonna kill your radio but its not the greatest. 1.5 and under is a good place to be, but the lower the better.
If your SWR is high, Here is how to find out if your antenna is too long or too short.
1. Turn to CH 1
2. Repeat SWR procedure. You must calibrate every time you do it.
3. Remember the SWR reading.
4. Turn to CH 40.
5. Again repeat SWR procedure.
6. Compare the reading between CH 1 and CH 40.
Now if the SWR is higher on channel 1 then channel 40 your antenna is too short. You must make it longer.
If the SWR is longer on channel 40 then on channel 1, then the antenna is too long, you need to make it shorter.
Make height adjustments about an eight inch at a time, and take reading each time.
once the SWR is significantly lower and the reading on channel 1 and 40 are about the same, you a about matched. At this point turn the radio to the center of the band, channel 20 and take an SWR reading.
You should now have a low SWR reading, 1.5 or under. If you are 1.5 or under, you are good to go.
If you cannot get the SWR to an appropriate level, there may be an antenna problem.
Nov 16, 2010 | Galaxy Radios DX-949 40-Channels Base CB...
Dont know how to use the swr meter on my radio
With radio turned on
1. Switch the first switch (S/RF SWR CAL) to CAL setting
2. Key mic up &
3. Turn SWR CAL knob while still keying mic until the needle is on the red CAL arrow at the far end of the meter scale. Unkey mic.
4. Switch the first switch back to SWR setting.
5. Key mic up again and record SWR reading and adjust as needed.
6. When done adjusting put switch back in the S/RF setting for normal operation.
Do not flip the switch with the mic keyed up.
Jan 19, 2010 | Cobra 29 LTD CB Radio
Tunning the antenna on radio shack cb trc-447
After installing the antenna, follow these steps to adjust the
1. Turn on the CB.
to CAL.
4. Unkey Mic.
the reading.
1:1 - 1.5 Great
1.5 - 2:1 OK
The ideal standing wave ratio (SWR) is 1:1, or a meter
reading of 1 on the SWR meter's top scale. A SWR ratio
of 1.5:1 to 2:1 is excellent for most mobile CB antenna
applications.
Check the SWR on Channel 1 and Channel 40
If the SWR is higher on 1, make the antenna longer
If the SWR is higher on 40, make the antenna shorter
Most antenna's are adjustable. Make small adjustments at a time.
Oct 10, 2009 | Radio Shack TRC-447 CB Radio
When i key up the mike the tx/rx light and the ant
your swr setting are off wack fix your swr
Oct 02, 2009 | Cobra 29 LTD CB Radio
I need the manual/s for a Cobra CB radio, 29LTD Classic,ser#105129711,manufactured 5/01. Thanks for any help you might have, This radio has a built in SWR meter and I need to know how to tune it or do I...
1) push the button marked S/RF / SWR / CAL to CAL
2) Hold in the button on the mic
3) Turn the SWR CAL knob until the needle is over set to the far right of the meter
4) flick the switch (in step 1) to SWR
Your SWR reading will be displayed. The more to the left the better..
Jun 22, 2009 | Radio Communications
Swr to hi and can t get it down
I hope this will help you on setting your swr put the radio on channel 1 check your swr.
now go to channel 40 check the swr. If the swr is lower on 1 than it is on 40 the antenna must be shortened buy 1/4 inch.until you reach your desired swr.if the swr is lower on 40 than it is on 1 the antenna must be lenthened by 1/4 inch until desired swr.
Mar 28, 2009 | Cobra 29 LTD CB Radio
Radio Communications Logo
60 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
