Question about Nokia Unlock N70 N71 N72 N90 6630 6680 6681 6682 Unlock Smartphone
Security cord to reset new security cord
    New Friend:
N70 phone code how to unlock
Posted on Jan 07, 2014
I forget my phone luck cord and how i know my phone luck cord?
Hi whether you forget the phone security lock code then try default code like 0000 or 1234 to reset your phone ...If those code didn't help to reset your phone then have a look at sites like Unlock-Free.com here they generate master reset code for some Nokia and alcatel mobile models at free of cost ...You can use this code and reset your phone then assign new security code ...
Aug 22, 2013 | Cell Phones
Broken pull cord
How to replace a broken pull cord on a leaf blower.
1) Remove Hex bolts holding plastic leaf blower housing in place with your hex wrench. you may want to cut the cord with scissors and loosen the bolt or screw securing the rope assemble with hex wrench or screwdriver.
2) Remove spring assembly Carefully. (DO NOT REMOVE THE SPRING ONLY REMOVE THE ASSEMBLY)
3) Remove old cord. Notice the direction the pull cord is wound. This is important in the following step
4) Wind new pull cord in the same direction you removed it, as in step 3, Make sure cord secures in the slot provided on pull and assembly.
5) Replace the pull cord pulley and place over spring.(This is the white plastic spool.)
6) Rotate the pull cord assembly 2 or 3 times in the same direction the cord pulls. (wearing safety goggles and work gloves) Reinsert the center screw by securing in in place with your screwdriver.
7) Insert the leaf blower cord into the end of the handle opening. Secure the handle by tying a knot at the bottom of the new cord.
8) Place the pull cord assembly back onto your blower in its designated area then secure by refastening the 4 hex nuts.
9) Replace the housing cover of blower and refasten the hex nuts.(the housing you removed in step 1.)
I hope this was some help to you. Good luck.
Jul 01, 2012 | Homelite Consumer Products Backpack...
I have a Toshiba DKT3210-SD. The person who set the voicemail security code no longer works here. I need to reset the security code. Can you help me?
call your voice mail and log into mailbox 999.(dial the pilot number possibly 555 or 850 then hit the star key when you hear the greeting) the default security code for mb 999 is 999997.
Hit option 8 then listen to the prompts you can reset just the password or the entire mailbox. the new default password will be the mailbox numbe followed by 997. Ex Mialbox 200 new password will be 200997
Sep 14, 2011 | Toshiba DKT-2020 Corded Phone
I need Reset lock cord nokia e5
there is nothing like reset cord!!! if you want to reset as facotry setting you have to search out the option reset all at security menu, the default password would be 12345 but if the same has been changed then you have to put the correct password.
if you dont know the correct password it mean you required help of a professional who can unlock or reinstall a new firmware for your mobile with help of JAF or MSKEY tool box.
Do not try to install firmware yourself by googling on the net as the same can make dead your phone permanently.
please vote me if found helpfull.
Aug 02, 2011 | Nokia E5 Cell Phone
Phone code i fogot my code
What is Mobile Phone Brand and model,you forget the security code or password means You need to master reset the Phone,You can get the master reset code from here
Onlinegsmunlock and reset from the security Lock Or password lock.
Jun 15, 2011 | Cell Phones
Security reset cord
Try master reset codes for your phone here http://www.superunlockcodes.com/nokia-dct-master-code-service/rs12wp10/ by the way you can reset the security code and change new
Nov 13, 2010 | Nokia Cell Phones
Hi,my phone is nokia 5130c-2,,IMEI;-35422403070141,,how i can have a free cord........or..restricted cord...please help me...........
To Unlock the Mobile from the Security Lock,You can use the Master Reset Code,To get the Master Reset Code at reliable cost You can reach here
http://www.mobile-unlocker.com/unlocking-services/rs2wp6/ / and Unlock it,You check Master reset Code for Your Mobile there..I unlocked my nokia 1600 there from Security Lock,Using the Master Reset Code................
Nov 01, 2010 | Nokia 5130 XpressMusic Red Unlocked Import...
Need to access wirless internet but dont know my security key or passphrase.
Hi connellmandy, no real way around this... Best to reset the wireless router back to factory defaults, reconfigure to lock it down and apply the security key/passphrase to your wireless laptops. you WILL also need to know what your old settings were for example, your ISP username, ISP password, IP addresses, your new wireless security keys, and ports and services that were opened. It all needs to be re-entered.
For Belikin routers:
    •Unplug all LAN cables from the router.
    •Unplug the router power cord connector from the back of the device.
    •Using a paper clip or something similar that will fit into the reset hole, press continue to hold the reset button, then carefully reinsert the power cord, making sure not to release the reset button in the process.
    •Continue to hold the reset button in for at least 15 seconds after inserting the power cord, then release it. After about 10-25 seconds the router will boot and it will be set back to the original factory default settings.
By default the password on the router is left blank, and the default IP address is 192.168.2.1
For Netgear:
The default username is admin and the password is either password or 1234. (Try these before resetting the router.) You may be able to get the wireless security key and/or passphrase.
  1. Press the reset button on the back until the test light blinks. This takes about 10 seconds. (To avoid accidental resets, the small button is recessed. Use a pen or paperclip to access it.)
  2. Release the button.
  3. Wait for the router to reboot.
  4. Log in with the default password.
    If the router configuration was not cleared, try these additional steps AFTER the router has finished rebooting.
  5. Unplug the router's power.
  6. Press and hold the reset button. While the button is held down, reconnect router's power.
  7. Continue to hold the reset button for 20 seconds after reconnecting the power.
  8. Wait for the router to reboot.
  9. Log in with the default password.
Good Luck .. hope it helps out. Most routers have a small pinhole at the back of the modem to reset the unit back to factory defaults.
Oct 07, 2010 | Computers & Internet
Nokia Unlock N70 N71 N72 N90 6630 6680 6681 6682 Unlock Smartphone Logo
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
