Question about Minolta Magicolor Office Equipment & Supplies
Pagemaker 7 0
Magicolor 3100 will not print in color.
  • Minolta Master
  • 6,161 Answers
Are all of the image unit and color toner Minolta/QMS (OEM) not third party. Does the machine print the demo page OK?
Posted on Feb 04, 2015
4 Suggested Answers
toddg
  • 171 Answers
SOURCE: printing issue
In order to proceed with the solution to your problem, we'll need to save the current settings on your Crown printer and then restore the printer to its original factory settings as shipped. Your current settings will be saved, and can be restored after we finish this troubleshooting session. You will need to access the printers front panel in order to perform the following settings.
Procedure to save your current printer settings
Procedure to restore printers original factory settings
Procedure to restore your saved printer settings
1. Make sure the Online light is lit and that the display reads Idle.
2. Press the Online/Offline button to take your printer offline.
3. Press the Menu button once. The display should read Operator Control.
4. Press the Right Arrow button once. The display should read Administration.
5. Press the Select button once. The display should read Communications.
6. Press the Left Arrow button until you see Miscellaneous in the display.
7. Press the Select button once. The display should read Save Defaults.
8. Press the Select button again. The display should read No.
9. Press the Left Arrow button once. The display should read Yes.
10. Press the Select button.
11. A few seconds should pass until the display reads Yes Is Selected.
12. Press the Online button twice to take the printer online while the display reads Idle. Your current printer settings are now saved and you are ready to proceed with returning the printer to its original factory settings.
6. Press the Left Arrow button until you read Miscellaneous in the display.
8. Press the Right Arrow button. The display should read Restore Defaults.
9. Press the Select button once. The display should read Factory Defaults.
10. Press the Select button again. The display should read No.
11. Press the Left Arrow button once. The display should read Yes.
12. Press the Select button. Yes Is Selected will appear in the display.
13. A few seconds will pass and the printers display should read Disk And Flash Sys Loader.
14. Your printer will reboot with the original factory settings and return to Idle.
Try a test print. Does the problem still exist?
10. Press the Right Arrow button. The display should read Custom Defaults.
11. Press the Select button. The display should read NO.
12. Press the Left Arrow button once. The display should read Yes.
13. Press the Select button. Yes Is Selected will appear in the display.
14. A few seconds will pass and the printers display should read Disk And Flash Sys Loader. Your printer settings are now restored to their original saved settings
Try a test print, does the problem still exist?
Posted on Sep 24, 2008
  • 141 Answers
SOURCE: My new Magicolor 1600w Printer hasthe toner light
Probably. Most color images have some black in them as well.
Posted on Aug 09, 2009
  • 78 Answers
SOURCE: Minolta Magicolor 3100 ...
Does the printer show any message on it's display ?
Most common problem with these printers is the driver setting (mostly media type/weight) conflicting with the settings made via the front panel menu's.
Posted on Jan 04, 2011
Compatible pagemaker
Check your default settings on the Pagemaker 7.02 it might be defaulting to B/W or Monochrome or grey scale all these mean the same thing black and white. Check that program then check your control panel setting on you computer. it might be set to one of them if so then all programs on the computer are set to black and white.
Jan 03, 2014 | Minolta Office Equipment & Supplies
Typing white text on black background
Normal printer ink does not print white - it does every other color, just not white - if you really need white printing, you should contact a professional printing company, they can generate white printing,
Apr 08, 2012 | Adobe PageMaker 7.0 for PC
How can I get a copy of the driver to install my Minolta magicolor 3100 Laser Printer to another pc?
Hi margomontez!
You can get the driver from the manufacturer's site at this link
http://onyxftp.mykonicaminolta.com/download/SearchResults.aspx?productname=magicolor%203100%20
Just select the one that matches your operating system (windows 7, windows xp, etc.
If you are downloading it onto the computer you want to install it on just double click the file you are downloading once its done and follow the on-screen instructions.
If you installing it on a different computer than the one you are downloading it on take the file you downloaded and burn it to a cd/dvd or copy over to your storage device (flash drive, etc)
That should take care of it for you and good luck!
Feb 22, 2011 | Minolta magicolor 3100 Laser Printer
Minolta Magicolor 3100 ... Printer sayes its online and ready to print. When i send a print job it spools it ok but when it goes to print it goes offline. I delete the print job and the printer is back...
Jan 04, 2011 | Minolta magicolor 3100 Laser Printer
Waiting on input end job
Try to clear all the waiting jobs, a printer keeps the undone jobs in memory, Sometime that can cause you problems like that, The printer waiting and waiting and waiting.
Rightclick on the printer icon
open it
check for printerjobs in the queue..if there are any.
Good lyck to you
Dec 16, 2008 | Minolta magicolor 3100 Laser Printer
Unable to print both side though requested
as i know, usb-printers don't support both side printing. It is words of the generant
Sep 24, 2008 | HP LaserJet P2015dn Printer
Printing envelopes
Try setting the page setup to 8.5x11 and adjust the margins to landscape, top and left margin approx 4". A lot of times the envelope templates are afterthoughts.
Pagemaker programmer's supervisor, "Forget that template, nobody will ever print envelopes in Pagemaker"
Hope this helps!
Mar 02, 2008 | HP Color LaserJet 2600n Printer
Paper margin problem in pagemaker application
Do you mean the left margin is too large so all the content is shifted to the right and off the page? If this is the case, it is probably a setting in Pagemaker. In the file menu, choose "page setup" or "print setup". Check the paper size. Check the margins.
Jun 24, 2006 | HP Color LaserJet 2600n Printer
Top Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
CheckitRight
CheckitRight
David Burkhart
David Burkhart
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
