Question about Dr. Heater DR-998
My Dr. heater DR-998 will not come on,
I purchase it in November and on Christmas eve went to turn it on but would not come on. I tried different plug but still did not work. I tried to turn it on the next morning still want come on.
ITS BEEN SITTING ON SHELF UNTIL NOW HAD IT 2 YRS PERR Dr. THIS WOULD HELP WITH BREATHING I have breathing problems=Please help me
No way of knowing, it might but it would depend on what kind of "breathing problem" you have. Try following the users manual in setting the unit up. If you can't find your user's manual, you can download one from here (The start up instructions are on the second page.)
http://www.appliancefactoryparts.com/content/pdfs/183477-1.pdf
If your using hard tap water, make certain you clean the unit every week with vinegar and water. If your using "soft" water, once a month will usually suffice.
I would also suggest using a 1/2 cap full of a bacteriacide (actual amount on bottle, usually 1 cap full per gallon), which is marketed for this specific application. A single bottle should last for years.
Jan 03, 2016 | Sunbeam Humidifiers
Just bought and plugged in E1 error!! Can't get it to work!!
then return it to place of purchase for replacement or refund .
Oct 11, 2015 | Sunheat TW-1500 Thermal Wave Infrared...
Replace power cord on DR-968 infrared heater.
On most appliances you can swap a cord from any other appliance that you are throwing out. Open up the unit and disconnect the wires (either from crimp style marrettes or crimp push on or crimps with the eyelette) On the housing look for the nylon connector. Pinch this with a pair of pliers and pull out. Putting them back in is tougher but acheivable if you hav patience.
Oct 19, 2013 | Dr. Heater DR-998
Does not give mist
Try running vinegar through it. This helps to demineralize it. Once it's clean, put salt in it to create more steam.
May 04, 2013 | Humidifiers
Just stopped giving mist
Depending upon the hardness of your water supply, humidifiers sometime have to be "primed" to get them going. This information should be contained in the instructions for use
May 04, 2013 | Sunpentown Cool Mist SU-2000 Ultrasonic...
BH 3950 plug overheating
this happens when you have run a heater for a long time on an outlet that is either not giving the heater enough amperage or to much amperage try it in a different room if the problem persists try a different heater.
Nov 05, 2011 | Humidifiers
Output/Fan will not turn no matter what setting the speed control dial is on. Blue light and green light go on when humistat knob is turned. I purchased this humidifier in November and it was working...
Sorry to read about your problem, I hope this helps you out.
You either have a defective power switch, or defective motor, your unit is under warrenty, so I suggest you return it..
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
2 Thumbs - Somewhat Helpful
1 Thumb - Not Helpful
Dec 28, 2010 | Honeywell HCM800 11 Gallon Humidifier
One of the cells that hold water has a small crack in it and I would like to buy another cell.... its the left side Dr Labelle
I think you would be etter served to just repair that crack - it can be done in minutes with a product called Plastiweld, available at your local auto parts store. Make sure you allow it time to cure as stated in the directions. I have used it on several different jobs and never had a failure.
Good luck!!
Nov 15, 2010 | Holmes Products Cool Mist HM3500...
Vicks Vaporizer shorting out the house power
could be faulty element or earth leak - as it is new - I strongly advise you to change it at the store you purchased it from.
Jul 21, 2010 | Vicks Warm Steam Vaporizer 1.5 Gallon...
Dr. Heater DR-998 Logo
53 people viewed this question
Top Dr. Heater Humidifiers Experts
Paul Carew
Dennis
Are you a Dr. Heater Humidifier Expert? Answer questions, earn points and help others
