Question about Microwave Ovens
Set the time
How do I set the time on a chef sapphire electric elevated oven
2 Suggested Answers
ZJLimited
  • 17970 Answers
SOURCE: How to set and use
USING THE TIMER AND CLOCK
Using the 60 minute ringer timer
To set the timer:
1. Turn the knob clockwise to the required number of minutes. When the time has elapsed the timer will give a short ring.
NOTE: For times below 20 minutes, turn the knob past 20 minutes and then back to the required number of minutes.
Using the 2 hour cut-off timer
* Manual operation
The timer needs to be set at the "O" marker so that the oven can be used manually.
* Automatic operation
The 2 hour timer features an automatic oven "cut off".
This means that a cooking period of up to 120 minutes can be set.
1. Set the Oven Temperature Control Knob to the required temperature.
2. Turn the cut-off timer clockwise to the required number of minutes. For timer settings of less than 20 minutes, turn the knob past 20 minutes and then back to the required number of minutes. (Purpose - to set audible ringer.)
3. When the timer returns to "Auto Off", the timer gives a short ring and the oven will be switched off.
4. The oven will not operate again until you turn the timer back to the "O" marker.
NOTE: It is not recommended to use this timer for short duration, e.g. boiling eggs.
OPERATING THE PROGRAMMABLE CLOCK
WARNING
• The Clock MUST be set to operate oven.
General features
Your 3 button programmable timer has the following features:
• Timer - your 3 button programmable timer allows you to set a countdown time that will beep when the set time has elapsed.
• Cooking duration - You can set a cooking duration. A timer will count down the preset cooking time, beep when the time has elapsed and turn the oven off.
• End cooking time - you can set a cooking finish time. A timer will count down the preset cooking time, beep when the finish time has been reached and turn the oven off.
• Delayed start cooking time - You can combine the cooking duration and cooking end time to switch the oven on and off at a specific time during the day.
NOTE: Your 3 button programmable timer only operates
Change the time of day (Daylight saving)
1. Press the "mode" button until the "clock" indicator II begins flashing.
2. Press the - or + buttons to change the time. 5 seconds after the last change, the "clock" indicator II will disappear, confirming the time has been set.
Setting the timer
1. Press the "mode" button until the "timer" indicator II begins flashing.
2. Set the countdown time you want by using the - and + buttons. 5 seconds after the last change the "timer" indicator II will stop flashing, confirming the timer has been set.
3. To stop the beeper, press any button.
Setting the cooking duration
1. Check the clock displays the correct time of day.
2. Set the oven to the desired temperature. The oven indicator II light will glow and the oven will come on.
3. Press the "mode" button until the "cook time" indicator II begins flashing.
4. Set the cooking duration you want by using the - or + buttons. 5 seconds after the last change, the "cook time" indicator II will stop flashing, and the time of day will be displayed.
NOTE: Do not forget to add preheating time if necessary.
Setting the cooking end time
2. Select the desired oven function temperature. The oven indicator II light will glow and the heating source will come on.
3. Press the "mode" button until the "end time" indicator II begins flashing.
4. Enter the time of day you want to finish cooking by pressing the - or + buttons. 5 seconds after the last change, the "end time" indicator will stop flashing and the current time of day will be displayed.
Setting the delayed start cooking time
1. Program the "cook time" and "end time" as described in the relevant sections. Once both the "cook time" and "end time" have been set, the "cook time" and "end time" indicators will stop flashing and the current time of day will be displayed.
To check or cancel settings
1. To check your settings, press the mode button until the setting you want is displayed. A red light will flash next to the mode (cook time, end time etc) that is currently on display.
2. To cancel "delayed start" press the mode button until a light flashes next to "end time". Press and hold the - button until the clock no longer reverses (you will hear a beep). If you have left the temperature knob at a setting the oven will start once the "end time" light stops flashing.
3. To cancel "auto shut off" press the mode button until a light flashes next to "cook time". Press and hold the - button until the clock no longer reverses at ("0:00" and you will hear a beep). This automatically cancels "delayed start". If you have left the temperature knob at a setting, the oven will start once the "cook time" light stops flashing. Because you have cancelled "auto off" the oven will continue to heat until you manually turn it off.
On completion of cooking
The heat source will turn off, the timer will beep and the "end time" and/or "cook time" indicators will flash.
1. Turn the temperature control to the off position.
2. Press any button to stop the timer from beeping.
Accordign with the user manual. Hope this helps.
Posted on Jun 15, 2011
Magic chef MCD1611ST microwave, the display lights up, the time and powerlevel can be set, the light works when the door is open but when i hit start everything shuts off. Any suggestions?
There are a lot of possible causes, but I'd look at the door switches first, and the wiring connectors to them. Make sure the contacts on all the switches are opening and closing.
Nov 19, 2016 | Magic Chef MCD1611ST Microwave Oven
My magic chef microwave died. I replaced fuse, and electrical works but won't cook. Why?
Most likely if the fuse blew the part that creates the microwave energy is defective, it is called the "Magnetron" Just replace the oven is my suggestion.
Nov 11, 2016 | Magic Chef Microwave Ovens
How to set up the clock?
No sweat, really easy. press clock button once for 12hr twice for military time, then enter time, press clock button again.
Magic Chef MCD1611ST Instruction Manual Controls Setting The Clock Time...
Mar 31, 2015 | Magic Chef MCD1611ST Stainless Steel...
Electrical wiring for mcd 1611st the microswitch the normally open and normally closed
Many micro switches have markings of "NC" and "NO" and "C" on them; indicating which terminal is what. You might be able to get a schematic for this on the Magic Chef web site.
May 06, 2014 | Magic Chef MCD1611ST Microwave Oven
My magic chef microwave, model # iMCO160S,lost power, not during use. I have checked electrical connection and is OK. Do i need to change a Fuse ?
Fuses are a common failure part. If the fuse, you can purchase ceramic types from Electronix: http://www.electronix.com
Sep 03, 2011 | Magic Chef MCD1311ST Microwave Oven
I am unable to set my clock on the Magic Chef MCM1110 W/B Microwave Oven I just purchased following the Instruction Manual
Typically all you have to do to set the clock is to press the Clock button, enter the time, and press Clock again. However on some models, clock set is accessed through the main menu, by pressing the Help button and following the prompts.
Aug 17, 2010 | Magic Chef MCD1110ST Microwave Oven
OVERHEATING - Magic Chef Microwave M# MCO160S
Generic questions and comments:
Does your microwave have a "popcorn" setting and are you using it? Is there a rotating table in your machine? Is your popcorn bag elevated on top of a bowl or similar? Are you using some other "sensor" setting? Can you use straight time setting and get it to go past the 1 min 45 second mark?
On my microwave, it takes just about that much time and the popcorn is done ... BUT only if I elevate the bag to about the middle of the oven.
Let me know if this works for you.
a
Sep 21, 2009 | Microwave Ovens
Magic Chef Over the Range, MicroOven, model MCO153UBF
I tried the usual things, then checked the outlet in the cupboard where the unit is plugged in.....It was okay, but then I noticed a separate electrical cable going into the wall at the outlet. I went to the breaker box downstairs, found a breaker marked "Microwave Oven", flicked it off and on and away the microwave oven went....It is now okay. I guess the thermostat had turned everything off when it became too hot....
anyway all okay now....thx Janet
Jul 22, 2008 | Magic Chef CMV1000B Microwave Oven
Microwave Ovens Logo
26 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
