Question about Fila Clothing Accessories
Shoe repairs left side torned
The lining of my carlos falchi bag is torn up, almost half of the lining is gone... where can i have it repaired?
most shoe repair shops can repair bags
check your trade pages of the phone book and make calls
Jun 23, 2016 | Cars & Trucks
Repairable Nike shoes
They can be repaired at a better quality shoe repair shop and if the repair is done right, it should look almost like they were new!
Feb 01, 2014 | Nike Clothing Accessories
Dog torn the inside sole out of a Xarby
You can repair it yourself if you have leather or some closed cell top cover material to put in. If not, a shoe repair shop can help you with this.
Jan 06, 2014 | Bandolino Clothing Accessories
Dog bit my fit flop sandals, can it be repaired
I would say that they can be repaired. You can line the area where the tear is to get it fixed or you can take it to a shoe repair shop.
Jul 24, 2012 | FITFLOP Clothing Accessories
Reebok shoe net torn
It cancbe replaced at a shoecrepairxshop
Feb 28, 2012 | Reebok Clothing Accessories
The sole of my GEOX shoe (Left Side) fell apart. Please advise where and how I can get the sole repaired as the pair of shoes are in very good condition?
I am going to say that any good shoe repair shop should be able to take care of this. If you are not familiar with what kind of work the shop does, have them show you some of their work. If it looks like a ham-handed klutz did the work, find someone else to do the work!
Aug 23, 2011 | Geox Alex WP Shoes for Men
I have a sandal that has a torn and worn inside sole. where can I have it fixed?
I would say that any shoe repair shop could take care of a repair like this. Take both along because it will look better when the repairs are made to both shoes.
Aug 13, 2011 | Vaneli Melea Sandals Sandals for Women
Flip flop string torn from the base typical flip flop problem but they are only 1 year old.
The problem could be multiple things. One your feet may be too big for the shoes putting stress on the flip flop string, even though I doubt that it the problem, but a possibility. Two you may be over wearing them or in what is considered rough conditions, also usually not the case. Finally the shoes aren't made properly or well enough. Anyway with the first problem, you just need a bigger size. The second problem get shoes that can handle your everyday or also with the third problem you can repair the shoes. You can try to repair the shoes before they break or after. If they are cloth like then things like hot glue can be effective or using string like this website shows click here to see. If it is a rubber flip flop then you can also use glue or try what this website shows, just click here. Hope that helps.
Jun 04, 2011 | Havaianas Clothing Accessories
How to change back brakes 1999 ford windstar, back brakes are grinding, brake light on
does it have rear disc brakes or drum brakes, if disc brakes should be changed just like the front and you might have an emergency brake shoe inside the rotor that they call a halo shoe, if it is drum brakes take off the adjusting spring and the return spring remove the brake adjuster,the the brake bar then remove the brake shoe hold down spring by holding the pin from the back and pushing and turning the spring to remove from the pin, you might have to remove the the emergency brake bar from one shoe by removing the horseshoe clip from the pin on the shoe if you have problems putting it back together look at the other side that you have not torn down yet.
Aug 12, 2009 | 1999 Ford Windstar
Brake shoe positioning on -88 K2500
Short shoe goes towards front. Also: check for any contamination on shoes or hardware from either axle seal or wheel cyls. Any contamination will make vehicle pull when brake applied. Technically, if contaminated shoes need replacement but if not heavy, on new shoes I usually just give a light sanding on friction material and the remainder will usually burn off.
Feb 12, 2009 | 1988 Chevrolet K2500
Clothing Accessories Logo
13 people viewed this question
Top Fila Clothing Accessories Experts
Da Doc
shuyumeng
shuyumeng
Are you a Fila Clothing Accessory Expert? Answer questions, earn points and help others
