Cfd-758 sony cd lens
How or where do you clean the lens?
3 Suggested Answers
  • 3 Answers
SOURCE: Sony CFD-G500 cd player
There is an inherent problem with this unit that is not the reader. I noticed that the red light which comes on when the super base is activated will sometimes flash while the unit is first trying to read the CD. It seems to be in sync with the disc spinning motor of the CD player. I have repaired a couple of these by checking and resoldering poor quality solder joints on the CD sub board and a few on the main circuit board. But this has not repaired all of them. Sony need to look into this.
Posted on Apr 02, 2009
falspet
  • 438 Answers
SOURCE: Does not detect CD in drive.
do you have it apart enough to view the CD transport mechanism ? if i so is the CD spinning up ?
over time the laser brightness diminishes and is not eluminating the cd proporly, there is a brightnes controll on the laser assembly, this can be ajuusted to a small degree to restore oporation, mark the original position of the control, the controll is located on a small pcboard where the plug enters the laseser asembely, turn the controll clockwise only about 5 to 10 percent, now atempt to read a good known cd, if it reads, leave it, if not turn the controll counter clock by 5 to 10 persent of the original poition, now try the cd again, if it works leave it, if not the laser may be defective and needs replacing, all this is asuming that the lense is cleen so prior to ajustment cleen the lense, also insure the lense is in place, some lenses have fallen off in my past experiances, and may be rateling around inside the unit, don`t lose it, you can very carefully glue it back in place using crazy glue, the assembely is quite easy to replace, you will see when you have it apart, if you can find a new one for a reasonable price this may be an option for you, one other thing, observer the carage, note if it seems to slide tho the center and then position itself a small portion away from the center this happens only when the unit is trying to read a CD , if so good, if not this may be due to a defective home switch used to position the laser over the appropriate track to read the directory of the CD, you can see the switch, and can be easily replaced, you will know how when you see it, that's what i know so now you know, good luck
Posted on Jan 31, 2010
How to replace cd sensor on sony CFD-ZW775
Have you tried trying a different disk, blowing on the detecting lens or cleaning the disc?
Jul 22, 2012 | Computers & Internet
My Sony CFD-S33 CD player has started only playing 10 min of each CD
Clean the optical pickup lens, by inserting a lens cleaning disc into the player. If it do not help you, repalce the optical pickup unit. Sony sets will have special type optical picku units. You might have to contact the authorised service center for Sony at your town, to get an original one.
May 22, 2012 | Sony Cfd-s33 Cd Cassette Recorder Am Fm...
Sony CFD-F10 wont play cds, says no disc
how long have you been using this player? The problem should be from the lens (laser).
The lens is weak and that's why it cannot read/load Cd's. The weak lens is also what's making it say "no disc".
Get a lens cleaner and use it to clean the lens, but if the lens still does the same thing even after using the lens cleaner, then it means you would have to change the whole lens completely to a brand new one.
By so doing your player would play all Cd's with no problem at all.
Good luck.
Feb 14, 2011 | Sony CFD-F10 Radio/Cassette/CD Boombox
My sony cfd zw155 will not play cd's they start to revolve and then stop and display reads no disc
The internal laser lens might need cleaning due to dust build up with a CD Cleaner or the Lens has Become faulty but most of the time it will be a dirty lens
Apr 03, 2010 | Sony CFD-ZW155 Cassette/CD Boombox
My sony CFD-E100 won't recognize CDs
use a cotton swab to clean the optical lens-which is seen by opening the CD cover. if after cleaning the lens it still doesnt play a cd - exercise all manual switches(could be a dirty cd/radio switch), several times. after these steps, and the cd still refuses to spin...its hopless. the optic is bad.and not economical to repair. bet the cotton swab does the trick.
Mar 04, 2010 | Sony CFD-E100 Boombox
Sony cd radio cassetteplayer says no disc when disc is in player
Make sure your cd medium is compatible with your Sony unit. Some cd types that have been burned on a computer may not be compatible. Check your instruction book for your Sony unit to see what types of cd medium you can use.. Also, the lens on you cd player could be dirty and may need a cleaning CLICK HERE to see the Radio Shack lens cleaner. You can also get them at may other locations like Walmart, Target, Sears, and Best Buy. Good Luck! : )
Nov 10, 2009 | Sony CFD-F10 Radio/Cassette/CD Boombox
My cfd-510 radio wont play cd's how can i fix it? everytime I try to play a cd it atempts to but can't
Open up the top and try cleaning the lens using a cotton swab and alcohol. If that fails to resolve the problem, then the optics need to be replaced. These units use KSS-150 optics, I think. These are still available (or a substitute) for around $20 for the part.
Dan
Sep 18, 2009 | Sony Boom Box With CD Player & Cassette...
My CFD-Z501 won't play a disc. I get the message "no disc"
Try to use CD/DVD clening disk ($6 in Walmart). Or simply use cotton swab (Q-TIP) and 40 % ethyl alcohol (vodka) or 50-70% isopropyl alcohol (NO ACETONE), depending on your budget.
Also check if discs are inserted correctly and not damaged/durty etc. Also check your discs. Some CD-players dont accept burned CDs (copyed). I believe Sony is not the case, just a suggestion.
If cleaning wont help lens might be damaged.
Good Luck
Jan 26, 2009 | Sony CFD-Z501 Boombox
Sony CFD-S300 boombox would not run CDs
what i would suggest you to do is get a q-tip and a little bit of rubbing alcohol on the tip and gently clean the lens let it dry
May 22, 2007 | Sony CFD-S300 Radio/Cassette/CD Boombox
42 people viewed this question
 Grubhead
Grubhead
