Question about Copystar CS-2030 Copier
Kyocera CS 2030 fax jams
I have  a CS 2030. every time I receive a fax the paper jams. The copier and printer work great. It just jams when a fax is received. Any thoughts or solutions would be appreciated.
If you have the internal fax tray, check where the paper is getting jammed. It may jam right @ the exit gate, which can be wiggled to proper position, or the white paper turn guide on the fuser may have notches worn it it from paper exiting from the copier. These notches can be sanded down with emery cloth or very fine sand paper to smooth.
Posted on Mar 30, 2008
  • 56 Answers
Hi,check settings for fax.Try to check paper attributes for fax.Maybe You have different paper format adjusted for fax printing.
Posted on Nov 14, 2007
Paper jam in tray one after receiving every photocopy in kyocera fs6525 wht's a problem ???
First make sure that tray is set up for correct paper size. That would be first thing. Check for paper dust in paper path blow it out. Really sounds like paper tray not set correctly.
Feb 23, 2014 | Kyocera Fs-6525mfp Copier, Printer,...
I have Kyocera Copier that is trying to print a fax and it keeps coming up JAM 40. How do I fix this?
JAM 40 is a fuser jam. Remove the process unit and make sure there is no paper there. Open the back cover and make sure there is no paper there. Turn the machine off then back on. If you are still geting Jam 40 then you have a bad sensor or similar issue.
Jun 10, 2011 | Kyocera Copystar CS-1820 Black and White...
How to troubleshoot kyocera when there's paper jam in printer
you have to know which jam code machine giving you that time easy for troubleshout the machine
good luck
Dec 07, 2010 | Kyocera Copystar CS-1820 Black and White...
I have a kyocera cs-1650 with the error message FAX MODE ERROR. can you help?
It is problem Program not properly configure.set up fax program,Fax line type,Receiving mode,number of ring count.Other help follow your copier User Guide manual.If you do not fix your problem then you call a service technician. who support this machine.
Dec 02, 2009 | Kyocera Copystar CS-1820 Black and White...
Copier jams after making one copy
Is the jam Physical? (Damaged lead edge where it may have caught some thing)
Is the jam Timing (paper if perfect, it just stopped.)
If it is Physical then you need to look for the obstruction, paper clip, staple, or small piece of paper. Check very carefully, remove any foreign matter and retry.
If it is a timing jam, the start by removing the paper, check inside the the paper feed area for foreign material, fan the paper and carefully reinstall it, making sure it is the right size paper for the paper cassette. if it has movable guides in the tray, be sure they are firmly against the paper on all sides.
Close up the machine and try again.
Hope this helps.
Apr 28, 2009 | Kyocera Copystar CS-1820 Black and White...
Paper Jam
Ok, The Copystar CS-1820 is a Lemon, as an Authorized Independant dealer for Copystar. I can attest to this. This is a common problem from Copystar and their's not much that can be done. Unfornatel they should of stuck to the CS-1810 design they would of been better off/
Mar 09, 2009 | Kyocera Copystar CS-1820 Black and White...
Km-2030 Checksum error f1
my copier is displaying error code 100, whats the problem km 2030
Jan 21, 2009 | Kyocera FS-2000D Laser Printer
I am tring to load my copier
Please see your user manual in loading the paper properly.
Oct 06, 2008 | Copystar CS-2030 Copier
"Jammed" message
Try new paper.Damp paper causes all kinds of jamming prob.
Jul 13, 2008 | Copystar CS-2030 Copier
Copystar CS-2030 Copier Logo
136 people viewed this question
Top Copystar Office Equipment & Supplies Experts
Kyocera HP Expert
Tammie Duggan
Tammie Duggan
Adorjani Laszlo
Are you a Copystar Office Equipment and Supply Expert? Answer questions, earn points and help others
