Question about OKI C3200 Led Printer
OKI C3200n and HP LaserJet 3052 Can't be in the same PC
I have a Oki 3200n install in my PC and it was working find, then I install an HP LaserJet 3052, since that my oki do not print from this PC, I remove the HP and still Oki dont print, I try to re-install oki 3200n but it comes up with an error Can't finished instalation, now I have the HP3052 working in this pc and if I need to use the oki I use my laptop, I would like to have both in mi Desktp,
any help??
  • Sergey Lebedev
    Sergey Lebedev May 11, 2010
    How these printers are connected to PC? Via USB or via network? I'd recomment to use network connection for OKI and USB for HP thus eliminating the port conflict.
  • OKI Master
  • 824 Answers
You do not say what operating system you are using?. They are both compatible with Windows 10.There should be no conflict between the two printers. Use system restore and go back in time before you had the problem. Disable your antivirus and try and install them again. That should work.
Posted on Jul 02, 2017
  • 2110 Answers
SOURCE: Oki printer download
download tis driver...
Posted on Jan 30, 2009
  • 2120 Answers
SOURCE: OKI 3300 Image Drum Problem
Did you remove the plastic tape from the new cartridge?
Posted on Feb 16, 2009
  • 627 Answers
Compatible toner is more cheaper than original, risking quality and due to low quality of the powder you can damage your printer.
I suggest to use original toner and at the printer properties set your printer to work in save toner mode.
Posted on Sep 30, 2009
Testimonial: "Although I was hoping that the answer would be in favor of compatible, I got confirmation of what I guessed it would be. prompt, and helpful... thanks"
  • 10406 Answers
SOURCE: When I print to my Oki C3200n the paper comes out
The "fuser" uses heat to "bake" the ink onto the paper.
Your printer seems to have a mechanical problem while "feeding" the paper from the "input" tray, through the printer, passing the fuser, and to the "output" tray.
Check that all the rollers that "pull" the paper into the printer are working -- if one of them is not grabbing the paper, the paper "slews".
If you need help, take the printer to a qualified technician for repairs.
Posted on Nov 13, 2009
try switch off, unplug, hold up and down & reset button at the back, swith on
Posted on Sep 13, 2011
Windows 8 says my oki c3200n is in an error state
Have you contacted OKI Data? Live customer support is available 24/7 (within the US and Canada) at 1-800-OKI-DATA.
Jan 22, 2013 | OKI C3200n Led Printer
Hi, is there a way to stop the OKI 3200n printer from demanding a new belt, the printer is working just fine but the darn red light stays lit
It will continue to report this until replacement. In my experience, it won't lock you out, but the error is a result of the printer testing the integrity of the belt, so until it is replaced, it will report this error. Use it until yu see print issues, and then replace.
Sep 30, 2010 | OKI C3200n Led Printer
MacBook Pro will not recognize drivers for OKI C3200N
Go to (Start > Control Panel > Hardware and Sound > Add a device) Check for connected devices. You can also go to (Start > Control Panel > Hardware and Sound > Add Printer > Local) check the USB1, 2, 3 options is available for using an existing port. The options are LPT1, 2, 3 (Printer Port) | COM1, 2, 3, 4 (Serial Port) | FILE (Print to File) | TPVM (Thin Print) | XPSPort. Select the appropriate port and try it…..
good luck
Aug 07, 2009 | OKI C3200n Led Printer
My Oki C3200 has the following error message 541:m Toner Sensor Error
There are several reasons for this message... we will start with the easiest to solve. Here is a link:
Jun 03, 2009 | OKI C3200n Led Printer
Jan 30, 2009 | OKI C3200n Led Printer
OKI 3200CN with Vista Laptop
make sure when you install you opt for USB port driver.
if already installed, uninstall, then reinstall
OKI do not support this printer very well for vista
Sep 29, 2008 | OKI C3200n Led Printer
Oki C3200n Says Order K Toner after install
Two possible problems:
1. You actually got a partially empty new toner. This has happened to me once.
2. The sensor on the printer is dirty and not seeing the toner. With the toner there is a little wipe that says it is for cleaning the LED. There is an LED sensor that "reads" the presence of the toner. If this is dirty it will think there is no toner cartridge.
Jul 09, 2008 | OKI C3200n Led Printer
OKI C3200 Led Printer Logo
93 people viewed this question
Top OKI Office Equipment & Supplies Experts
Level 1 Expert
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
