Question about Home
Where to purchase dual cistern flush button for imperial toilet T-IBP01 V2.0
5 Suggested Answers
SOURCE: Can old style dual cistern be converted to new style 6/3
We have not solved the problem but after speaking to 3 Major Plumbing Supply Places
they have told us we have no alternative but to replaced both the whole toilet suite's
as older style pans don't match up with never models
Posted on Jan 05, 2009
  • 34 Answers
SOURCE: Slow Flushing mechanism
Check the angle stop at the wall ( valve) if it more then a few years old the rubber inside sticks try turning it off and on a few times. Well first just make sure its open all the way to start. If both of those do not work It might have a screen at the opening of the preeure mechanism...check that the was no line trash caught in it from turning the water on and off. If none of these things work let me know and we can get more technical in find out whats wrong...heck you could have just gotten a bad one. The Plumbing company I worked for when I lived in houston had the contract with them to do there warranty work and boy did we do a lot of it .
Posted on Feb 04, 2009
  • 129 Answers
SOURCE: i needs new valves for my dual flush, close
No I'm sorry they do not. You might try plumbing supply house in your area.
Posted on Sep 26, 2009
  • 517 Answers
SOURCE: Toilet Flush. We have an integrated toilet
Good day!
OK please double check the connection and proper installation of it..
and try to look the cable if you press the button it should go up together with the rubber..
try to adjust the cable to upward..
if you have follow up question just add a comment to give you another idea..
thanks for using fixya and have a nice day!!!
Posted on Jun 29, 2011
Roca dual push button Toilet will only flush when holding the push button continuously down until the cistern is empty. It won't completely flush like it should when pressing the button once.
allow tank to fill a little more by adjusting fill valve. When there's not enough water flowing from tank the stopper can over-power the water flow and cause the flush to stop by re-sealing.
Feb 28, 2015 | Home
Invisi Series ll Round Dual Flush Plate & Buttons
That would be a leaking flapper valve. They are inexpensive and easy to install. Good luck
Jun 09, 2014 | Toto Aquia II Dual Flush Toilet
Imperial toilet cistern parts
go to the website and read for instructions on replacing the float valve or the flapper or the float
Jul 11, 2013 | Home
Grohe dual fush push button
hey,
If you can get a new bellows this is possible.Repairing a bellows is also possible if you have the skills and tools to hot-air solder it.
Look at this guide that might help you. though it is not the exact model, principle is the same.
Have fun
Avi
Grohe GD2 flush system concealed cistern repair fix and disassembly...
Dec 11, 2012 | Grohe 38 771 000 Eau2 Dual Flush Air...
Cant get the lid off a push button cistern
There are some dual flush cisterns where you have to depress one button to reveal a cavity in the second button. Put a screwdriver in that cavity to left out the second button, then release the first button and pry that out.
Underneath the buttons is a screw which must be unscrewed to release the cistern lid.
Not sure if this will apply to you... but if not, good luck anyway.
Feb 01, 2011 | Duravit 0910100005 Happy D Toilet Cistern ...
How do i fix a cistern that is continually leaking in to the toilet bowl? i have tried to open the cistern at the flush button unit but do not want to force open. tried twisting but is quite tight.
most modern toilets do not have an overflow pipe to outside instead they overflow into the bowl itself so have to adjust level so it does not overflow into return
Apr 02, 2010 | Toto Aquia II Dual Flush Toilet
Weak dual flush does not empty the toilet bowl.
well, yes... but apart from providing you with a forum in which to vent your frustration I'm not sure how you think we might help. I have the same problem with a dual flush cistern, but in my case I know that the root of the problem lies in the fact that the soil pipe leading from the bowl has insufficient fall (because the previous owner of my house moved the toilet further from the down pipe). Maybe something like this is contributing to your problem too?
Jan 21, 2010 | Duravit 0910100005 Happy D Toilet Cistern ...
Cannot remove top of cistern
There are some dual flush cisterns where you have to depress one button to reveal a cavity in the second button. Put a screwdriver in that cavity to lever out the second button, then release the first button and prise that out.
Oct 29, 2009 | Duravit 0910100005 Happy D Toilet Cistern ...
I needs new valves for my dual flush, close
Aug 05, 2009 | Home
Home Logo
32 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
