Question about Stanley Bostitch F21PL Nailer
Sparks from nailer
Every time I pull the trigger I get lots of sparks shooting from the place where the hammer strikes the nail. The gun is brand new.......
  • 285 Answers
Do not worry.This is quite normal. It is the metal driver hitting the head of the nail.There are no electrical components in a pneumatic nail gun so this is pure metal-on-metal strike sparks. You may find it is more visible on certain nails than on others. But do not worry. It is normal. You may find the sparks reduce after time as the driver wears a little or takes on a certain shape.
All sounds normal though. Do not worry :)
Please rate this solution on FixYa!
Posted on May 29, 2009
Www.dewalt.com
Worn trigger valve orings will cause gun to fire twice, and /or attempting to single fire nail with bump-fire trigger. Easy test, look closely at firing pin under trigger. It should fit snuggly an not move from side to side in valve. If loose, replace valve. If your nailer has bump-fire trigger, do no attempt to place gun then fire one shot because the gun will most likely double fire. Good luck.
Oct 09, 2012 | Porter Cable Coil Roofing Nailer
Nail gun problem
This is a bottom fire tool. (NV83A2) You need to hold the trigger down and then as you place the nailer to the wood the safety will depress and it will fire once. This is usually done in one, swift action. If you do this in the opposite way by placing the tool to the wood and then pulling the trigger they often will double fire.
Jul 05, 2012 | Nailers Hitachi Nv83a2 3 14" Coil Framing...
Hitachi NR83AA shoots two nails on one pull of the trigger?
Best practice is to bump fire the gun to prevent double fire. Do not place the gun on the work and pull the trigger. This takes practice while using at an angle. Works better if the nose piece has rather sharp points to help nose to stay in postion while you bump. With trigger depressed, practice without nails bumping/hitting wood at different angles untill you can bump hit at the spot that you need the fastener. If the gun double fires while bump-firing, most likely all the safety/trip parts are worn/loose. Not expensive to replace. Good luck.
Jul 05, 2012 | Air Tools & Compressors
Why does my roofing nail gun jamming, it would fire one nail and the hammer will remain out, so i toke a screw driver and push the hammer back in, and it still did the same thing
Simple test for piston jam. With nails removed and latch open, point nose of gun up then down. If the driver slides up and down in the cylinder as you move the gun, replace the piston oring (test gun for proper operation). If the piston stays in the upper most position as you move gun (push driver to top position), check lower bumper and bottom seal under the bumper (sheet). Replace as needed. If the lower parts are in good condition (good piston oring, lower bumper and sheet) , replace the 3 orings on the feeder piston. Good luck
Dec 03, 2011 | Hitachi NV45AB2S Coil Roofing Nailer
Jammed nail gun fc350a
Nail guns will jam when driving nails thru very hard wood, solid objects, allowing the gun to double fire hitting the first nail or using the wrong nails(amoung some of the reasons, you get the idea that jamming is common) . There is no special tool to help in case of jam. You must be creative. I use an old driver shaft from nailer that easily fits into the nose of the gun (you can grind a piece of allen wrench to fit into nose and allow space for the stuck nail). The metel that you use must be very hard and strike with heavy copper or brass hammer (caution, steel hammer may splinter metal, use protective gear ). You will need to strike very hard to remove some stuck nails. If first or second strike results in no movement of driver, remove the head and cylinder of the nailer and place the body of the gun squarely on piece of plywood over concete floor (this will protect the head of the nailer from being damaged). Worst case, you will need to remove the rails. Good luck.
Jun 25, 2011 | Porter Cable Factory-Reconditioned...
Nail gun shoots 2-3 nails, not one. last week 2 of them hit me in the thumb. has been doing this for years. I have put up with it because I did not know what to do about it.
Most nailers work better by bump firing the gun. Less likely to double fire. This is a common problem amoung brands. If you place nailer on work then trigger, you may/will have problems as you describe. There is usually an option of triggers or builtin method of single firing the gun. With single fire trigger, you can place gun on work and fire. The will not reset for next round untill you let go of trigger and lift gun off the work. If your gun is double firing even with bump method, then replace the trigger valve.
Nov 16, 2010 | Nailers 3 12" Pneumatic Air Round Head...
Brand new unit. Used last weekend, no problem. Today, won't shoot nail. Air is released when trigger pulled, but no nail plunged.
Orings /other parts tend to stick when nailer is new. Dewalt uses some vinyl orings that have been causing premature failure. Be sure to add a few drops of oil when used. Too much oil is not good. Wrong oil will cause orings to swell and cause problems such as yours. Your nailer's firing valve can be reset by rapping the nailer against rubber surface such as a thick rugger mat or coiled rubber air hose. Remove airline and nails, being carefull not to damage the head, rap had against rubber mat and retest gun. If it did not reset rap against nose of gun and test. If no joy, you will most likely need to remove head and manually move cylinder up/down and /or check vinyl orings for failure. Before you try to reset the gun, make sure that the safety is pushing the firing pin all the way in. Air removed, look under the trigger as you push down on safey, if it does go all the way in try bump-firing the gun (for test have nails removed). Hold in trigger and quicky /firmly strike gun against rubber pad. Good luck
Nov 14, 2010 | Dewalt D51850 Heavy Duty 20 Degree Full...
Senco 601 nailer shoots 2 nails each time the trigger is pulled.
the 601 had a design flaw, in the nose, where the nails hit as the are being pushed forward, the peice was made out of a peice of metal that was too soft, it wore down and that is where you get the double nail problem.
Senco offered a trade in, this was years ago, for a limited time and gave us credit towards new guns, which we gladly did
Dec 31, 2009 | Senco & Frame Pro 601 Framing Nailer
I have a hitachi nv 65 ah that will shoot two nails at time
I hope this doesn't offend you. What I'm suggesting is that you may not be using your nail gun correctly. Some people keep the trigger pulled and bounce the gun onto the wood. This technique works okay, but placement accuracy of the nail suffers. The other technique is to place the gun on the wood and pull the trigger USING TWO HANDS! This is the technique suggested by the manufacturer. The problem with this technique is that if you apply insufficient pressure to the gun (USING ONE HAND) the safety is not engage so you don't shoot a nail. What usually happens - I just witnessed this a couple of weeks ago - is that not enough pressure is applied while pulling the trigger so you push harder and end up bumping the gun which shoots a nail - because you have the trigger pulled, but the nail shot was a surprise so it causes another bump (and is more apt to bounce because you're using just one hand). Because it is a machine and can operate faster than your reflexes - it shoots another nail. This happens before you can lift it off of the wood, or remove your finger from the trigger. That's the reason I keep the trigger pulled and bounce it. I know that after the bounce I've set a nail, and can remove my finger from the trigger. When I need to accurately set a nail I always use two hands, press hard and pull the trigger, and release quickly. Only pull the trigger when you know you're about to set a nail, and are poised above the workpiece.
Dec 09, 2009 | Air Tools & Compressors
The nailer shoots a nail when the trigger on the handle is pulled irreguardless of the hammer being used to strike the head
I found a broken retainer ring in the head of the nailer. It had the striker head jammed in the down position so when you pulled the trigger to arm the head with air pressure, the flooring nailer shot a nail.
Thanks ..
Apr 18, 2009 | Air Tools & Compressors
Stanley Bostitch F21PL Nailer Logo
198 people viewed this question
Top Stanley Air Tools & Compressors Experts
John Trevino
yoopertech
Joe Garcia
Joe Garcia
Are you a Stanley Air Tool and Compressor Expert? Answer questions, earn points and help others
