Question about Curtis Televison & Video
How to set up cable - Curtis Televison & Video
My tv model magnavox26mf231d/37 shows hdmi is disabled and the hdcp authorization failure.
This could be a problem with the cable box or other set top box and not the TV. It's known to happen with Samsung cable boxes from Cablevision.
First try resetting the TV and set top box by unplugging both. Remove the HDMI cable from the TV and the set top box. Reconnect the HDMI cable. If you are using a Redmere or similar HDMI cable, make sure that the end labeled TV is connected to the TV's HDMI port. (These cables have additional electronics and are not reversible.) Connect the power cord to the set top box and wait 30 seconds to a minute. Then plug in the TV. To ensure the set top box does the correct handshake with the TV, turn on the TV first and set it to the HDMI input. Then turn on the set top box. See if this fixes the issue. (On some cable boxes, this can be a temporary fix. You may need to have the set top box replaced.)
If the above steps don't help, try a different HDMI cable. If that doesn't solve the problem, then the set top box is faulty.
I hope this helps.
Jan 10, 2015 | Televison & Video
Sound robotic on samsung ln22a450c1d
change the sound volume in channels settings /avc and try
Jan 01, 2014 | Samsung LN32A330 32 in. LCD TV
NEED JUMPER SETTINGS FOR MASTER HARD DRIVE
Set The Jumper Setting On Your Hard Disk Drive
The hard disk drive will be detected as 32 GB if the jumper is set to the 32 GB clip pin setting. The common jumper settings for Samsung hard disk drives are listed below. Please check the label on your hard disk drive for the correct jumper setting.
Important: Use the alternate jumper setting listed below under General Pin Setting. After changing the jumper, partition and format your hard disk drive.
Configuring your Hard Disk Drive (Master, Slave, or Cable Select) - Setting the Jumper
If this is the only HDD in your computer, set the pin setting to Master.
If this is the second HDD in your computer, set the pin setting to Slave.
If this is the second HDD in your computer, and the first drive is set to Cable Select, set the pin setting to Cable Select.
If you are replacing the HDD in your computer, set the jumper setting to match that of the drive you are replacing.
Cable Select:
This setting is the default setting for PATA/IDE hard disk drives. With the Cable Select jumper setting, the BIOS determines whether a hard disk drive is Set as Master or Set as Slave by it's position on the UDMA cable.
If the hard disk drive jumper is set to Cable Select and is connected to the black connector on the end of the UDMA cable, it is recognized as Set as Master for that PATA controller.
If the hard disk drive jumper is set to Cable Select and is connected to the grey connector on the middle of the UDMA cable, it is recognized as Set as Slave for that PATA controller.
Note: When using Cable Select, your system must meet the following conditions:
Your systems host controller must support Cable Select.
Your hard drives must support Cable Select.
Your cable must support Cable Select.
Set as Master:
Use this setting if you are installing an additional hard disk drive to a single UDMA cable with a hard disk drive Set as Slave, jumper one hard disk drive to Set as Master, and the other to Set as Slave.
Use this setting if you are installing an additional hard disk drive to a single UDMA cable and the Cable Select setting is not recognized.
Set as Slave:
Use this setting if you are installing an additional hard disk drive to a single UDMA cable with a hard disk drive Set as Master, jumper one hard disk drive to Set as Master, and the other to Set as Slave.
32 GB Clip Pin Setting:
Use this on computers manufactured before November 1998 when either you start up your computer and see the message, "Hard disk drive controller failure", or your system stops responding during the boot process after installing a new drive. This occurs when the hard disk drive is too large for the BIOS to support.
If after performing the troubleshooting procedure listed above, the full capacity of your hard disk drive is not recognized, click here for information about obtaining a system BIOS update. If you are unable to update your BIOS, another option would be to create a second partition with the remaining unallocated disk space.
Aug 18, 2012 | Computers & Internet
My dvd player was unhooked from my tv during a move. i no longer have the dvd manual. apparently I am connecting something incorrectly, because I have audio but no video. can you help with a verbal or...
The DVD player and Tv set connections are made in ur tv,by what kind set up?Like by a RCA components cables Y,R,W RCA cable?Just follow the DVD player output holes hook up RCA cable Y,R,W to the DVD player out holes hookup to tv set input holes like Y,R,W input holes.Check the RCA connections cables pull out and re connected in those holes a couples times sometimes old equipment must do that for ensure contact are made.Might have a damage set of RCA cable set.Might have replace another RCA cable set.Or ur setup using a S-video cable set and used a RCA cable R,W cable only for audio only?Than S-video cable probally got shorted must be replaced.
Aug 04, 2011 | Panasonic Televison & Video
I have a maxtor quantum fireball plus as 20.5 hard drive. i want to set it to slave. how do i set the jumpers?
on maxtor drives, you will find the jumper within a cluster of 9 pins. if you look on the bottom of the drive, on the circuit board, the pins should be labeled "ms" "cs" and such. the "ms" and "cs" stand for "master" and "cable select". you rarely use the true "slave" setting anymore, more often than not' "slave" drives are set to "cable select" and are attached to the middle, slave position on the ide cable. in "cable select" mode, the cable decides what device is master and what is slave, depending upon the devices' position on the ide cable.
to set the drive to "slave", set the jumper so that it only has 1 pin under it, and doesnt actually jump any pins, or just take the jumper out. only use the "slave" setting if the "master" device on the same ide cable is actually set to "master".
if the master device is actually set to "cable select" then you will have to set the slave device also to "cable select" and the middle position on the ide cable will set it automatically to be a slave. , instead of using the jumper to make it the "slave".
to set the drive as "cable select", which is what i would recommend, use the jumper to connect the 2 pins which are labeled "cs", the 2nd position from the bottom position on most older maxtor drives, and attach this hard drive to the middle connector of the ide cable.
Nov 25, 2010 | Quantum Fireball Plus AS (QMP20000AS-A)...
No cable channels are working with the TV Spectra SS213 TV
goto the menu and make sure it is set to cable and not to off air or local setting. after setting to cable, run an auto scan to lock in available channelss
Oct 06, 2009 | Spectra (SS213) 13 in. Portable Television
Cannot set screen width
Both the TV and the Cable box have Aspect(height/width) settings. You must confirme the setting on the cable box and then do the TV.
1. Set TV to Native, this should show image exactly as the cable box sends it.
2. change Aspect settings on the cable box until you get one that works
3. if you get a good one, then your OK. You will just need to find a setting between the 2 devices that work for you. Also, these settings may change automatically for the TV or cable box based on the channel
Dec 25, 2008 | Toshiba REGZA 42 in. Flat-Panel LCD HDTV
I have bought two hitachi 160 GB hard drives and need jumper setting explained please
The usual jumper settings for a hard drive are:
  • Cable Select
  • Primary
  • Secondary
Cable select means that the mainboard will choose whether to make the drive primary or secondary. Most mainboards today support cable select. And, most drives will have their jumpers already set to cable select. You can just have all your drives set to cable select, and the mainboard will take care of the rest.
“Primary” means first and most important. Think of the primary as the one that usually takes control of the cable and gets its way. The secondary is like a little brother who must usually wait.
You usually want your main hard drive set as primary, or set it as cable select and have the mainboard set it as primary
Sep 16, 2008 | Hitachi Computers & Internet
No audio on pasma when cable set box set to certain channel
In that case two things might be happening. 1. HDMI/DVI cable you using might be faulty you want to change that or 2. The HDMI input of your TV set might be the problem. I will suggest you use component cable instead, I am talking about the 5-color-coded (green, blue, red and red/wihte) cable to connect the set top box to your TV.
Jun 15, 2008 | LG 50PX4DR 50 in. Plasma TV
Televison & Video Logo
35 people viewed this question
Top Curtis Televison & Video Experts
Martin Murray
Are you a Curtis Televison and Video Expert? Answer questions, earn points and help others
