Question about Husqvarna Garden
Husqvarna 130 governor
Where is the governor on the husqvarna 130 and if i remove it will it give me more speed?
  • mattiec23 May 22, 2009
    im 14 years old just foolin around with my dads tractor lol
  • 376 Answers
The governor is there for a reason, to keep the engine from over-reving and self destructing. Sure, you can get more speed by removing/raising the rpm's, if you want your rod to end up sticking out through the back of the engine case.
Posted on May 22, 2009
  • Dwain Pippen May 22, 2009
    Out of curiosity, why do you think you need more speed? Dwain
    Uh huh. Your dad's gonna be fooling around with your **** with his belt soon, too. lol
When a husqvarna lth 2142d ride on lawnmower losses speed what is problem
21 hp briggs big motor
if not a drive belt or gearbox issue
is the Governor set properly
rider mower serviced regularly
carby jets adjusted
no stale fuel clean fuel filter
valve clearance to spec
newish plug
not burning oil
Oct 24, 2016 | Husqvarna Garden
Governor,carb problem
Sounds like the linkage spring is not working correctly or was never replaced during rebuild. I would replace that spring as a starting point.
Aug 01, 2015 | Husqvarna Garden
Governor settings for 18.5hp B&S single cylinder,31E777-2439-B1 Husqvarna
The governor shouldn't need to be adjusted unless it has been bumped or removed. But, if your sure the problem is the governor, you adjust by moving the governor arm in the direction that opens the throttle valve all the way open. Remove air cleaner and filter to inspect while doing this to make sure. Then note that direction, keep in this position, then loosen small nut on governor linkage at base of unit. With a needle nose pliers, turn small center shaft of governor linkage(the part that leads inside engine) in same direction you moved the linkage in earlier step. While holding in place tighten small jam nut. This is called a static set, which is a factory standard. Also, make sure throttle cable is in wide open position when doing this. Good luck.
I’m happy to assist further over the phone at https://www.6ya.com/expert/layne_0fccff498c319c32
Feb 16, 2014 | Garden
Engine speed surges up and down
Keith:
First check for the obvious... fresh fuel? clean air filter? carburetor mounting bolts/nuts tight? cylinder head bolts tight? crank case bolts/nuts tight?
Now to adjust the governor:
Find where the governor shaft comes out of the engine... loosen the nut and bolt on the governor arm clamp (where the governor arm clamps to the governor shaft). Gently pull the governor arm back until it stops, Gently turn the governor shaft the same way (some have a slot for a screwdriver or a hex-head for a nut driver to hold the shaft at it's closed position) as you pull the governor arm. Both the arm and the shaft must be at their full stop of travel while you tighten the governor arm clamp. It may take another person to lend a hand to keep the governor arm at the closed position while you tighten the clamp.
Nov 30, 2013 | Tecumseh Snowblower Snow Blower Starter...
2006 Husqvarna yth2042 motor runs well, but has trouble accelerating and going up an incline
If the motor runs good at a low rpm, I want to say your problem lies somewhere in the governor. As you put load or strain on the engine the governor should increase the throttle speed on the motor. My guess is a wire, cable or something is rubbing on the linkage from the governor to the carb, if not the governor my need readjusted. I hope this helps.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/steve_f5a6ca85b5d1ffc9
Oct 02, 2013 | Husqvarna YTH2042 42" 20 HP Lawn Tractor...
I have a Husqvarna GT 2548 with a 25 hp Kohler eng. Engine idles fine and drives fine until I engage blades , then it bogs down. It is really bad if I am moving up an incline. I checked the blades and...
The governor regulates the engine speed and when a load is applied that would slow the engine it is the governor's job to open the throttle to maintain the speed. It also limits the maximum engine speed to a safe level. As a user of the machine you should have formed an idea about whether the governor is working correctly.
If the governor linkage moves freely against the spring(s) and the maximum revs of the engine are about right no adjustment should be attempted and the fault probably lies elsewhere, most likely fuel starvation though bad ignition or valve timing, tight valve clearances or partially blocked exhaust can affect power output.
A back-to-basics approach is usually the best if the problem has built gradually but if it happened suddenly I suggest you begin by thoroughly cleaning the carb.
Aug 05, 2017 | Husqvarna Garden
Speed of the lawn mower governor is missadjusted
The engine revs are turned down to make the machine noise compliant, increasing the revs will greatly increase the noise, the engine revs shouold not realy be increased, however a dealer with a suitable engine taco may do it for you, it is very important not too over speed the engine or it will self destruct,
Apr 11, 2013 | Tecumseh Lawn Boy Push Mowers Insight...
2008 Husqvarna LGT2654 Idles high and bogs with deck engaged
Hi, basically the bottom case will have to come off the motor again as your friend has failed to correctly position the governor gear against the governor arm, sorry Phil.
Jun 14, 2012 | Husqvarna Lawn Tractor - 54in. Deck, 26...
Sir i m very sorry to disturb u but i m simply an engineering student of 7th semester n my project is on electronic governor so i just want to know how the electronic governor is efficient over the...
a mechanical gov can use springs or fly weights to control the amount of fuel delivered at a given rpm. an electronic does basically the same thing but with the use of speed sencers and cervos that can control fuel, spark, and timeing. the first is a straight forward approach and has worked well over the years. but the secound is more precise and adjustable withe the stroke of a key board. as to which is better, that depends on the application. mechanical works off engine rpms and takes abuse well but can only regulate speed useing rpms so if you have more gears the faster you can go. where as the electronic uses speed sencors that pull info from the trans or wheels and will only let you do the speed set by the computer
Nov 20, 2009 | 2007 Ford E-150 XLT Wagon
Speed Limiter/Governor issues 2001 Olds Alero
t there is no mechanical speed governor. It is controlled by the PCM - engine computer which you would have to reprogram to increase the limit. Dealer only
Nov 07, 2017 | 2001 Oldsmobile Alero
Garden Logo
312 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
