Question about Husqvarna , No.455 Rancher, 20" Gas - Powered Chainsaw
Husqvarna 223l trimmer shuts off
Had it for about fours and it ran great, till about a week ago. Its starts up fine but shuts off after about 20-30 seconds. If i prime the gas it starts and shuts off again. Cleaned plug, changed gas and oil mix.
  • Jim Parker
    Jim Parker May 11, 2010
    The four hours that you used it, was that the first time you had used it for a while?
    Jim
I have been having the same trouble. Try replacing the fuel lines...
Posted on Jul 13, 2009
  • grantd2010 Sep 30, 2010
    check your coil. If it is not functioning correctly, when the trimmer gets warm it will cause it to stop working. also check your carberator fuel to air ratio.
    Guru:
  • 597 Answers
See if air cleaner is plugged or needs changed or cleaned
Posted on Jun 05, 2009
Starts up when choked then dies. Has a new carb and using 4 cycle fuel that is fresh. Ran great till 3 weeks ago then this.
I just went through the same problem with my Yardworks trimmer that is identical to this. If it starts when chocked after priming but stall immediately would usually indicate that there is no fuel getting to the engine. I also found that switching to non-ethanol premium fuel made all the difference in the world.
Jun 06, 2015 | Troy-Bilt 29cc 4-Cycle Curved-Shaft Gas...
Husqvarna 223L won't start
I would first take the spark plug out and see if the tip is wet, it could very well be flooded.
second of all I'd try putting fuel directly into the carb (if this helps you'll most likely need a carb kit or maybe even a new carb)
May 30, 2013 | Husqvarna 223L
Why won't my Husqvrana 223L trimmer crank?
Electrolux products are junk, should have bought a stihl.
May 08, 2013 | Husqvarna 223L
Replacing pull start on 223l trimmer
Its pawl has either come off the recoil spring or the recoil spring has broken. There are videos on youtube showng you how to repair this fault.
Sep 20, 2012 | Husqvarna 223L
Husqvarna 223l starts but quits before I can even get the choke off, then will not even start again. Has been great until this.
I can assure you it wont be leaking oil, as the only oil it uses is mixed with the fuel.
Lock throttle trigger on,
Start on full choke till it fires,
Switch to half choke and it should fire up on high revs,
Blip the throttle and it should turn to tick over.
If it still keeps cutting out it could point to a carb or fuel takn issue.
Aug 04, 2012 | Husqvarna 223L
put a meter to the spark plug wire and see if it fires. Make sure all lines are clean.
Jul 23, 2012 | Husqvarna 28cc Gas Line Trimmer
Bump head wears out very fast on husqvarna 223L
Are you resting the head on the floor while strimming and wearing out the bumpcap? Are you hitting it too hard on the floor when you want it to feed out.? Are you using the full harness or the strap harness when using it.? Either way it should be set the the correct length, so the strimmer is just off the floor, i like to have it so the front tilts down, that way it would keep the bumper off the floor. Either way thay should last way longer then 2 weeks so i put it down to opperator error.
Jul 07, 2012 | Husqvarna 223L
Husqvarna , No.455 Rancher, 20" Gas - Powered Chainsaw Logo
568 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
