Question about Chronotech Revolution Watch
Adjusting band It's big
Got this watch for xmas, nice. the band is too big. how do i adjust the metal band?
u can have ur watch to the watch shop they may make it short fitting on ur hand
Jan 04, 2011 | Invicta 100 Meter Sport Diver Quartz...
I GOT A ZR11811 WATCH FOR XMAS AND BAND IS TO BIG IT IS ARELIC BRAND
Take it in to your local watch repair shop, they have the required tools in most cases to make the adjustment.
Dec 28, 2010 | Relic Watches
Can't adjust the wrist band on citizec C651
Look where the band connects to the fold-over clasp. There are several holes on the clasp. Use a plastic headed thumbtack or some other small pointed object to push the pin in and move to desired hole to fit your wrist.
If the longest adjustment is still not big enough you will need to add a link to the band. You can contact Citizen Watch at 800-321-1023 they will send you 3 links at no charge.
Oct 21, 2010 | Citizen Skyhawk Eco-Drive JR306059F Wrist...
Watch strap a little big
mcdevito75 here, Maybe a link or 2 can be reoved from the metal band, or an adjustment at the clasp can be done. Look for a small watch repair shop in your area, they can help.
Jul 08, 2010 | Casio A168W Wrist Watch
Clasp on watch band is big problem. Will not stay
I will not pay for advice. Skagen should be there for their customers as all big companies are. I understood the advice would be free.
Jan 15, 2010 | Skagen 358SSSD Wristwatch
How to make a relic watch bracelet a little smaller?
No but if this is a mens watch there might be a micro adjustment on the clasp. To adjust press the pin in the clasp and move the pin in or out depending on the position of the pin to make loose or tight.
Sep 18, 2009 | Relic 0504648FA
Remove links on this watch
Most bands have removable links on the end of the band. You can tell because they have small holes on the side to remove the pins that hold them together. The links that don't have holes are not removable. This is standard on most metal bands.
May 09, 2009 | Timex Atlantis 100 77517 Wrist Watch
Adjust ladies citizen watch metal link band
If it is a metal link band, you can remove a few segments. Segments are connected by split pens. You should see a thinner end and a bigger end; or an arrow on the inside shows where the thinner end should be. Push the thinner end firmly with a pin or something until the big end pops out the opposite side.Use pliers to remove the pin.
Apr 12, 2009 | Citizen Eco-Drive BL006056H Wrist Watch
Purchased fossil ladies watch am4183 at Macy's, stainless steel band is too big, is this band adjustable, if so how.
Check the sides of watch band and you will see the pin ends. They are holding all links together. If there are arrows inside the watch band, they are pointing the way the pins must come out.
To shorten the band you have to:
Extract the pins.
Take link(s) off.
Join the rest of band together and drive pins back.
Jan 01, 2009 | Fossil JR8096 Wrist Watch
Adjusting mesh band
Take a small flathead screwdriver, or maybe a metal nail file and pry up the catch.DO NOT pry up by placing the tool on the rod used for hooking the clasp side to this side. Just stick in the metal piece that is folded over ( it should have a little notch in it) and pry it up. If you still don't understand I will be glad to send you a picture later on today. PLEASE let me know either way!!
Aug 11, 2008 | Watches
Chronotech Revolution Watch Logo
12 people viewed this question
Top Chronotech Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Chronotech Watch Expert? Answer questions, earn points and help others
