Question about Garden
Cannot connect lance into gun to assemble campell hausefield pow
Bayonet connect will not push down
3 Suggested Answers
  • 2006 Answers
SOURCE: I attached a replacement hose
You have some type of blockage in your lance. I would suggest either taking off the tip and pulling the trigger to blow the obstruction out or trying to clear the blockage with a guitar string.
Posted on Jun 26, 2011
  • 41533 Answers
SOURCE: just got an karcher 411a pressure washer theres a gun but should there be a pressesure lance attached to it before it will work
seems like there should be .
Posted on Oct 29, 2015
Karcher lance fitting
if they are the plastic version, replace them as they tend to "expand" as they age and won't fit properly.
Jul 08, 2014 | Garden
Model CPW 1800 2 lance guns have developed leaks when pumping against dead end. Do these washesr have a pressure relief valve . Can this be replaced?
Byronj25, you can get the internal part that has most likely failed here. http://www.sparesgiant.com/p-4993-annovi-reverberi-210-gun-valve-kit-with-o-s-2291.aspx. You may want to dismantle it though and check that the black elbow tube has not failed also, as that part is obsolete and so would require a full new Lance. New Lance link http://www.sparesgiant.com/p-5002-champion-cpw-yellow-hl2-annovi-reverberi-gun-large-bayonet-40409.aspx
May 21, 2011 | Annovi Reverberi Garden
K 3.65 Can't separate spray lance from trigger gun
Most lances need to be pushed firmly toward the trigger nozzle before being twisted to release.
Feb 08, 2011 | Garden
How to take a part a model 31 shotgun schematic to show how to take it apart
Make 100% sure it is unloaded before you start. Open the action a little bit, then unscrew the barrel nut until you can see space between the plunger and the detent. Turn the barrel and magazine assembly 90 degrees and pull it out (yes, the 31 is a takedown gun). Push out the big pin in the receiver from right to left (looking down on the gun from firing position). Turn the gun upside down. Push the trigger assembly toward the front of the gun until it aligns with the slots, and pull the trigger assembly out of the gun. For BASIC disassembly, most users should stop here. The slide/bolt assembly is a little more complicated, and unless you have some patience, experience, or mechanical knowhow, getting them back together can be a little frustrating. For those who want to go farther, look up a copy of "The NRA guide to Firearms Assembly," or find a M31 manual on E-bay for under $10.
Read more: http://wiki.answers.com/Q/How_do_you_disassemble_a_model_31_Remington_shotgun#ixzz176Xpe7hJ
Dec 04, 2010 | Computers & Internet
Bostitch framing gun
HI, if it happens when you press the trigger the top valve is sticking & your gun needs servicing.
If it is just leaking by itself the trigger assembly needs serving or you can replace the trigger unit. They are not expensive & come as a complete unit (depending on the model).
Moselikely the orings are worn out or dirty
cheers
Lance
Oct 08, 2008 | Tools & Hardware - Others
Garden Logo
63 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
