Question about Bose Lifestyle 48 System
TV & Radio in two different rooms
I cannot listen to the Bose outside the house and listen to the tv inside the house, but we used to be able to . If the Bose music is on outside it is also playing inside the house and I cannot listen to the TV inside the house.
  • 105 Answers
Dual source button, and switch them around to your choice of in/out sounds
Posted on May 21, 2009
Have a bose wave and live in a metal building. Can't get hardly any am fm radio recept. 3.5 mm antena jack. Can I get an am fm antenna? And do I need to mount antenna outside?
The Bose has the option for external antenna, but uses the AC cord as the antenna, so first try stretching your AC cord to its fullest extent in a straight line, then in different directions to see if that improves the situation. This is for FM only. The AM uses an internal ferrite rod antenna, and this is sensitive to direction, so try rotating the radio in different directions to see if signal improves on AM, and place unit as near a window as possible.
If none of this helps, you will be able to use an external antenna, and no it is not mandatory that they be mounted outside ... as long as you have room indoors. In fact, several manufacturers market indoor antennas for apartment dwellers and others under restrictions against mounting antennas outdoors.
But, logically, the best way to improve reception is the largest antenna mounted as high up and as far away from obstructions between the antenna and transmitter as possible.
Good luck.
Don Miller, CET
CET Services
Bose Wave Radio Repairs
don.miller60@outllook.com
Apr 30, 2016 | Bose Audio Players & Recorders
Static on am stations on bose radio
The Bose unit is not the problem, there is interference near by causing the operating frequency to pick up static, check all electrical items in the house including the lights to see if the source can be located, if not it is coming from outside.
Sep 24, 2012 | Bose Wave Radio
I have a bose wave radio fo many years, when turn it on there is a constant buzz as the radio plays. the buzz varies if i move or position the radio differently. sounds antenna related but there is no...
The antenna is built in. The buzz you're hearing is a 60cycle hum (electricity from a nearby appliance) Try this, put an extension cord on it and walk it around your listening room for best reception. You can also find the culprit appliance by turning items off 1 by 1 until buzz subsides.
Jan 04, 2011 | Bose Wave Radio
Cable Guy messed up Bose 18 sound
Make cable guy get you one.I cant believe he left without fixing it.
Sep 20, 2009 | Bose Lifestyle 18 System
Front bose speakers and bass module stopped puttimg put sound
If you're saying you hooked the Bose speakers directly to the Yamaha's amp instead of the prescribed way through their own bass module - they're cooked.
Dec 23, 2008 | Bose Lifestyle 12 System
I have a Denon 2308CI. I use the 7.1 suround. I have my sony STR DE995 to use as a second amp for zone two hook up. My goal is to watch a movie in the living room and listen to the radio or any other audio...
the mani surround room should be connected to the front speakers A, Center, sub pre-out and surround.
for the other two rooms connect them to surround/back, go into settings and in power amp assignment assign the surround back speakers to the multi room.
once this is complete with your remote in the zone2 control mode you can play your sources in zone2 and control the volume also, if you have inwall volume controls set the zone2 volume to -10 and use the room controls.
To listen to the same source in both zones you will have to select that source in both zones
Nov 16, 2008 | Denon Audio Players & Recorders
DENON RECEIVER TWO ZONES
yes you can enjoy of multi zone function which allow you to listen in two different places at same time.(main room& sub room).
Aug 06, 2008 | Denon AVR-1803 Receiver
Yamaha v-663 reciever
Most amps will only power two sets of speakers direcrly hooked to amp (A&B). If you want audio throughout the house, I would recommend a PA system set up with individual room volume controls
May 02, 2008 | Audio Players & Recorders
Remote does not work when plasma tv is on
It is a very strange case that you have.
I think that bose is correct, there is definetly an electromagnetic interference with the system, but the strabge part is that panasonic plasma tvs are not supposed to emit such EMI and they should be shielded.
one advice is that to verify this try putting on the tv, and bring a portable radio close to it and see is there is a change in the sound, if there is one, then definetly your tv is emitting EM fields. this could be due to a factory defect in the tv, have it checked by the retailer where you got your tv.
a second solution is to place the receiver of the bose system further away from the tv and try using both of them.
Dec 07, 2007 | Bose Lifestyle 25 System
Second zone not working
This amp allows you to pick a secondary source for those other rooms. Did you by chance accidentally change it from the "SOURCE" designation that makes room 2 listen to same thing as room 1? Just a thought.
Dec 04, 2007 | Denon AVR-3801 Receiver
Bose Lifestyle 48 System Logo
96 people viewed this question
Top Bose Audio Players & Recorders Experts
Electro Med Services...
Ben Armstrong
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
