Question about HP DeskJet 960c InkJet Printer
Hp 960 cartridge
I have refill the cartridge still i am having error of depleted cartridge
agnelkj
  • 210 Answers
SOURCE: inkjet refills
hi,
as you are using a refilled cartridge, it is causing this problem. the thickness of ink in a hp genuine cartridge and a refilled cartridge varies. and also the refilled cartridge may make your printer faulty. so it is good to try with a new hp genuine ink cartridges.
thanks and regards
agnel
Posted on Mar 18, 2008
nalin_elliot
  • 224 Answers
SOURCE: My HP Photosmart C7280 does not recognise refilled cartridge.
Yes that is because when you get a cartridge refilled then what may have happened is when you gave a print command some of the ink may have splattered onto the ink spraying sensors(usually happens with refilled cartridges on any printer).Its because of the heat generated with which the ink nozzles cannot handle as the ink that is sprayed from refilled cartridges is a little more than regular original ink cartridges.Dip a cotton swab in water wipe the copper contacts on the cartridge.Then wipe around the place where the cartridges sit and also wipe the carriage rod which is inside the printer (metal rod)along which ur spraying mechanism(carriage) moves. If this does not resolve your issue call in to hp at 1800-474-6836 and you can purchase original cartridges that are just for 11 dollars each.........or you can purchase a combination pack which will be cheaper
Posted on Jun 16, 2009
SOURCE: HP L7680 gives error ink in cartridges depleted
I had this problem recently after replacing the yellow ink cartridge. After much wrangling with HP, they sent me a new cartridge (since it's date code was not expired) and that seemed to fix that particular issue. You might also try getting a replacement cartridge from the vendor that sold you the one in question since it's likely to be faster and less painful than going to HP directly.
  • 1751 Answers
SOURCE: Error "remove and check color cartridge" after cartridge was refilled.
try cleaning the contacts opd the color cartridge
with a wet towel
if the problem is not solve return the cartridge in the shop you get it and ask them to replace it
Posted on Apr 26, 2010
  • 4 Answers
SOURCE: How to reset ink cartridges after refilling them
Go to the following website and download the freeware InkMonitor 2.1.2: http://www.pokluda.cz/. You have to add data about new cartridge. HP60 ink cartridge information, 200 pages per cartridge. This works great for me. It gives you a history of everything printed. This way you can gauge when its time to refill your cartridges. You must refill before they run out of ink or you will burn out the print heads and have to replace them.
Posted on Jun 06, 2010
Refilled HP 932XL ink cartridge and cannot reset the 'Depleted Cartridges' condition, and printer will not print.
Lots of printer manufacturers do all sorts of things to discourage refilling the cartridges. But they are to blame because those bastards over charge for ink - it is about 5000 dollars per gallon!
Go to Google and check - there is a workaround for it - trust me.
Good luck! (I refill also!)
Dec 08, 2015 | HP OfficeJet Office Equipment & Supplies
I already refill hp 960 catridge but printer show ink catridge depleted.. so what i do
the micro chip reads the amount of pages already printed but cannot be reset. Only way to remedy is get a refilling company to supply another chip.
Aug 06, 2014 | HP Office Equipment & Supplies
Printer officejet pro 8600 cartrige 951 is full but printer thinks its empty. how to reset printer
use only new cartidge. Its the best thing you can do if you want your printer work fine with no trouble.
Mar 31, 2014 | HP Officejet Pro 8500 Wireless All-In-One...
I just bought a new yellow ink cartridge, and when I put it in the printer says that the yellow ink is depleted. I changed the ink two times. What should I do?
If you are using off brand cartridges that are remanufactured (refilled), that may be your problem. I have had several HP printers and when I used refilled cartridges, it wouldn't print. I stay with genuine HP ink cartridges. Just my opinion!
Sep 15, 2010 | HP Photosmart C5180 All-In-One InkJet...
How do i make printer accept refilled cartridge t
Maybe you did not refill and insert it very well.
follow this steps in refilling your ink
1. remove the ink cartridge from the printer
2. make a hole at the top end of the cartridge, the hole can be made under the label on the cartridge by using a sharp/hot pin.
3. if you are using a syringe and needle in refilling, make sure you did not insert it into the hole too much so that the cartridge does not get damaged in the process.
4. make sure the ink is not over-filled to avoid spillage which can cause a hell of damage on you printer as it does to my previous one.
5. Gently use the label or a masking tape to cover the hole and insert it into your printer.
Note: The printer gives a message that the cartridge is empty or non compatible, ignore the message and continue with your printing.
It is also advisable that you refill your cartridge not more than 2 times.
If this solution does not help you, contact me on holamydes@gmail.com for more assistance.
Aug 15, 2009 | HP DeskJet F4280 All In One Printer InkJet
Printer not printing in black. Print Color only.
Hi
Thanks for using FixYa. First of all please try the refill cartridge on some other printer. If it’s working fine on the other printer then check the settings of the printer which are by default 960 dpi (dots per inch) but due to some reason this size has been reduced. Now you have to change this setting to more than 960, around 1200 dpi and then check out that if your printer works fine.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Jul 28, 2009 | HP PSC 1210 All-In-One InkJet Printer
Jun 15, 2009 | HP Photosmart C7280 Laser Printer
Ink cartridge
I think you need to open your printers "Properties" and set and apply that new cartridges have been installed to get past the problem. It's been a while but I had to do this with mine last time I refilled them after they showed depleted.
Jul 15, 2008 | HP Photosmart C5180 All-In-One InkJet...
HP DeskJet 960c InkJet Printer Logo
Seeker5211
Seeker5211
