Question about NEC MultiSpin ND-1100A (ND-1100A) DVD+RW Burner
Jumper setting in cpu - NEC MultiSpin ND-1100A (ND-1100A) DVD+RW Burner
  • 33 Answers
Not sure what the CPU has to do with anything! The following might help with CD/DVD drive jumper settings:
http://www.computershopper.com/storage/howto/installing-a-new-dvd-burner4
Posted on Jan 17, 2014
What is the responsibility of jumper setting to mother board
When a jumper is placed over two or more jumper pins, an electrical connection is made between them, and the equipment is thus instructed to activate certain settings accordingly. For example, with older PC systems, CPU speed and voltage settings were often made by setting jumpers.
Oct 07, 2013 | Computers & Internet
Imperial gl ve 20020930 SPECS
TriGem (Company) Imperial GLVE (Model)
http://h10025.www1.hp.com/ewfrf/wc/document?cc=us&dlc=en&docname=bph07813&lc=en#N779
http://www.trigem.co.kr/tgservice/econsult/faqProduct04.asp?cls=0&Page=&ID=4237&C1=1&C2=68&C3=359&C_N=IMPERIAL-GLVE
Hmmm, I'm at a stalemate.
Looking at the specs for the motherboard chipset;
The Northbridge and Southbridge chip,
Intel 845GV
http://en.wikipedia.org/wiki/List_of_intel_chipsets#Pentium_4_chipsets
Supports CPU's with a 400MegaHertz Front Side Bus, or a
533MHz FSB.
Naturally I can't get a clear picture of those jumpers, but they look to be 3-pin.
If we are to assume that the jumper pins set the CPU FSB support, from 400MHz to 533MHz, then the jumper cap is moved from either
Pins 1 and 2, to Pins 2 and 3; on J2 jumper;
Or Pins 2 and 3, to Pins 1 and 2.
I know !O_O!
Sort of a guessing game, as to where the jumper cap goes to what pins, for 400MHz FSB support, or 533MHz FSB support.
Do you have any idea of what the FSB is for the old CPU (Processor), that was in the motherboard? (Or is)
Let's say 400MHz.
You now know if the CPU you are wanting to use, needs 533MHz Front Side Bus support, you need to move the jumper cap to the opposite pins.
What happens if it's wrong? Nothing. processor just won't work.
Change the jumper cap back.
(NOT plugged into power when you do. Also FOLLOW Anti-Static Precautions)
Yes. I'm 'out there on a limb'
I am assuming after looking at the TriGem support page, for the Imperial GLVE motherboard, that the J2 jumper is used to change the FSB support for the Processor.
It MAY be that J2 has Nothing to do with CPU Support.
It may be that there is no jumper for changing CPU FSB support.
(Cleared that right up, huh? Geez!)
For additional questions please post in a Comment.
Regards,
joecoolvette
[J1 = FDD. Floppy Disk Drive
J2 = CPU FSB jumper
J3 = CMOS Setup
J4 = CMOS,
IMHO ]
Feb 19, 2013 | Computers & Internet
Hi! I just made a cpu swap on my asrock p4 combo from socket 478 - 775, the new cpu is the 570J 3.8 ghz 800 mhz fsp 1 mb chache ofcourse i looked at the manual and changed the jumper settings from...
According to the Asrock site, the CPU you chose should work in your board. You are going to have to check the jumper settings, (see the manual page 11) jumpers J1,J2,J3,J4,J5,J6,J8,J9,J10,J11,J12,J13,J18,J21 only. You indicated that you also changed J7,J14,J15,J16,J17,J19,and J20 since your statement was "i looked at the manual and changed the jumper settings from J1-J21"
Also make sure you do not have a jumper block on the CLR CMOS down near the battery. If you left a jumper on, it will not boot
Also, make sure you installed the CPU correctly and did not accidentally bend a pin on the underside. see 2.2 on page 12 Installing the 775.
Dec 23, 2010 | Asrock P4 COMBO...
2600+ with ASUS MB A7V266-E/AA
Here is the CPU Support list from Asus Support, for the Asus A7V266-E,
http://support.asus.com/cpusupport/cpusupport.aspx?SLanguage=en-us&model=A7V266-E/AA&product=1&os=17
Scroll down the list. 34th one down, that is listed.
1.Did you get the Athlon XP 2600+ that has a 266MegaHertz, (MHz), Front Side Bus? (FSB)
The AXDA2600DKV3C?
There is an Athlon XP 2600+ that has a 266MHz FSB, and one that has an FSB of 333MHz. <-This one Won't work.
Model number ->AXDA2600DKV3D will Not work.
Both are Thoroughbred A/B Core models.
The AXDA2600DKV3C has a 12.5x multiplier.
Your 1900+ has a 12x multiplier. (AXDA1900DUT3C) They both have an FSB of 133MHz. (Shown as 266MHz because AMD processors are 'Double-Pumped')
A.The AXDC2600DKV3C will not work. It has a 16x multiplier. (Thorton Core)
B.The AXDC2600DKV3D will not work. It has a 333MHz FSB. (Thorton Core)
C.The AXDA2600DKV4C will not work. It has a 15x mulitplier. (Barton Core)
D.The AXDA2600DKV4D will not work. It has a 333MHz FSB. (Barton Core)
E.The AXDA2600DKV4E will not work. It has a 400MHz FSB. (Barton Core)
2.Are the jumper blocks -> CPU RATIO, and SYSCLK, still set in the Jumper Free Mode?
By the factory default settings these jumper blocks, (DIP switches), should already be set to Jumper Free Mode.
The white DIP switches should be in the OFF position. (The white switches will be DOWN, towards the numbers on the jumper block CPU RATIO. They will be UP, away from the numbers, on the jumper block SYSCLK))
The CPU RATIO jumper block is right above the processor. It is a blue rectangular block.
The SYSCLK jumper block is down the motherboard, right below the AGP graphics card expansion slot. (And above the first PCI expansion slot)
If those two jumper blocks are not set to Jumper Free Mode, set the DIP switches in the jumper blocks to this setting.
Now go into BIOS Setup. In the main menu use the Right Side Arrow key on your keyboard, and highlight Advanced.
If -> CPU Speed is set to Auto, you won't have access to set your CPU parameters. If it is set to Manual, you will see them. If it's set to Manual, write down the headings, (CPU:System Frequency Multiple, System/PCI Frequency (MHz), and so on) Write down the numbers to the right of these headings. If something goes wrong, you can go back into BIOS Setup, and change them back.
1.CPU:System Frequency Multiple should be
12.5X
2.System/PCI Frequency (MHz) should be
133/33
3.System/DRAM Frequency Ratio should be
(Auto)
4.CPU Vcore should be (1.750)
5.CPU Level 1 cache, and Level 2 cache should be (Enabled)
6.CPU Level 2 cache ECC Check should be (Disabled)
7.BIOS Update should be (Enabled)
8.PS/2 Mouse Function Control (Auto)
9.USB Legacy Support (Auto)
10.OS/2 Onboard Memory >64M (Disabled)
Leave the rest alone.
The AXDA2600DKV3C uses 1.65 volts, has a 12.5 clock multiplier, and a 266MHz FSB. (You will see 133MHz, and set all your settings to 133MHz. AMD processors are 'Double-Pumped'. Intel processors are 'Quad-Pumped')
Aug 10, 2009 | ASUS A7V266-E (A7V266-E AA/PA/WOR)...
ECS P4IBMS Motherboard CPU Voltage Jumper Settings
I don't believe that there is a P4 motherboard that needs jumper setting to specify the CPU voltage. This used to be common for Pentium & Pentium II motherboards, & some Pentium III motherboards. But I have never seen a Pentium 4 motherboard that require this kind of setting.
Besides, I checked the motherboard's manual & I saw that there is a sub-menu in BIOS labelled "Frequency/Voltage Control". This should be the place where the CPU voltage should be set, & on most motherboards, CPU voltage & frequency are automatically detected.
Jun 20, 2009 | EliteGroup ECS P4IBMS Socket 478pins...
MSI 845GE MAX L MOTHERBOARD JUMPER SETTINGS
Hello!
If the motherboard is new or you never set any jumper setting or you did not interfere any connection seeting their then you yo did not need jumper setting to seat the CPU.
The CPU you are going to use is very compatible in your mainboard so do not worry about the setting.
more about your setting click here for the usermanual of your board.
hope this help, melnavz
Feb 25, 2008 | MSI 845GE Max-L (MS-6580-060) Motherboard
SL-86SPE-L Motherboard manual and / or bios jumper settings required.
Load fail safe defaults from CMOS/ deseabled the CMOS.
OR press F5 when booting & continue.
Feb 18, 2008 | Soltek SL-86SPE2 Motherboard
Motherboard Jumper free code
Set Jumper Free Mode (manual) and new FSB in BIOS Setup - menu "CPU External Frequency (Mhz)".
Oct 24, 2007 | ASUS P4SP-MX Motherboard
NEC MultiSpin ND-1100A (ND-1100A) DVD+RW Burner Logo
Top NEC Computers & Internet Experts
parusdi rusdi
Level 1 Expert
Steven Wander
Steven Wander
Alun Cox
Are you a NEC Computer and Internet Expert? Answer questions, earn points and help others
