No or bad signal most of the time especially when windey
  • Televison & ... Master
  • 5,487 Answers
See previous reply
Posted on Jan 04, 2014
Freeview problems
To pick up digital signals you need two things a good aerial and a good lead to it. The best type of aerial is like the one shown below. As for the cable to it, get the same stuff used to link up satellite dishes. Also shown below. If you need to split it for more than one TV get a proper splitter.
Never use the old type brown cable, it lets in water and doesn't stop electrical interference. A badly suppressed car on the old analogue TV caused a few dots on the picture. If it gets into a digital signal the picture will freeze and then vanish till it's gone. That's why you need very good cable.
To watch the HD channels you will need a really good signal, so invest in a decent aerial.
Jan 03, 2014 | Televison & Video
Emergency flashers flash when right turn signal lever is used. Left turn signals work normally
Check your grounds especially on the right turn signals. A bad ground will make it do all kinds of weird things.
Jan 03, 2012 | Volkswagen F 224 Cars & Trucks
My neighbourgh can get freeview tv just using his old ariel, i on the other hand can not. have i done something wrong with the tv set up. thanks
Probably not. Freeview signals are hundreds of times weaker than the old analogue signals, so will show up every single problem on a badly maintained, badly installed old external tv aerial.
In most areas, a tv set-top aerial is a waste of time and even a loft aerial may have problems. Any aerial system which is not direct from the external aerial to the tv can also suffer problems, as each Y-splitter and joint wastes an awful lot of signal.
Your fix is to get a proper modern aerial system fitted. If it's well designed and installed with the proper parts and cabling (does not necessarily mean most expensive) then it should last for another 30 or so years and ideally won't need signal amplifiers.
Note that although your neighbour gets reception, he probably suffers regular picture break-up, freezing and /or pixellation especially in poor weather unless the aerial was in top condition beforehand and was relatively modern.
Jul 12, 2011 | Televison & Video
97' OLD'S CUTLASS SUPREME (TURN SIGNALS) Front and Rear LEFT & RIGHT TURN SIGNAL ONLY, Will not flash. When using the turn signal switch the lite stays on, I have to use it manually. ** 4-Way...
Beware...some GM cars , especially 94-96 were made with two flashers in them. One was for the emergency flashers and the other was for the directional. If you flashers are located under the dash by the steering wheel look around you will see the other one. Be sure to replace it with the proper one.
Jan 08, 2018 | 1996 Oldsmobile Cutlass Ciera
Ihavr a 2000 chevy cavalier for some reason the brake lights dont work most of the time, also along with this the turn signals ewont flash. ive already replaced both sockets and bulbs in the rear im not...
Check your fuse first thing. You may also have a bad brake light switch. If the turn signals come on but just will not flash then replace the flasher relay.
Apr 04, 2011 | 2000 Chevrolet Cavalier
When using the FM reciever, there is a
due to the nature of the f.m. signal you may notice a hum when locked into a signal especially during times of no modulation(talk/music),otherwise if its severe enough,look for ground loops and bad solder joints that let signals radiate through out the receiver and create humming,also check the power supply filter capacitors if its a 60 cycle line noise hum
Mar 19, 2010 | Audio Players & Recorders
95' Buick regal, 3rd brake light works, tail lights work, turn signals work, stoplight switch seems to work ie 3rd brake light working, fuse is ok, changed bulbs, but no rear brake lights.
If the third brake light works and the regular ones don't, it is most likely a bad turn signal (multifunction) switch. The switch is able to kill the brakes lights to run the turn signals, and in rare circumstances does this. I've seen it several times. It could also be wiring, especially near the turn signal switch, but it is usually the switch.
Nov 25, 2009 | 1995 Buick Regal
I have a 2000 VW Passat. Recently, my cruise control has been acting up. It will engage but shut off every time I turn on my left turn signal or my brights. However, three days ago, it stopped working...
Check the wiring harness, especially the one that goes underneath the dashboard and steering column. There may be bad wires or loose connections that may have caused your cruise control to act up when turning on the signals or the brights. If that checks out Ok, inspect the speed sensor near the transmission. It may have gone bad.
Oct 27, 2009 | 2000 Volkswagen Passat 4Motion
Device is locking up and losing satellite signal at times
Are you sure there IS a signal all times? Especially when driving in cities with tall buildings or near transmission lines the signal may seem to 'disappear' and the screen freezes.
Jul 17, 2009 | GPS
No picture on dish tv
The 311 receiver is normall a pretty tough machine. Getting a 70 % signal is normal, and it shouldn't fluctuate too much unless you have something like a tree or other obstacle in the way.
85% of the problems with these older systems is the LNB. I see it all the time.
My first suggestion would be changing the LNB (the eye of the dish). You say that your system is 10 years old, and there are a lot of LNB's out there that go bad over time. It may say that you are getting signal, but the quality may be so poor that the receiver may not know what to do with it.
If you have 2 LNB's (separate eyes) on your dish, then you have two singles or duals with a switch 21. I'd remove these and replace them with a Legacy Twin LNB. If you have a Twin LNB, then replace it with another Twin (especially if it has "lot" number printer in the front of it, these are notoriously bad).
I hope this helps you...
Jan 08, 2009 | RCA DISH Network(r) 311 Satellite System
Televison & Video Logo
24 people viewed this question
Top Televison & Video Experts
