Question about ICOM Informatique Icom F14 VHF 16ch handheld 2-Way Radio
Range seems to be very low. using the f14 at golf tournaments but can't get from one end of the course to another.
How do choose a better golf rangefinder?
If you want to buy a golf rangefinder then here's the article about the Golf Rangefinder.
There really isn't one that's "best", all are a combination of features and price.
However, and this is VERY important, you need to decide before you buy whether or not you're going to play in any organized tournaments. If you intend to play in organized tournaments, and the tournament allows rangefinders, do NOT buy a rangefinder that will measure slope in addition to distance. That rangefinder is not legal for tournament play, and if you use it, even if you don't use the slope feature, you will be disqualified.
Mar 22, 2018 | Optics
What does F 14 mean on electrolux stove?
f14 misconnected keyboard cable. 1) verify connection between display board and touch panel (2 ribbon electrical cables).make sure the cables are completely seated into the connection point both ends. If the cables are connections check ok then replace the touch panel. If the problem persists still occurs replace the complete display board
Dec 05, 2016 | Electrolux Kitchen Ranges
Can a golf ball be replace by a different type of ball during tournement play
"There is nothing in the Rules of Golf that prevents a golfer from switching to a different brand of golf ball (i.e., from a Titleist to a Bridgestone) on every hole on the course - so long as the change is made between the play of holes.
However, there is something in the Rules of Golf that says a tournament committee can impose such a rule.
It's called the "one ball condition" (in the rulebook, it's in Appendix 1, Part C), more commonly known as the "one ball rule." As you probably know, all Tour events are played under the "one ball rule." And any rules committee may adopt the "one ball rule" for its competitions.
"The "one ball condition" requires the player to use the exact same brand and type of ball throughout the round. For example, if you tee off the first hole with a Titleist Pro V1x, then that's what you must play throughout the round. You may not switch to any other brand of ball, nor even to any other type of Titleist ball. You started with the Pro V1x, so the Pro V1x is what you must use on every stroke. "If the "one ball rule" is not in effect, however, golfers may swap out different types of golf balls at any point in a round of golf, so long as the change is made between holes rather than during the play of a hole."
Aug 25, 2014 | Golf
F14 Error
First please get the full model number of the range. Kenmore products are made by other manufacturers and the error codes will depend on the manufacturer.
Most likely, you have a Frigidaire range (for example a 970. model). Then the F14 code could indicate a problem with the P12 ribbon cable connector tail, a bad EOC (control unit), or touchpad. First try disconnecting and reconnecting that cable. Next the EOC should be replaced. Finally the touchpad should be replaced.
If this is a brand new range, contact Sears to get a repair person to fix the range. If you bought it used, see the above possible solutions.
I hope this helps.
Dec 24, 2013 | Kenmore 30" Electric Double Oven...
What is the steady ed tour?
The"Steady" Ed Tour merges NorCal and SoCal discgolf to create the premier California disc golf tour. The series' events bring top NorCal and top SoCal players together where they can go head to head with friends other disc golfers from around the state and some of the best players in disc golf.
The "Steady" Ed Tour is made up of a series of independent tournaments known for their top notch tournament directors who put on fun, safe and exciting events. Each year DGA and the "Steady" Ed Tour sponsors make the "Steady" Ed Tour the best attended tournament series in The Golden State.
For more info: http://www.discgolf.com/tournament/steady-ed-tournament-series.html
Jan 14, 2013 | Sport & Outdoor - Others
I can't seem to access the Tiger Woods AE Sports golf site. I am trying to get online to play in a golf tournament. I cannot access the site. I am told that it is my ISP.. But my ISP is working fine.
Try a different web browser, or adjust security settings in existing browser. If IE8 is installed, uninstall it, reboot and try again. IE8 is not quite ready for the real world in many situations.
Aug 11, 2009 | Computers & Internet
Need a manual for Busnell 1500 Pinseeker Tournament
bushnell.com>north america>english>golf>laser rangefinders>Pro 1600 tournament edition> now look toward the bottom of the page and you will see the manual tab....you can download it to your computer. The 1600 and 1500 work the exact same way....the case and battery door are the only thing different!!!
Apr 11, 2009 | Bushnell PinSeeker 1500 20-5103...
Radio Communications Logo
Top ICOM Informatique Radio Communications Experts
eradiostore
eradiostore
BJ Russell
Steve
Are you an ICOM Informatique Radio Communication Expert? Answer questions, earn points and help others
