Question about Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System
Ref light bulbs wh-pool GS5SHA
Open door, loud buzzing noise, all 3 light bulbs flash. (new bulbs)
freezer lights unaffected
push button (on - off) on side works smoothly
noise coming from bottom of box
  • aferalcat May 23, 2009
    Sea Breeze,
    Refrigerator side now dead, no lights, noise or cooling. Will inspect board Saturday.
    Thanks
  • Whirlpool Master
  • 4,655 Answers
Your refrigerator has two sets of electronic control boards. One is inside and works to adjust temperature and to communicate with the other below and behind the refrigerator. They both have relays that if bad could cause the sounds you hear. It would be ok to pull it away from the wall and open bottom cover and listen to see if the sound is coming from the lower control board. If yes we need to examine the board after unplugging the power to refrigerator. let me know if the board is the reason or if while there you find something different, Thanks, Sea Breeze
Posted on May 22, 2009
  • John Tripp
    John Tripp May 23, 2009
    Do you now know why the power failed to the compressor? I will be around if you shoud need me. Good Luck, Sea Breeze
My ge fridge is suddenly making a loud buzzing/ rattling sound when I open the fridge door. Any idea why?
first thing to check is the light bulb, take the light bulb out and see if noise stops.
Mar 12, 2018 | GE Refrigerators
Car garrage door opener
smart or learn button is located on the back of the garage door opener. (the machine that is over your head) on most units such as liftmaster, craftsman, chamberlin. its on back or side by the light bulb and is green, yellow, orange/red, purple. genie units are black button behind light cover. or external on old units. push and hold your cars homelink button will blink slow, at the same time push and hold the remote for the garage door. led light in car will blink fast. let both go. now go to the garage door head unit, (overhead) and push the learn button. button will blink and you have 30 sec. to go to car and push the cars garage door button. head unit should flash its light, letting you know that it is programed succesfully. genie units push 3 times
Dec 10, 2013 | Building Materials
Kenmore electric dryer series 70 makes loud buzzing noice
Sounds like you have a motor problem draging and it can't get started I just replaced one same problem.
Apr 24, 2010 | Kenmore 63942 Dryer
Whirlpool LER 5436 tumble drier- loud buzz
When start button is pushed there is a buzzing noise but dryer will not start.
Oct 21, 2009 | Whirlpool LER4634J Electric Dryer
Ref light bulbs and noise no cooling wh-pool GS5SHA
I had the same problem. There is a main controller board at the bottm of the refrigerator near the back by the compressor motor. One of the components on the board shorted out and the board had to be replaced. Total cost about $150.
May 30, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Fridge and freezer not cold. Loud buzzing and clicking intermitently. Lights flashing to say door is open and all freezer temperature lights are all flashing too
Read this article on Compressor Relays to understand the problem you are having.  It will explain in detail what to do to repair your machine.
Thanks, Bill
Nov 09, 2008 | Whirlpool Refrigerators
Loud Buzzing Noise from Behind Freezer
Sounds like the freezer fan blade is hitting on a build up of ice or frost. You may have a defrost issue, or it may be a one time thing, like the door was open for a long time (object holding door partially open) or also check the ice dispenser duct door to make sure it is closing. Sometimes a chunk of ice hangs up in the ice shoot, allowing moist air to enter freezer, resulting in the extra frost / ice near the freezer fan. You might also check the door gaskets, especially the bottom side where sugary liquid spills might cause a gasket to tear. #2: Long run times: If cooling is good, don't worry. Older refrig's often ran less time, but used much more electricity than the newer refrig's, even though new one run longer. (Like having a 40 watt light bulb on for 20 hours a day uses less electricity than having a 100 watt bulb on for 10 hours a day)
Aug 27, 2008 | GE PFS22SBSSS Stainless Steel French Door...
BUZZING NOISE ON WHIRLPOOL GOLD FRIDGE/FREEZER
YOU MAY HAVE A BAD LIGHT BULB, SOCKET OR LIGHT SWITCH. TRY WIGGLING THE SWITCH TO SEE IF THERE IS ANY CHANGE IN THE BULB INTENSITY. IF NO CHANGE, TRY REPLACING THE LIGHT BULB. IF NO CHANGE, THE SOCKET NEEDS REPLACED.
Apr 08, 2008 | Refrigerators
FREEZER SOUNDS VERY NOISY
that because the internal fan is hiting the ice or has bad bushings you can hear the noise just with the door close because when you open the door there is a switch the one turns off the internal fan so when you close the door it turn on the fan again if you wants to hear that with the door open just open the door and push the botton swich with your fingers and you'll hear the noise
Dec 29, 2007 | Freezers
Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System Logo
119 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
