Question about Apple iPad 64 GB WiFi
Cannot turn on
The battery completely died. ive plugged in the charger and it just shows that battery charging then it shows the apple icon and it just keeps going back and forth
    New Friend:
Droid razr m wont turn on
Posted on Mar 06, 2014
    Problem Solver:
  • 5 Answers
From https://discussions.apple.com/thread/2462356?start=0&tstart=0
Try pressing SLEEP/WAKE button and HOME button *at the same time* to force it restart for 2 or 3 times and see if it can turn on. Sometime it's just turn off by itself (happens more frequently for me esp when the battery is low) and we have to force it to start again.
Hope this helps,
Posted on Jan 04, 2014
My Tablet is on charge and the screen icon shows it is charging but the Charge % Icon is staying the same
Try a different battery charger.
Maybe you are using a battery charger of a phone.
They have the same plug but different Amperage.
Usually tablets have more powerful battery charger than phones (2.1A instead of 0.5/1A).
The battery charger that you are currently using seems to have enough power just to keep your tablet alive, but not enough to charge it.
You can check on the data written on the battery charger's body the maximum amperage.
Jul 16, 2016 | Amazon Kindle Fire HDX 7
I have a Mach Speed JLAB tablet. It wont power on. Just showes battery with exclamation point in the middle. Why?
That symbol usually indicates the battery isn't charged or charging. It could be a connection problem, a charger problem, or a battery problem.
If you have an extra wall charger, try that first as they don't always last forever. Make sure the plug that connects to your tablet looks clean and not corroded.
If it still won't charge, then chances are the battery needs servicing to make sure the connection is OK or the battery just might need to be replaced.
May 11, 2015 | Tablets & eReaders
Digiland tablet won't charge. Is there a way to
Depends upon exactly what's happening.
  • When you plug in your charger, does it try to charge the Tablet? ie Does the Charging icon come on the screen briefly when the charger is plugged in with the Tablet turned off, or does the little charging 'lightning' symbol come onto the battery icon on the home screen when the Tablet is running?
  • I assume the battery has gone flat, but will the Tablet turn on when the charger is connected?
If the charging icon comes on, and/or the tablet will run on the charger, then both the charger and the charge port connection on the Tablet are OK, and the most probable cause of failure is the internal battery which will need to be replaced.
However, If neither the icon comes on nor the Tablet runs on the charger, then either the charger has died, or the plug/socket on the Tablet where it connects is faulty. The most likely cause is that the charger has died and will neeed to be replaced
There is a slight chance that the internal charging circuits in the Tablet may have developed a fault, but that is highly unlikely {:o)
Dec 30, 2014 | Tablets & eReaders
Why My wont charge my iPad charge
many videos onit just google it. good luck.
Aug 27, 2014 | Apple iPad Tablets & eReaders
Kurio 7s won't charge
Is it turned on when in charger. May need to be turned off before you plug it into charger Then it should show a battery icon on screen showing it is charging ..
Jun 13, 2014 | Techno Source Kurio Kids Tablet With...
I used my table and the battery died. I plugged it in to charge and the tablet wont turn on at all and its been charging for almost 2 hrs. Is there anything i can do? its a 7" irulu with android 4.0
google search netflix 1.8.1 apk download
click on the link that has dropobox at the end
then click on blue download icon
afterdownload is complete locate and proceed to install......
enjoy actually watching and hearing your movie
Feb 17, 2014 | Irulu 7" Google Android 4.0 Capacitive...
I plug it in but it will not charge
You must use the Apple charger or allow extra time if using a non-Apple device. The standard output for a USB charger is 5 volts but Apple uses 5.17 volts. The battery icon at the top of the screen should show a bolt symbol when connected for charging. If it does not you may have a bad cable.
Dec 01, 2013 | Apple iPad (16 GB) WiFi Tablet PC
I have an Asus Memo Pad HD 7 which I purchased 3 months ago. It worked wonderfully until one evening while using the pad plugged into the wall, it stopped showing the charge icon in the upper left hand...
the more programs you install and run in the back ground the more the battery is drained. It comes to a point where there are so many programs running the gadget cannot run & charge at the same time. It might charge better if you uninstall a lot of programs or do a factory reset but that is drastic
Oct 30, 2013 | Tablets & eReaders
My Samsung galaxy tablet 7.0 died out while im playing a game, when I tried to recharge it a battery icon with caution sign show up. It does not recharge anymore. Tried another charger of my other Samsung...
Connection on tablet from charger to battery is not being made and that is why it is not charging in one unit but charging in other. Till problem is resolved charge battery in other working unit.
Aug 28, 2017 | Tablets & eReaders
My Samsung Galaxy Note 10.1 battery not charging can you please tell me why
Same problem on my Samsung Galaxy Note 10.1 (GT-N8013) w/ OS 4.1.2
It just boots up and shuts down.
Dec 06, 2012 | Samsung Metallic Gray Galaxy Note 10.1in...
Apple iPad 64 GB WiFi Logo
96 people viewed this question
Top Apple Tablets & eReaders Experts
Virgil Wolter
Level 1 Expert
Aaron Galvan
Level 1 Expert
john smith
Are you an Apple Tablet and eReader Expert? Answer questions, earn points and help others
