Question about Dell Powered Subwoofer Set A425 Computer Speaker Set W8037
Broken knob i noticed after turning the knob up that it started sqeaking and felt lighter at first i thought i blew the fuse so i changed it and did a sound test it sounds fine but the knob wont work correctly
Fuse 12 20A keeps blowing. controls OBDII and cigar lighter
Hi John!
  • There is a short in the Circuit. Do not put any more fuses in it.
  • Take it to the Electric Shop to have it diagnosed.
Good Luck,
JP
Jul 03, 2015 | 2005 Ford Excursion
Cigarette lighter fuse in 2003 dodge neon keeps blowing
The cigar lighter is shorted to ground and needs to be replaced.
Apr 15, 2014 | 2005 Dodge Neon
Horn and cig lighter won't work
disconnect the negative terminal on your battery first.
Jul 02, 2013 | Saturn SC2 Cars & Trucks
2004 Chevrolet Aveo hatchback - lighter/12v outlet fuse blows
it sound to me like the lighter plug itself is loose and when you released the parking brake wiggled the plug enough to short out and blow the fuse . check to see if the plug is loose .
Apr 20, 2013 | 2004 Chevrolet Aveo
Where is the fuse for the cigarette lighter in a 1999 toyota camry and what could be potential reasons why it doesnt work
A good thing to check to see if it's just a fuse is try your external mirrors to see if they move, they work off the same fuse as the lighter.
If it is a fuse, and if you are in Australia then the fuse box is next to the drivers right knee area, In America, then next to their left knee. There is also a fusible link built into some cigarette lighters, mine has one. When it blew, the auto electrician was able to resolder the link and get me going again until I could buy a new lighter.
Hope this helps.
Dec 23, 2009 | 1999 Toyota Camry
I think the fuse for the lighter blew when we put
You should Have A Couple a fuse boxes under the hood make sure you check the one for the lighter an there is probably another back up one too. once you find the one for the lighter check if its broken replace it. Then if the radio still give you trouble try the back up one if its not broken leave it out for a few seconds then put back and restart.some models dont have that back up so just replace the fuse 2 or 3 dollars or at autozone.I hope that helps.
Jun 25, 2009 | 1987 Chevrolet Astro Cargo
Radio, clock and lighter have all lost power
Look straight up under dash, access panel on front of dash, in glove box or could be under the hood in a box.
Jun 25, 2009 | 2005 Dodge Caravan
Cig lighter fuse blew. renewed but cig lighter and remote key not
you probably didnt change the right fuse and had another one blown at the same time you also could have a primary fuse under the hood that blew. once fixed dont use pump again. not same amps drawn
May 06, 2009 | 2003 Toyota Corolla
Broken cigerette lighter Golf GTI
you might check the fuses under the dash on the drivers side
Jan 02, 2009 | 2005 Volkswagen GTI
19 people viewed this question
Top Dell Audio Players & Recorders Experts
jairo sanchez
Jax Planet
Jax Planet
Are you a Dell Audio Player and Recorder Expert? Answer questions, earn points and help others
