Question about Fujitsu Heating & Cooling
How to clean heat pump filter - Fujitsu Heating & Cooling
Can Heat Pumps be contaminated by Dust.
That makes a little sense to me.. the air is heated or cooled as it's blown through cooling and heating coils. The filters might have blocked the dust on the intake side, but the exhaust into each room wouldn't be protected, and the coils are on that side.
I'm not in heating and cooling.
Nov 02, 2015 | Heating & Cooling
Heat Related Pump Not Running
Have you cleaned or replaced the filter? Try removing the filter and running it, if the problem goes away , replace the filter. Cheers
Dec 31, 2017 | Balboa Instruments Garden
Waterco Aqua Heat Titane 101, The Fan Come On But Compressor Does Not KickIn?
make sure your filter is clean, heat pumps are fussy about too much back pressure. you might try it with the filter cartdrige renoved
Sep 21, 2013 | Waterco Baker Hydro 80K Btu Titanium...
Fujitsu heatpump 13 years old is not heating room as it used to.filters are clean.i have gauges and would like to know what pressures are good and what pressures indicate low refrigerant or worn...
The refrigerant and compressor are related in cooling the room.As for heating problem the thermostat needs to be checked.
if you're used to a certain temperature of air and your heat pump is producing much cooler air, take the following steps. (Note that a heat pump may go into a defrost mode to prevent icing. When this happens, it can temporarily output cold air. Also be aware that the heat pump will have to work harder to produce heat.)
1) First be sure the thermostat is set properly. Try raising the set temperature 5 degrees F. and waiting a few minutes.
2) Be sure the room-heating registers are open.
3) Check the heat pump filter. If it's dirty, change it.
4) Be sure the auxiliary heating elements are working .
5) Clean the coils of the outdoor condensing unit.
If still the same problem then thermostat needs to be checked and replaced.
Thanks.
Jun 15, 2010 | Heating & Cooling
I have four blinking lights and it reads clean filter cartridges or call for service. First three lights blink jet one jet two and light and also heat light. All four blink and tub will not heat up. Keeps...
Is your pump actually moving water?
I think you should replace your cartridge filter or at the very least, do a thorough cleaning in accord with the manufacturer instruction.
There is a possibility you have pump impeller damage or there is other problem with the pump.
May 13, 2010 | Qca Spas Majestic Series Aruba Xl Hot Tub
Digital read out....fault high ref pressure.
Verify circulating pump is on and that there are no water flow restrictions to the heat pump. Make sure all necessary valves are open or in the proper positions to allow proper water flow to the heat pump. Verify filter and skimmers are clean. Check for water level in the pool. This condition may also appear if the heat pump has not been operated for an extended period. To clear the condition, cycle the heat pump, on and off, up to 3 times. If this does not correct the problem, call for service.
Jul 25, 2009 | Jandy Ae2500t 115,000 Btu Heat Pump
Heat pump turns on and off in the heat mode
Check both coils. If they are dirty have them cleaned.
Jan 17, 2009 | Heating & Cooling
Heating & Cooling Logo
59 people viewed this question
Top Fujitsu Heating & Cooling Experts
Fotis Papastamatiou
Bill Long
Are you a Fujitsu Heating and Cooling Expert? Answer questions, earn points and help others
