Question about Durvet Epsom Salt Poultice 20 oz Jar
Boil How to bring boil to head
How do I properly operate the Turbo Boil on my new Kenmore range?
Turboboil is a feature offered on a number of Kenmore electric ranges and cooktops. Without you model number it's hard to get into specifics - but turboboil is a special, high wattage heating element that delivers up to 3KW of energy to a specific heater on the cooktop. If I understand correctly, you would only use this setting when you wish to bring water to a boil in the shortest period of time possible - then change to a normal burner heat setting to maintain the temperature of the water in the pot.
Remember, an electric heat element is turned "full on" and "full off" as needed to maintain temperature (unlike a dimmer knob controls a light bulb). The turbo boil turns on a "double heater" to rapidly heat the water - after water reaches 212 degrees, it can not be heated any further (it turns into steam) so you should switch to a normal burner mode from that point forward.
Kenmore com
Apr 07, 2015 | Kenmore Kitchen Ranges
I would like a higher BTU gas range and is shopping around for new range.
Most range manufacturers give you the but rating for there burners. I have an electric range that has a "fast boil" burner. It can bring a gallon of water to a full boil in about 10-12 minutes. I also have a commercial gas (propane) range. Its burners are rated around 33,000 btu
Nov 19, 2014 | Dacor Kitchen Ranges
Vy v6 ute i went to check my coolant and there was none in there so filled it up and it started to boil after a bit bit my temp gauge said it was fine and the fans aren't coming on?
have a compression test done as it may not be boil as such but getting compression pressures into the coolant system from a blown head gasket or cracked head
Mar 29, 2014 | Cars & Trucks
How do you cook pasta? Do you boil the water with the pasta in or wait till it is boiling to add it?
In terms of water to pasta ratio, you should use around 4-6 quarts of water for every pound of dry pasta. Once the water has come to the boil add the pasta and then bring it back to the boil. Add some salt, stir occasionally and follow the instructions on the packet to find out how many minutes to cook it for.
Feb 20, 2013 | Cooking
Whenever I cook pasta the water boils over and causes a terrible mess. How can I stop this happening?
The most common cause of water boiling over when you cook pasta is if you cook it with the lid on the pot. Don't cover pasta fully with a lid. Either cook it uncovered or if you are in a hurry to cook it quicker, just partially cover the pot.
Also make sure you don't overfill the pan with water as this is another cause of overboiling.
Jan 10, 2013 | Cooking
What is an average boil time?
Average boil time is the time required to bring one liter of 70 Fahrenheit to boil.
Sep 10, 2012 | Coleman Camping, Backpacking & Hiking
Canon i560 has full ink and when it comes out there is no print at all
your printer cartriage is blocked. try this. boil half cup of water then insert the cartriage head in boil water for 30 sec and then try
Jan 01, 2011 | Canon BubbleJet i560 InkJet Printer
Rice is mushy, I have cut the water down by one cup and it is still mushy. 2 cups rice 4 cups water down to 3 cups water
If you are using regular rice, it is 1 cup of rice for 2 cups of water. Bring the combo to a hard boil and then reduce the heat to a slow simmer for 20min, stirring ocassionally.
If you are using "Minute Rice", it is 1cup of water to 1cup of rice. Bring the water to a hard boil, turn off the heat and add the rice. Cover for 5min. Fluff with a fork.
Feb 02, 2010 | Hamilton Beach 37532 20-Cup Rice Cooker
How to clean out a breville hot cup?
1/2 vinegar & 1/2 water bring to boil and sit for 10 mins then boil with fresh tap water and as pour away.
All should be then OK - it works for us in West Aust!
Oct 21, 2009 | Kitchen Appliances - Others
Durvet Epsom Salt Poultice 20 oz Jar Logo
568 people viewed this question
Top Durvet Hardware & Accessories Experts
Gene Haynes
Craig Butler
Craig Butler
Are you a Durvet Hardware and Accessory Expert? Answer questions, earn points and help others
