Question about Pitco Frialator SG18S Deep Fryer
Frialator pitco thermopile connection - Pitco Frialator SG18S Deep Fryer
4 Suggested Answers
kebah
  • 683 Answers
SOURCE: 13 year old pitco frialator fryer pilot wont stay
Hi there.
Check and tighten all wiring connections.
Check the hi limit for continuity across the terminals using an ohm meter, if it has no continuity, you have to replace the hi limit.
Regards.
Posted on Aug 28, 2011
ljoeman55
  • 3 Answers
SOURCE: Just purchased a used pitco frialator model no.145
what kind of problem?
Posted on May 03, 2013
  • 3 Answers
SOURCE: my pitco gas frialator oil leak in tank .how can
is not the tank leaking, is the drian valve dripping
Posted on Jul 21, 2013
How much current should the thermopile generate on a Pitco VF35-s Frialator
That doesn't sound out of line for a cold thermopile. Check it hot - hold a candle flame against it. The voltage should rise.
Aug 13, 2014 | Kitchen Appliances - Others
13 year old pitco frialator fryer pilot wont stay on. changed gas valve and thermopile.... pilot light wont stay lite
Hi there.
Regards.
Aug 21, 2011 | Pitco Frialator 35CS Deep Fryer
The pilot light goes out when i release the pilot knob. I have a 35 c pitco frialator
Hi there.
Check the thermopile, it must be clean and free of soot or any form of dirt. The gas pressure must be sufficient and all wiring should be tightly connected. Check also the hi limit, it should have continuity across its terminals when tested with an ohm meter.
Regards.
Jul 21, 2011 | Pitco Frialator 35CS Deep Fryer
When the pilot light button is released the flame goes out. (pitco propane fryer) - unsure of model number as data plate is worn. Does the thermopile need replacing ?
Try first to clean the thermopile. If it has accumulated soot/ carbon, it will not sense enough heat from the pilot flame to generate small amount of electricity to energize the pilot valve and main valve of gas valve.
May 18, 2011 | Pitco Frialator SG14 Deep Fryer
I have a pitco 35c fryer the pilot light will light but the flame is very low it goes out when i release the controll the pilot light adjustment has no effect on flame i have the right amount of fuel...
Check and clean the thermopile, it is the cylindrical piece of metal standing behind the pilot assembly.Try also to tighten its wiring connections to the gas valve and high limit.If it does not correct the problem, replace the thermopile.
Apr 06, 2011 | Pitco Frialator 35CS Deep Fryer
I have a used sg-14 pitco that i want to use outside for my family reunionsdo i have to use a large tank oflp or can i use a 30-lb tank when i light the pilot it will not stay lit when i release the button...
You can check the voltage generated by thermopile using a voltmeter. Set the voltmeter on milli-volt setting then heat up the thermopile. When properly heated, it can generate 500 to 750 milli-volts.
May 20, 2010 | Pitco Frialator SG14 Deep Fryer
Pitco rtg 14 gas pilot goes out
Sounds to me the thermopile (thermocouple) is at fault, it's a safety device to detect if the pilot flame is alight or not. If the pilot should go out for any reason, the thermopile will detect this & shutdown the gas valve (ie the unit will cease to operate).
A new thermopile should solve your problem. It's not a task I would attempt yourself if you are in any doubt.
Mar 05, 2010 | Pitco Frialator Kitchen Appliances -...
Hi, i am having a problem with a deep fryer. Pitco Frialator 35CS. The pilot is liting, but the burner will not lite. Solve this for me. thanks
Make sure that the gas pressure is standard (as rated on nameplate), thermopile must be clean (no dirt or soot) and the thermostat is good.
Jan 19, 2010 | Pitco Frialator 35CS Deep Fryer
Pitco fryer pilot out
if you changed the thermopile and still have the same problem make sure that the sensing bulb is directly over the flame. If it is and the thermopile is installed correctly the next thing would be the gas valve.
Hope this helps
Jun 19, 2008 | Pitco Frialator 35CD Deep Fryer
Thermopile
The thermopile for the 35cd,35cs,pit40sn,sg185 are the same thermopile the part number is P5047541. The only other thermopile in use for pitco products is the one for the solstice series it is part number 60125501
Mar 19, 2008 | Pitco Frialator 35CD Deep Fryer
Pitco Frialator SG18S Deep Fryer Logo
24 people viewed this question
Top Pitco Frialator Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
paulcarew
Treefrog15
Treefrog15
Are you a Pitco Frialator Kitchen Appliances - Other Expert? Answer questions, earn points and help others
