Question about Mitsubishi VS-50501 50" Rear Projection Television
Has problems powering on
It started with the alignment
Everytime I start my printer I get a message to realign while there is NO problem with the alignment.
The printer alignment has to be completed as below,
  1. After printer prints the alignment sheet.
  2. Place the printed sheet on the scanner bed and press "start scan" or "start color copy".
  3. Wait untill the printer Power light stops blinking.
  4. Now turn off the printer and turn back on.
  5. Printer will not print alignment sheet.
Regards
Riztech
May 29, 2011 | HP PSC 2175 All-In-One InkJet Printer
My laptop is Compac presario CQ40. it's screen goes blank i can hear the voice which is running but screen goes blank and i have to shutdown and start afterward but the problem persist. My laptop work...
1. Faulty RAM - try to remove, clean, re-align.
2. Remove battery, press power button for at least 30 secs. w/o AC power. Attach to AC power without
battery. power on. Hard reset
3. Faulty Processor - very risky of dismantling and aligning processor.
4. MOBO problem.
Mar 15, 2011 | Computers & Internet
Changed cartridges, printer doesn't align or function
Something seems to be physically wrong in the mechanism.
Try the rolling wheels and the belt on which the cartridges run.
Jul 19, 2010 | HP OfficeJet 6110 All-In-One InkJet...
1997 Ford Probe that keeps throwing alt belts
There was a service bulletin in the 90's about the power steering pulley alignment. It is pressed on and some of them caused a belt misalignment issue. Over time, your pulleys and bearings have worn causing this problem to be exaggerated. The first place to start is checking the condition of these pulleys and bearings. Visual signs of wear and looseness of bearings are easily checked by a qualified technician. A worn tensioner can change the belt alignment at different positions. It may look good at idle, but may tip to one side as it adjusts going down the road. Pulley alignment is usually checked with a simple string lined up on all pulleys (in the same groove of each pulley). If one pulley is out of alignment with the others, the belt can easily walk off over time. I have also seen a different brand of belt being just a bit shorter, causing misalignment of the tensioner. So start with a good visual inspection and go from there. A helping hand is good when checking pulley alignment from different angles. This problem CAN be fixed! I hope you find a conclusion to your problem.
Sep 19, 2009 | 1999 Ford Taurus
Power steering is stiff some times on my kia sedona
It might be a failing power steering rack as well...classic symptoms are very stiff when first starting vehicle or at a stoplight, then loosens up as rpms increase.
Aug 10, 2009 | 2004 Kia Sedona
Aligning cartridges, please wait
Pressed ok more than once to start alignment??
Have you worked through this page already? And you tried the "Bypassing the print cartridge alignment" solution? See HP's solution here. Make sure you don't have photo paper or colored paper in the input tray when aligning...
When you perform the reset, did you unplug the data cable (usb) as well as the power, and wait a few minutes? Try leaving both data and power cables unplugged for 1/2 hour and then resetting, and make sure you complete the power cycle by pressing start copy color. Link here.
If none of these steps work, try removing and reinstalling the cartridges, and if that doesn't help, here's a last ditch fix that may work in your case.
Otherwise, I'm afraid service is the answer...
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
May 23, 2009 | HP Officejet 5610 All-In-One InkJet...
It automatically print a page everytime I start my hp psc 1315
Hi Siddarth
In HP PSC 1315 printer after replacing new Ink Cartridges the printer always prints Alignment test page every time you turn it ON.To resolve this problem you must complete the alignment process.
Steps
1.Turn the printer ON.
2.Once its ON, it will print the Alignment page. Place the page in the scanner bed correctly.
3.Then Press START SCAN button.
4.The power light will start blinking, wait until the power lights turns solid.
5.Now Alignment process is over.Discard the paper from scanner.
6.Turn the printer OFF and then ON, it will not print that page again.
Note:Please follow this steps every time when you replace the Cartridges.
Thanks
Rizwan
rizwan84tx@gmail.com
Dec 08, 2008 | HP PSC 1315 All-In-One InkJet Printer
WHEN I TURN ON THE PRINTER IT STARTS TO PRINT THE ALIGNMENT PAGE
Hi Mahdavi,
Steps
Thanks
Rizwan
Dec 06, 2008 | HP PSC 1315 All-In-One InkJet Printer
ALIGNMENT PROBLEM
try doing incremental resets.
start with a partial reset:
press the # and 3 buttons simultaneously, and while holding them down, unplug the power cord from the back of the printer. wait 3 seconds, while still holding down the buttons. Then plug the cord back in. Wait until the LED will prompt "partial reset" and release the buttons.
try to align again.
if the problem persists, do a semi-full reset:
Same instructions as above, but this time use the # and the 6 buttons. Wait until the LED will prompt "semi-full reset" and release the buttons.
try to align again.
Feb 17, 2008 | HP Photosmart 3310 Printer
Hp Photosmart C3180-start-up
Okay, just chatted online with an HP tech, and she helped me solve the problem!
She said: the printer prints an alignment page everytime you turn on due to incomplete initialization process.
Turn off the printer and Turn on.
Please unplug the usbcable.
  1. Lift the scanner lid of the product.
  2. Place the top of alignment page face down in the left front corner of the glass.
  3. Place the alignment page face down
  4. Close the scanner lid of the printer.
  5. Press the Scan button.
  6. The On/Resume light will blink during the alignment process.
  7. After the On/Resume light stops blinking, alignment is complete.
  8. Turn off printer and Turn on.
It shouldn't print the alignment page any more! :)
Hope this helps!
Jan 01, 2008 | HP Photosmart C3180 All-In-One InkJet...
Televison & Video Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
