Question about Bernina Virtuosa 160
Bernina Virtuosa 160 not stitching on right side
RickE1
  • 202 Answers
SOURCE: Bernina Virtuosa 160
First the simple solution. Make sure your needle is inserted flat side to the back and all the way up.
The only other thing I can think of is that your hook is out of time and this will take a technician to re-time it. You may need to take it in for a servicing.
Posted on Jul 27, 2008
RickE1
  • 202 Answers
SOURCE: How is presser foot adjusted ?
If your stitches are tiny more than likely the feeddogs are not working correctly. More often than not its because the pivot points for the feeddog mechanism inside are gummed up,dirty and oily and they need to be cleaned. Your machine is in need of service. Does not really have anything to do with presser foot pressure especially if you have tried adjusting that to no availe.
It needs servicing.
Posted on Feb 13, 2009
calmeblondy
  • 33 Answers
SOURCE: loose pressure foot - how do I tighten on a Bernina 160 Virtuosa?
use small screwdriver provided, usually orange, streight edge,
Posted on Sep 28, 2009
  • 980 Answers
SOURCE: I need a new electronic board for a Bernina
Only from a Bernina agent or direct from Bernina.
Posted on Mar 10, 2010
  • 166 Answers
SOURCE: I have a Bernina Virtuosa 153 sewing machine that
You may need to increase the foot pressure to cope with the heavy denim material. Look carefully at the material as the machine tries to stitch ... if the foot is not keeping the material firmly on the stitch plate, it might be riding up on the needle (denim tends to be rather 'grippy') which will prevent the thread loop being formed correctly below the stitch-plate and therefore not getting picked-up by the CB hook. Changing to a bigger diameter needle might actually make the situation worse in this case ... go back to an 80 and try again.
Posted on Nov 21, 2011
I have a bernina virtuosa 150. how do you change stitches with the cps system?
try contacting bernina customer service and ask them how to
change the stitches
Feb 06, 2013 | Bernina Virtuosa 150
IF THE COTTON GATHERS AT THE BOBBIN SIDE OF FABRIC WHEN SEWING WHAT ARE THE POSSIABLE REASONS
This a tension problem, the upper thread is too tight, lower the number on the tension gauge until the stitches look the same top and bottom.
May 23, 2012 | Bernina Virtuosa 160
My Bernina Virtuosa 160 bunches up the thread on the bottom side of the fabric, any thoughts as to why?
My problem has been solved. We removed the plate, brushed it and replaced the plate. it works fine now.
May 07, 2012 | Bernina Virtuosa 160
I turned off my machine to change the pressure foot on my Bernina Virtuosa 160. The pressure foot number does not change on the display. Is there something I need to do to change the number?
The machine Knows the foot number buy the small glass part of the foot just on the upper right side of the foot. Check to see if that is not damaged and clean. Also check the sensor on the machine just above the foot for not damage and clean. If that is good make sure your foot is paralel with the stitch plate. Do this buy putting a single hole foot on your machine and make sure the needle is right in the center. If this does not work you will need to take it in. May be a bad sensor or unpulged but that is rare.
Also not all bernina feed have this foot sensor, if this is the case it will not read it
hope this helps
Mar 27, 2011 | Bernina Virtuosa 160
I tried to use a double needle on my Bernina 160. The top stitching looked ok, but underneath the thread was straight and you could pull the bottom thread right out. I've heard the bottom is supposed to...
When you thread the top thread, ALWAYS RAISE the presser foot so the thread will seat completely in the tension disk. If this doesn't improve the stitch, try tightening the top tension. If it is too loose, the bobbin thread will lay on the surface of the fabric. When the top tension is tightened, it will pull the bobbin thread up into the fabric.
Feb 03, 2018 | Bernina Virtuosa 160
Machine not stitching
In my town, when you buy a new Bernina, you get a free series of classes to learn how to use it. Call your store and see if they have a "Get to know your Bernina" class for your machine.
Jan 13, 2009 | Bernina Virtuosa 160
It needs servicing.
Jan 07, 2009 | Bernina Virtuosa 160
Jun 28, 2008 | Bernina Virtuosa 160
Programmed stitches on the 160
As a Bernina tech I can tell you to try adjusting the stitch balance with the small knob on the side + or -. Just in little increments until they start to look right. Maybe this has gotten turned too far off. If this doesn't help (50/50), worst case scenario most likely the small gear has been jarred loose or has skipped a tooth to the stepping motor which means a tech will have to reset this and balance it from the inside. There are also steps to take in the service program but again this would be a job for a tech. I suggest you get the whole clean, oil and adjust as this would be included in that.
Apr 12, 2008 | Bernina Virtuosa 160
Sewing Machines Logo
14 people viewed this question
Top Bernina Sewing Machines Experts
Tally Girl
Tally Girl
jnissen
Level 1 Expert
Chris Wetmore
Are you a Bernina Sewing Machine Expert? Answer questions, earn points and help others
