Freeview problems no or bad signal most of the time especially when windey
  • Televison & ... Master
  • 5,126 Answers
To pick up digital signals you need two things a good aerial and a good lead to it. The best type of aerial is like the one shown below. As for the cable to it, get the same stuff used to link up satellite dishes. Also shown below. If you need to split it for more than one TV get a proper splitter.
Never use the old type brown cable, it lets in water and doesn't stop electrical interference. A badly suppressed car on the old analogue TV caused a few dots on the picture. If it gets into a digital signal the picture will freeze and then vanish till it's gone. That's why you need very good cable.
To watch the HD channels you will need a really good signal, so invest in a decent aerial.
Posted on Jan 04, 2014
Nikkai freeview box was working fine until yesterday eve but then came up with no signal or bad signal. Tried re-tuning but doesn't make any difference.
This would definately sound life a signal problem. Freeview signals can vary quite alot in strength.But you should have it on a solid surface to protect it from heat
Nov 07, 2012 | Televison & Video
My neighbourgh can get freeview tv just using his old ariel, i on the other hand can not. have i done something wrong with the tv set up. thanks
Probably not. Freeview signals are hundreds of times weaker than the old analogue signals, so will show up every single problem on a badly maintained, badly installed old external tv aerial.
In most areas, a tv set-top aerial is a waste of time and even a loft aerial may have problems. Any aerial system which is not direct from the external aerial to the tv can also suffer problems, as each Y-splitter and joint wastes an awful lot of signal.
Your fix is to get a proper modern aerial system fitted. If it's well designed and installed with the proper parts and cabling (does not necessarily mean most expensive) then it should last for another 30 or so years and ideally won't need signal amplifiers.
Note that although your neighbour gets reception, he probably suffers regular picture break-up, freezing and /or pixellation especially in poor weather unless the aerial was in top condition beforehand and was relatively modern.
Jul 12, 2011 | Televison & Video
Problems on the freeview 21inch Tv Teknica from Tesco was working when we bought it 2 years ago cannot get all the channels and poor reception re installed channels many many times but does not maintain...
you may want to try changing the coaxial aerial cable that feeds the tv, these can go faulty. also if you are running a series of tvs off one aerial, you should be using an aerial booster, other wise you will get a signal drop (as displayed on your tv).
If these small things don't cure it, the set requires replaceing as the tuning card is knackered
Jan 16, 2011 | Audio Players & Recorders
We have analog tv and freeview box but arial is in loft. signal strength is 70 percent and is good most of time.have found bad breakup when running 3kw shower and 3kw kettle, no other apliances interfere,...
The problem with inside aerilas is the signal strength of 70% contains noise as well. You could try using a higher gain aerial and the interference will be limited with a better signal.
Any electrical items can interfere with a poor signal.
Dec 30, 2010 | Televison & Video
I have a sony tv. It only has sound on some chanels. I have checked the cable connection with another tv;it is ok. What should I look for
Hi It sounds like a signal problem, I'm assuming its Freeview channels you are dropping, I have had the same problem on some of my TV's especially since the re-tuning channel 5 fiasco. Have you tried Re-tuning the DVB-tuner from the freeview menu, then settings or set-up or installation, then choosing the First Time Install option as it will wipe all previous channels. If you have a portable you can try it on the same aerial see if you have the same problem with that, then if it is the signal, buy a booster and put that on the RF input, which is what I did with the same problem. I am in a poor signal area and have had to have my aerial raised to get even an average signal.
Dec 06, 2009 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Freeview - No transmitter found
The signal from the communal aerial might be weak, since other people are using it, or it is experiencing interference with a power cable or something.
Try a signal booster from **** Smith or Harvey Norman, RadioShack, Tandy, Walmart etc ( I assume you are Australian - Freeview :) )
OR
Get your own aerial, if you don't live in a concrete shoebox....
Oct 12, 2009 | Televison & Video
No Signal On D/TV
You may lose some channels when you retune the TV as the channels have been rearranged. To locate them look at the EPG although you may still find that some channels are no longer available on FREEVIEW. See the following link for additional information
http://www.freeview.co.uk/_retuneinfo/
If the above process does not work then check the link above for additional information and also visit the accompanying site links below to find more information for your model of TV / FREEVIEW box.
For troubleshooting the retune procedure visit http://tvretune.co.uk/troubleshooting/
For specific model information visit http://tvretune.co.uk/productmanuals/
Oct 01, 2009 | Samsung LE26R72B 26 in. HD-Ready LCD...
No freeview bbc channels
just solved the problem
with the variable attenator fitted i did a rescan still didnt work
but when i did a rescan to the restore factory settings it now works
Nov 24, 2008 | Televison & Video
LE32R74BDX
this is because most new lcd tv's have a poor tuner built in and require a stronger ariel, to pull in the analogue or digital signal. Check that your ariel is freeview capable whether using freview or not, as these ariels are better at pulling in the signal, or do what i have had to do and buy a mains plug in signal booster from Asda for about £6.00, this did the trick, especially if you don't want to replace an ariel costing about £30.00
Jun 13, 2007 | Samsung LN-R409D 40 in. LCD Television
Televison & Video Logo
71 people viewed this question
Top Televison & Video Experts
Electro Med Services...
