Question about GE Refrigerators
Ge refrigerator shorts every time you plug it in the breaker pops"
Solution for "ge refrigerator shorts every time you plug it in the breaker pops"
    Problem Solver:
  • 9 Answers
I had this problem at one time the compressor went had to have it replaced as per the ref maintenance man.later learned that the problem could have been in the wiring onto the compressor check it out hope this helps.
Posted on May 22, 2009
Why ge washer not spin or agitate?
Check to see if any power to that outlet to see if you have some power by plugging in a light or other electrical device. No power? check circuit breaker for Washer electrical outlet. If it pops back, you have a short somewhere. Unplug washer then try circuit breaker again. If the circuit breaker stays on, you have a problem in the Washer. Call Service man or may be cheaper to find a lightly used replacement, or buy new.
Aug 31, 2014 | GE WBSR3140DW Top Load Washer
Please help my side by side ge fridge freezer is tripping our power I have had it for 2 year we moved houses I left it unplugged for three days in our garage then moved it into the house and plugged it in...
Check to make sure that in the process of moving a "hot" wire under the refrigerator did not come loose and now is contacting a metal part of unit.
U have a classic short circuit which accounts for the breaker popping immediately. It is not a short in the compressor because that would have popped the self resetting clixon and not the house breaker.
May 01, 2017 | Refrigerators
GE AEH10AMG1 was working fine a week ago. Plugged it into the same socket yesterday, and the breaker in the plug popped, and it keeps popping when we try to plug in the unit.
You have a direct short in the A/C unit probably at the compressor or your condenser fan motor. You can disconnect one component at a time to identify where it is shorting. turn power off unwire condenser fan motor secure wires so they dont touch anything plug unit in if it still pops breaker your compressor is probably bad.
May 19, 2011 | GE Heating & Cooling
Refrigerator has electrical short causing GCI outlet breaker to pop. Is this an easy or cost prohibitive fix?
It is possible you have a short. However, the more likely cause is the simple fact the refrigerator is plugged into the GFI outlet. Try this first, take a heavy duty three prong extension cord, NOT a lamp extension cord, plug it into a non GFI outlet, and plug the fridge into the cord. Does it trip your house circuit breaker? If so, then you do have a short. You will need to call a local refrigerator repair company to find the source of the short, and only then will you know if its an easy or cost prohibitive fix. If it does not, and it likely wont, the problem is that a GFI outlet detects a fault to ground. Due to the humidity and moisture inside a refrigerator, and normal water drainage sometimes into the metal base of the refrigerator, it is not uncommon for water to contact metal points inside and outside a refrigerator. Since all / most metal points on a refrigerator are grounded to each other, if water contacts any of them, they can and will trip a GFI outlet breaker, because it is detecting a fault to ground.
Nov 09, 2010 | GALAXY Microsystems 63702 Top Freezer...
New defrost timer on fridge keeps tripping circuit breaker
The problem is the defrost timer you just replace on your refrigerator, you will need to check the ratings on the broken defrost timer to ensure it matches the ratings on the present defrost heater on your refrigerator, beside, you will need to test the continuity on your present defrost heater to see if the voltage rating is ok, because, if it can be tripping the breaker off while it kicks into defrost mode signify that the present defrost heater is not compatible with your refrigerator, it is either it is not well wired or fixed, and if it is, then, it means the defrost timer voltage rating is low compare to the former, you will need to get exact specification as the the broken one.
Take care.
Jul 10, 2010 | GE Refrigerators
Keeps popping the breaker
There is a short circuit inside. It may be from the heater. Or water would have entered some electrical switching area.
Open the back door and inspect !
May 19, 2010 | GE Nautilus 24" Built-in Dishwasher
GE Refrigerator--model TFX24ZRXA. Replaced water valve. Removed icemaker to replace the dispenser motor. Plugging in the icemaker causes the circuit breaker to trip now.
Obviously you have a short in your wiring somewhere. perhaps one of the terminals for the dispenser motor were not securely attached. Is there any water in either plug for the icemaker, since breaker trips when you plug that in? Did you plug icemaker in correctly? You can reply here or send me a question from my website: www.FixMyFridge.net
Mar 15, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
No electrical power
You must find the reason the main breaker is popping ...
I'd start by unplugging everything and remove all breakers. Turn the main on ... does it pop? If it pops here look between the breaker panel and the end of your cord. Turn the power off - reinstall the first breaker - turn power back on. What happens ... keep doing this until the main or individual breaker pops - investigate that circuit to find your short.
If you get all breakers back in with out popping anything ... start plugging stuff back in. Something is shorting somewhere.
Let me know what you find please.
thanks
a
Oct 06, 2009 | Hilltop Rv 60 AMP CIRCUIT BREAKER CARDED
Everytime I plug in the power cord, it trips the breaker.
Refrigerators are not designed to run on a GFCI. Try a heavy duty extension cord to the fridge from a outlet that is not GFCI protected. If it still trips you probably have a short circuit in the compressor.
May 13, 2009 | GE GTS22KBP Top Freezer Refrigerator
Side by side keeps popping breaker
It is very doubtful that a defrost heater would do anything by open (NOT short) so that is not a likely cause of you popping the breaker. I would look at the compressor relay and capacitor as more likely areas that would cause it. UNLESS the compressor is locked up and that would cause it everytime.
Oct 18, 2008 | Whirlpool GS6SHAXMQ Side by Side...
Refrigerators Logo
182 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Lawrence Oravetz
okcchemist
Level 1 Expert
