Question about HEWLETT-PACKARD Pavilion Slimline s5503w DTS 1 x Sempron 140 27 GHz RAM 3 GB HDD 1 x 320 GB DVD RW
The white power light and orange standby light on front of the cpu isn't working.
    Master:
  • 269 Answers
If the rest of the computer is working, chances are that the cable from the lights to the mother board got disconnected or reversed (yes, polarity is important)
Posted on Aug 04, 2015
Blinking orange light
Is the Orange light the power indicator for this model or the standby (standby would be on all the time)
Dec 05, 2012 | BenQ FP553 (White) 15" LCD Monitor
I unplugged the little cables in the F_PANEL to the right bottom in my GIGABYTE GA-G41M-COMBO motherboard and the CPU is working after i reconnected them the but nothing appears on the monitor i hear the...
The problem most likely isn't with your f_panel your motherboard should have a manual that tells you how to plug everything into your f_panel correctly.
Ensure that there are no empty power connections on your motherboard. You board may not be powering its video component. If you have a graphics card, ensure if it requires a power connect that it is properly plugged in.
If this doesn't work I suggest your return your motherboard as it is not functioning properly.
Jun 17, 2011 | Gigabyte GA-G41M-Combo Motherboard
No display on monithor cpu fun runs &but mobo led
do it only if u r a professional..
assuming that the system bios hs not been flashed or updated in a wrong way..if so u gotta replace the m/b..
1st see if the ram(s) is loose/faulty..open n resit it..
check for ac main supply and fuse..next check all the outputs of smps viz. 0v (black~ground); +12v (yellow); +5v (red, green~ps-on, violet~pg & grey~sb); -12v (blue); -5v(white); +3.3v(orange)..if faulty try repairing or replacing the power supply with a standby n see..
if all above are ok..check the cmos/system battery..(above +3v)..
check the cpu fan rotating and the cpu generating heat..try replacing the cpu with a standby (if no heat is generated)..
there may b a chance for m/b's crystal clock generator to b faulty..try repairing or replacing the m/b with a standby..
there may b also problem with ur monitor or display adapter, try replacing with a standby..
hope it'll b enough to solve ur problem..
seek professional assistance of ur system admin/vendor....
Nov 03, 2009 | Intel D845GVSR Motherboard
My Presario F500 doesnt power on.. whats could be the problem.. I can see the green power led on.
Oct 31, 2009 | HP Compaq Presario F500 F700 and G6000...
My system donot boot at all
1st check for ac main supply and fuse..next check all the outputs of smps viz. 0v (black~ground); +12v (yellow); +5v (red, green~ps-on, violet~pg & grey~sb); -12v (blue); -5v(white); +3.3v(orange)..if faulty try repairing or replacing the power supply with a standby n see..
Oct 30, 2009 | Computers & Internet
I have a dell C521 tower,switch it on but light stays on orange,fans work but it wont switch on.help.
if the light remains Orange, Possible In Standby/Sleep/Hibernate Mode.
Try pressing And Holding The power Button For 4-5 seconds Or more.
If this Fails, remove the power Cable, remove side-panel ( Unless Warranted ) locate the silver cmos battery, on the motherboard. remove the battery for 10 seconds, replace and repower and startup. failing this i,d suspect the ram/memory or cpu.
Mike @ Compurepair.
Oct 29, 2009 | Dell Dimension C521 PC Desktop
I have a pioneer keh-p5450. can please send me a wiring diagram for this unit?
Here is the breakdown of what wire does what:
+Red..............12v ignition
-Black............Ground
+Blue.............Power antenna
+Blue/white.......Remote turn on
Orange...........Dashlight/dimmer
Orange/white.....Dashlight/dimmer
Orange/black.....Dashlight/dimmer
+White............Front left positive
-White/black......Front left negative
+Grey.............Front right positive
-Grey/black.......Front right negative
+Green............Rear left positive
-Green/black......Rear left negative
+Purple...........Rear right positive
-Purple/black.....Rear right negative
Oct 05, 2009 | Pioneer Car Audio & Video
Had to cut the factory harness
trick of trade... take a 9 volt battery and touch the wires to it.. the speaker will pop and you will know which one is which... do one color at a time
Apr 21, 2009 | 1993 Ford Explorer Limited
I have a shap lcd computer monitor and when i plug it into my computer and turn the power on, the little green power light comes on, screens back. and after 5-10 seconds the light turns orange and blinks...
It could be your monitor is fine. It simply goes to a cycle when its turned on and does not detect any signal coming from your CPU, it simply goes on standby mode (hence the darker image and orange/blinking light.) have you checked the computer (CPU) part?
Dec 04, 2008 | Computers & Internet
HEWLETT-PACKARD Pavilion Slimline s5503w DTS 1 x Sempron 140 27 GHz RAM 3 GB HDD 1 x 320 GB DVD RW Logo
Top HEWLETT-PACKARD Computers & Internet Experts
Michael Vincent Cruz
Are you a HEWLETT-PACKARD Computer and Internet Expert? Answer questions, earn points and help others
