Question about NEC MultiSpin ND-1100A (ND-1100A) DVD+RW Burner
Explain abt jumper settings - NEC MultiSpin ND-1100A (ND-1100A) DVD+RW Burner
  • 33 Answers
How to remove eMachines E732z BIOS password?
There's usually a set of jumper pins on the motherboard that reset the password when you short them while booting. Remove the jumpers, reboot again, and the password should be cleared. Which pins? Search for the number printed on the motherboard, and you may find a diagram which explains all the jumpers.
Feb 16, 2017 | Office Equipment & Supplies
Master jumper settings for sv1204h
i'll try to explain with a scheme:
These are the pins, you need to put the jumper like this:
Feb 28, 2011 | Samsung SpinPoint V60 SV1204H 120 GB...
"Reset you're cmos/bios jumper to
HI,
No need to worry. There are many known ways to reset / remove / bypass the password:
  • By removing the CMOS battery
  • By using the motherboard jumper
  • By using MS DOS command
  • By using software
  • By using Backdoor BIOS password
Now I'll try to explain each method one by one:
A. By Removing the CMOS Battery:
Almost all motherboards use a small coin sized CMOS battery to store all BIOS settings along with the password. To reset the password, unplug the PC, open the cabinet and remove the CMOS battery for approx. 15-30 minutes and then put it back. It'll reset all BIOS settings as well as the password and you'll need to re-enter all settings.
If it fails, then try to remove the battery for at least one hour.
B. By Using the Motherboard Jumper:
Almost all motherboards contain a jumper that can clear all CMOS settings along with the BIOS password. The location of this jumper varies depending upon the motherboard brand. You should read your motherboard manual to check its location. If you don't have the manual then look for the jumpers near the CMOS battery. Most of the manufacturer label the jumper as CLR, CLEAR, CLEAR CMOS, etc.
When you find the jumper, look carefully. There will be 3 pins and the jumper will be joining the center pin to either left or right pin. What you need to do, is remove the jumper and join the center pin to the opposite pin. e.g. if the jumper joins center pin to left pin, then remove it and join center pin to right pin. Now wait for a few seconds and then again remove the jumper and join the center pin to left pin.
Make sure to turn the PC off before opening the cabinet and resetting the jumper.
C. By Using MS DOS Command:
This method works only if you have access to the system when its turned on because this method requires MS DOS. Open Command Prompt from Programs menu and provide following commands one bye one:
debug
o 70 2E
o 71 FF
quit
NOTE: The first character in the above commands is "O" and not the number 0.
After providing the above commands, restart your system and it should reset the CMOS Settings along with the BIOS password.
If you are curious to know how it works? then let me explain the above commands:
In this method we are using the Debug tool of MS DOS. The "O" character present at first in these commands, outputs the values to IO ports. The number 70 and 71 are port numbers which are used to access CMOS memory. By providing FF value we are telling CMOS that there is an invalid checksum and it resets the CMOS settings as well as BIOS password.
Jan 08, 2011 | Intel DG31PR Motherboard
I dont know much abt motherboard..but my audio device is not detected so can u just temme abt the audio jumpers..
eh no but u can use the comms jumper 2 reset the comms on the board then check its registering in the bios
Jan 01, 2010 | Computers & Internet
Motherboard jumpers problem
some system chassis com with 2 or 3 sets of audio and usb ports, front and rear, and some motherboards have similar provision. These board jumpers are used to enable/diasble some of the ports
Sep 24, 2009 | Computers & Internet
Swap two hard drives
Indeed you can. Make sure the jumper settings are identical for the swap, and as long as the replacement one has windows xp running on it you should be fine.
Mar 04, 2009 | IBM ThinkPad T22 2647 Notebook
Bios password
dont take out the jumper, instead take out the battery(cell) for abt 5 secs and then put it back and there u go password is reset.
Jun 19, 2008 | Toshiba Satellite 5105-S501 Notebook
Jumper setting
what is the board model post it then will try for solution
Mar 28, 2008 | Computers & Internet
Jumper setting
hello
can you send me this page to check with you if you want
AYADI
Mar 14, 2008 | Iwill VX133 (MAVX133) Motherboard
NEC MultiSpin ND-1100A (ND-1100A) DVD+RW Burner Logo
43 people viewed this question
Top NEC Computers & Internet Experts
Steven Wander
Steven Wander
Are you a NEC Computer and Internet Expert? Answer questions, earn points and help others
