Question about Rinnai 37AHB09016KA5 90,000 BTU, 3 to 5 Ton Cooling, Hydronic Air Hand
Rinnai 37AHB09016KA5 providing no heat - Rinnai 37AHB09016KA5 90,000 BTU, 3 to 5 Ton Cooling, Hydronic Air Hand
  • Richard Rychlewski
    Richard Rychlewski Jan 03, 2014
    Hi I have a Hydronic Air Handler hooked with a Rinnai tankless that is running without producing any heat. The unit basically starts and stops but no water is being pumped into the air handler. The problem just started and I am wondering if the flow switch is broken or needs replacing.
  • 85 Answers
If this is a heat pump the switching valve could be malfunctioning. Check the for continuity on the valve.
Posted on Jan 03, 2014
Our Rinnai convector unflued room heater won't start. Lights just flash heat never comes on.
According the the Owner's Manual for your Rinnai Convector Heater, there are 8 things, than can cause what you described. Two of which can be discounted, unless you just had the heater installed.
I have provided a link to the Owner's Manual, that you can download and print for future reference. Please pay close attention to Page # 6 -Pre-Service Check List and Fault Finding. Each problem listed has a troubleshooting solution.
http://www.rinnai.com.au/images/stories/operating_instructions/Heating/Portables/Granada252/portable_radiant_convectors.pdf
Hope this helps you to further troubleshoot and solve the problem. Please let me know. Cheers!
Jun 17, 2011 | Heating & Cooling
How to install
Unfortunately, the installation of one of these units is not quite as simple as 1, 2, 3.
So, I am providing a couple links on the installation process. You can download and print each one.
The first is the Flue Installation Guide.
http://www.rinnai.com.au/images/stories/operating_instructions/Heating/Energysaver/CI_ES_Flue_Inst_Manual.pdf
The second is the Operation Guide, which also deals with proper installation.
The third is the exploded parts view & parts diagram, Which you may need in the future.
I hope all of this information will help you properly install the unit.
Jun 02, 2011 | Rinnai EnergySaver 556 Air Conditioner
Can the internal thermostat be adjusted?
The Rinnai Model Number you listed is for a Direct Vent Heater, not a Vent-free or "Ductless Heater".
Whether it's Vent-free or Direct Vent, the thermostat can not be adjusted. If it's not producing enough heat, the air intake filter may need cleaning or there my be some object obstructing the heat output vent on the front of the heater at floor level. Also, not setting the thermostat high enough can also be a cause. And finally, the heater may not be properly sized (Btu Output) for the area you're trying to heat.
For more insight into the Model Number you listed, I have provided a link to the Owners Manual, that you can download and print for future reference. It will also provide you with what needs to be done as part of Routine Maintenance, that you can and need to perform.
http://www.rinnai.us/documentation/downloads/ES38_1004RFA_Manual.pdf
Hope this helped to answer your question and provide further information.
Apr 13, 2011 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
I needs have a rinnai hot water heater it needs part no.ceo2 heat exchanger where can i buy one
All parts for Rinnai Heaters and Tankless Water Heaters must be purchased from Rinnai authorized dealers. To find one closest to you go to http://www.rinnai.us/ and click on find a dealer tab in the top red banner..
Mar 20, 2011 | Rinnai Heating & Cooling
My Rinnai infinity 20 water heating is not lighting
Just joined fixya and am a Rinnai service manager in Australia. Is this still an issue?
Apr 11, 2010 | Rinnai Digital Remote Water Heater Control...
Rinnai gas water heater wont heat the water hot enough even though we have turned the thermostat up to 185.
your temp control is bad and you will have to have a tech to service the unit, contact rinnai and they will give you info on a quilified repair person,, not just any one should be allowed to work on it,, depending on the age it may still be under warranty,, they come with 5 year parts 1 year labor 12 years on heat exchanger this is on all rinnai units
Feb 18, 2009 | Rinnai Desa Vent-Free Infrared Gas Heater:...
Using the rinnie as a major heating source for an older home
The smaller the vent the better. A Rinnai may heat an area just fine but a whole house is pushing it.
Dec 17, 2008 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
Pilot goes out after heating cycle
Check regulator on the unit.
Check pilot unit on the heater
use soapy water to check for leaks if see bubbles turn off main gas supply valve.
always turn off gas supply before any checks or repairs are made
when all else failes call your local gas provider to check heater and gas supply
Nov 22, 2008 | Rinnai Desa Vent-Free Infrared Gas Heater:...
Rinnai monitor heater 1004F
http://www.rinnai.us/Rinnai.aspx/FileLib
hope this helps
Feb 13, 2008 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
Rinnai 37AHB09016KA5 90,000 BTU, 3 to 5 Ton Cooling, Hydronic Air Hand Logo
22 people viewed this question
Top Rinnai Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Tim Whalen
Are you a Rinnai Heating and Cooling Expert? Answer questions, earn points and help others
