Question about GE JVM1653 Microwave Oven
There is power to unit, but food will not heat-up
In my case, it was a high voltage fuse that had burned. The reason for that is most likely a shorted diode ($3 ebay) or shorted capacitor ($12 ebay). They are easy to locate and cheap to replace. You will need to remove the cover and use a multimeter to find the faulty part.
Posted on Jan 13, 2014
Runs but does not heat the food.
Microwave Not Heating Troubleshooting Guide - YouTube
? 2:45
https://www.youtube.com/watch?v=_3SbJueEn1w
Aug 31, 2012 - Uploaded by Repair.com
Allow the circuitry to dry out by avoiding stovetop cooking for a few days. .... it to microwave, but its just not warming up myfood at all, any idea on how i can .... Everything works except themicrowave- it wont heat anything up.
Microwave Diagnostic - Has Power Not Heating - GE ...
? 2:34
https://www.youtube.com/watch?v=E_iUYIV8wD0
Aug 9, 2013 - Uploaded by ApplianceVideo.com
Microwave Diagnostic - Has Power Not Heating - GE, General ....internals of a similar GE Microwave unit that would not heat food.... Sometimes it turns on, sometimes it doesn't. .... My GE microwave space saver does not heat but it comes on. ... What's Inside A Microwave Oven (Teardown / Taken Apart) ...
Nov 18, 2015 | Microwave Ovens
Microwave will not heat food
Unless an expensive unit replacing the Magnatron and or Inverter that powers the unit will cost more than replacing the unit itself.
Nov 03, 2012 | Samsung SMH9187 Microwave Oven
Electrolux microwave buzzes and food doesn't heat up
If the unit operates correctly except heating the food, then the unit needs a new magnetron.
Aug 29, 2012 | Electrolux EI30BM55H Microwave Oven
Not heating
Hello
Power Supply
Check whether there is a proper power supply. Look to see whether the cord is connected to a grounded 3-prong outlet and the cord is fully plugged in. If the electrical system is built-in and no power cord is visible, replace or reset the household fuse or circuit breaker.
Microwave Functions
Some basic microwave operational steps may affect whether the microwave is heating. Open and close the microwave door, as the unit will not function with the door open, and push "Stop/Clear" to cancel any previous settings, such as the timer, which do not heat the microwave oven.
Setting the Microwave
Once the power to the microwave has been reset, or verified as working, and the microwave is ready to run, select a new cook cycle and press "Start" to see if the microwave begins to run and cook food as expected. Allow the food to cook for the alloted time and then open the microwave door and check to see if the food has cooked or heated. Choose a longer cooking time and restart the microwave if food is heating but is cooking slowly.
Repair
If all efforts to troubleshoot the function and power to the microwave still do not get the appliance heating food as expected, there may be a repair issue that needs to be addressed. Contact professional technician for advice.
Oct 05, 2011 | Sanyo Microwave Ovens
Unit does not heat food. the light and rotating plate work but food is not heating.
It could be a faulty magnetron, which is responsible to warm up the food. If that is the case, then the cost price of that part is quite expensive and you are better off replacing the whole unit rather than spending money on buying the parts.Hope this helps.
Aug 14, 2010 | Samsung MT1066SS Convection/Microwave Oven
Viking 1100 watt Microwave will not heat food
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
fjj
Jan 05, 2010 | Viking VMOC205SS Microwave Oven
I have a ge spacemaker XL1400. It was manufacture
it sounds to me like the magnetron is shot in it. this is the part that creates the heat. not worth repairing on a 10 year old unit. Sorry.
Nov 08, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
No heating
Sounds like the magnetron has failed. This is the component that produces the microwaves that heats the food.
The cost of the magnetron is about 95% of the cost of a microwave oven. Most people don't, for this reason, replace the magnetron, they replace the whole oven which is probably what you will end up doing.
There is a possibility that the circuit that provides power to the magnetron is faulty and you need to take it apart, find the proper electrical leads and test them with a volt meter. To do this you have to remove it from its mounting and take it apart. It is a fairly lengthy process however.
Benjamin
May 26, 2009 | Kenmore Microwave Ovens
Microwave arced, wont heat now
I'm assuming that it doesn't microwave either. If it does...then the heater is bad. Sears parts sells them. Second guess is a blown fuse or thermosensor. Inside the pad housing, locate the internal fuse and replace it if blown. The thermosensor is a black plastic bit about the diameter of a dime and 3/8 inch thick and clamped to the side of the unit inside the control area. Test it for continuity and replace if open. If not either of these, then you have power supply issues or control panel problems. My bet: the heater blew out. Often, this is caused when you heat greasy foods.
Dec 16, 2007 | Kenmore 69642 Microwave Oven
Not heating the food
sam..vane...two different problems.
Sam...find out if you've got power in the outlet you're using. If not, you've got to check to see if you've got a blown fuse in the unit. Also ...see below.
vane...chances are you have a power issue or the thermosensor which is used for a safety has blown. It is the size of a dime and 3/8 inch thick...black...two wires. You'll probably find it has opened. Found attached inside the control area to the side of the microwave heating area.
Dec 16, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
GE JVM1653 Microwave Oven Logo
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Shekar Avadhani
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
